Issues | Warranty | Recalls / TSB Problems, issues, recalls, TSBs |
04-07-2015, 09:18 AM | #1 |
Drives: 2013 Subaru BRZ - 6MT Ltd
SOLVED: No Reverse/Backup Signal or Lights
I no longer have backup lights and my backup camera doesn't show up on the head unit either.
I put a backup camera in over a year ago. It has worked flawlessly and would automatically pop up on the stock BRZ head unit when I went into reverse. About 2 weeks ago this stopped. I figured out my backup lights weren't coming on either. The first thing I did was check the fuse...good. Then I replaced both backup bulbs...still nothing. I pulled the head unit and checked all of the plugs...no issues. I probed the #2 wire on the 28 pin plug going into the head unit which signals for reverse and it had no signal. See image below provided by www.AutoHarnessHouse.com: Then I found another location for this signal thanks to www.AutoHarnessHouse.com down by the hood release. I probed that and had no signal either. Lastly I pulled the fuse again and checked to see that power was getting there, and it is regardless of whether the car is in reverse or not. Does anyone have any idea whats going on? Last edited by sidetrak06; 04-08-2015 at 09:42 AM. |
04-07-2015, 09:25 AM | #2 |
Switch at the shifter went for a crap? Would explain why all the back up functions no longer work.
04-07-2015, 10:49 AM | #3 |
That was my thought as well, do you know where that is accessed? Is it from inside or under the vehicle? If anyone has seen it please share any info you have.
04-07-2015, 12:08 PM | #4 |
Drives: '13 Black Subaru BRZ Limited
Same thing here, I noticed the reverse indicator in the HUD also doesn't show. Wiggling the shifter gets it pop up which also has the backup lights come back on. What mods do you have that could be related to this? I was thinking it could possibly be my reverse LED's or somehow the MTEC shift springs. I haven't looked into yet since wiggling the shifter is a quick fix and I've been too busy.
04-07-2015, 12:15 PM | #5 | |
04-07-2015, 04:42 PM | #6 | |
Drives: 13 Subaru BRZ, 02 Audi TTQ
The Following User Says Thank You to Scenic Driver For This Useful Post: | Tcoat (04-07-2015) |
04-07-2015, 05:11 PM | #7 | |
Drives: Subaru BRZ '13 WRB
04-07-2015, 07:01 PM | #8 |
Thank you @Scenic Driver, the problem is solved...and I have no #@$%ing idea how it happened. I went to look for the A53 switch and look what I found!
A frayed ground wire and the reverse wires pulled out of both ends of the connector! I have never even been in this part of the engine bay before. At first I was thinking mouse...but the wires look cut. After cleaning up the crap this is what it looked like. I am absolutely blown away. I followed the wires back, which just lay on top of the transmission and I don't see how they could have caught on something to do this. In the end I just eliminated the plug and soldered new wires between the transmission and the harness and everything is working as normal. WTF?!?! |
04-07-2015, 07:14 PM | #9 |
Wow
04-07-2015, 08:25 PM | #10 |
Drives: 2013 Firestorm FRS
wtf...weird.
Mouse with a knife...cause he's classy like that |
The Following User Says Thank You to continuecrushing For This Useful Post: | Tcoat (04-07-2015) |
04-07-2015, 09:34 PM | #11 |
A Mouseketeer?
The Following 2 Users Say Thank You to Tcoat For This Useful Post: | CamryDS (04-08-2015), continuecrushing (04-08-2015) |
05-27-2015, 06:19 PM | #12 | |
I just checked those wires and they look fine. Although the way those wires run along the transmission housing I'm thinking it could have melted the shielding somewhere down the line and is causing a short. I'll have the dealer mess with it when I have time to take it there. |
04-04-2017, 06:18 AM | #13 |
Drives: brz
bump. Does anybody know what the red clip controls? I need to replace that part. Mine was pinched during a clutch install and I am having a hard time figuring out what it controls and what it is even called.
04-04-2017, 09:20 PM | #14 |
You have mice crawling up there to keep warm at night. Bet.
Edit: wow gonna read the timestamps next time Last edited by Mr Nerd; 04-04-2017 at 09:30 PM. |
Similar Threads | ||||
FR-S / BRZ Reverse/Backup LED Bulbs! See Comparison Photos, Ships Same-Day! | Diode Dynamics | Exterior Parts - Lighting | 72 | 11-30-2021 02:19 PM |
Diode Dynamics Tail-as-Turn™: Make your LED tail a turn signal & add backup LEDs! | Diode Dynamics | Exterior Parts - Lighting | 192 | 10-04-2017 11:51 AM |
Reverse gear signal on factory HU harness? | Panman | Electronics | Audio | NAV | Infotainment | 2 | 01-24-2014 10:24 PM |
Interior LED + Reverse backup package? | Intake | Scion FR-S / Toyota 86 GT86 General Forum | 1 | 07-12-2013 11:46 AM |
Radio Signal Issue When shifting into Reverse | ruskymx | Scion FR-S / Toyota 86 GT86 General Forum | 13 | 01-22-2013 09:05 PM |
