Old 04-05-2015, 11:16 AM   #1
yomny
yomny's Avatar
Drives: 2013 FRS Whiteout
Question How are you logging at the track?
How do you get your engine's feedback at the track? I'm mainly asking how to get you logs from ecutek or any obd2 source that gets all engine parameters at the track since having a laptop on the passenger seat is out of the question. Software based is my interest, i don't have to have guages everywhere since this isn't a track car but would see the track once in a while and would like to make sure things are ok. Thanks
GTX2867R, moto-tuned , tomei op , motiv fp , Invidia Q300 ti , Rota titan 17x9 +42 , nt555 255/40 , ST coilovers w/cascam , Hotchkis sways
yomny is offline   Reply With Quote
Old 04-05-2015, 11:20 AM   #2
jvincent
jvincent's Avatar
I use the Harry's Lap Timer app on my phone and bluetooth OBDII reader.
The only useful measurement it doesn't give is oil pressure.
The nice thing about HLT is that you can record video on the phone and overlay the readings (RPM, speed, gear, etc) onto the video. It also provides graphs / data overlay on the track map.
I just bought an external GPS unit since the phone GPS only samples at 1Hz but with the external I can get 5Hz or 10Hz.
HLT is $20 on Android for the most advanced version.
Edit: If all you want are gauges and data logging, the Torque app will do that as well.
Old 04-05-2015, 03:29 PM   #3
yomny
yomny's Avatar
Thanks man I have Harry's lap timer and it's pretty cool. I was more interested not in telemetry but actual engine parameters. Coolant, oil temp, boost, fuel trims, afr, knock...
Old 04-05-2015, 03:34 PM   #4
jvincent
jvincent's Avatar
I think Torque will give you all of those.
The Following User Says Thank You to jvincent For This Useful Post:
yomny (04-05-2015)
Old 04-05-2015, 04:14 PM   #5
yomny
yomny's Avatar
Yeah I'm looking into a similar app. Just trapped one of those elm wifi obd2 transmitter to read with an iPhone app.
Old 04-05-2015, 04:29 PM   #6
dp1
driving smoother faster
Drives: Sold
OBDLink MX adapters are good (http://www.obdlink.com). I use the WiFi MX with iPhone, DashCommand for diagnostics, Harry's Laptimer for track/ax, external bluetooth GPS (Dual 150A)
dp1 is offline   Reply With Quote
The Following User Says Thank You to dp1 For This Useful Post:
yomny (04-05-2015)
Old 04-05-2015, 07:02 PM   #7
xwd
The OBDLink MX is the best BT reader I've used.
Since I have Ecutek I have a small Windows tablet (Venue 8 Pro) I use to datalog engine parameters sometimes, but it requires a cable. Hard to beat the data you get and the resolution though. Using an external input I have it logging wideband AFR also, but no way to log oil pressure.
I believe the OFT box can record most parameters as well now.
Old 04-05-2015, 09:51 PM   #8
yomny
yomny's Avatar
Yeah I figured it'll be hard to log afr, oil pressure and even knock since these aren't things the obd2 reports, that I know unless using a more advanced software like ecutek. I guess it'll do to keep an eye on temps. Even though oft and ecutek could be used it'll be a tad uncomfortable, possibly risky having those longer obd2 connectors under the dash at a track drive.
PS-thanks for your feedback.
Old 04-06-2015, 12:48 AM   #9
ddeflyer
Pretty sure the engine doesn't know the oil pressure, only that there is pressure or not.
Fun car leads to autocross, autocross leads to track days, track days lead to lemons, lemons leads to racing school, racing school leads to spec Miata...
No idea where it leads next!
ddeflyer is offline   Reply With Quote
Old 04-06-2015, 06:49 AM   #10
yomny
yomny's Avatar
Yeah oil pressure isn't measured or at least is not displayed. Maybe he meant temp since oil pressure was never mentioned before in this thread.
Old 04-06-2015, 12:40 PM   #11
mav1178
mav1178's Avatar
Drives: 2005 Toyota Camry
Aim Solo DL.
Datalogging, plus I set up the display to show real-time lap times (plus delta to lowest session time).
But in all honesty, I don't need to see all the parameters at the track. Aside from temps, the other stuff is useless unless you have a horrible tune.
-alex
The Following 5 Users Say Thank You to mav1178 For This Useful Post:
AZP Installs (04-06-2015), CSG Mike (04-06-2015), frssfo (04-06-2015), raul (04-22-2015), zdr93523 (04-22-2015)
Old 04-06-2015, 01:01 PM   #12
yomny
yomny's Avatar
Yeah that is true I was just wondering if there was a way without having to need someone next to you holding your laptop to get a good log. So aim solo gives you temps? Thanks
Old 04-06-2015, 02:06 PM   #13
GotMunchies?
Drives: '14 WRB BRZ 6MT Limited
For those using their phones to log data, what mounts are you using to keep them from flying about the cabin?
GotMunchies? is offline   Reply With Quote
Old 04-06-2015, 02:06 PM   #14
ddeflyer
Most of the OBDII apps give you temps.
Aim Solo DL talks can bus so it gets the data faster and also pulls some nice stuff like accelerometer data and brake pressure.
Datalogging 2nd gear pull? 1Cor10:23 Software Tuning 11 04-04-2014 01:42 AM
Now Available: OpenFlash Tablet Datalogging/Datagraphing (BETA Release) Shiv@Openflash Software Tuning 255 02-15-2014 04:43 AM
OpenFlash Tablet Datalogging Suggestions Shiv@Openflash Forced Induction 12 02-05-2014 02:31 AM
EcuTek Datalogging Question xxscaxx Engine, Exhaust, Transmission 8 05-24-2013 12:31 AM
Track Day: Upcoming Joey G Open Track Day for ADVANCED Drivers, Aug 20 NJMP Lightning AZP Installs Tracking / Autocross / HPDE / Drifting 0 08-14-2012 06:46 PM
