Tracking / Autocross / HPDE / Drifting What these cars were built for! |
03-22-2015, 10:33 AM | #1 |
Drives: 13 FR-S whiteout / blue w2w
SCCA Touring 4 Non-Adjustable Shock absorbers
I am looking for shocks but I am very restricted because I want to race in the SCCA Touring 4 class.
SCCA T4 class requires non adjustable shocks but does allow Eibach 4.10582.880 Sportline kit. They allow are SPC 67660 control arms Tires will likely be 225/45/17 NITTO NT01 Engine will be stock with Cat delete and tune so Max 185-190 Whp Does you have any recommendation on shocks? There looks to a very limited choice in non-adjustable shocks. |
03-22-2015, 12:07 PM | #2 |
Drives: Some rust bucket
RCE Tarmac zero are non-adjustable but valved for the street. I think you're going to be looking at custom made shocks, eg., Bilsteins, MCS, etc.
03-22-2015, 05:01 PM | #3 |
Drives: 2013 Raven Scion FR-S
Pick up some bilsteins b12 for use with the eibach springs
Emmanuel Baako: NASA-Southeast Race Control & NASA Florida Race Director
RaceCar:2013 Scion FR-S #986 NASA PTD || Tow:2011 Dodge Durango R/T Last edited by phastafrican; 03-24-2015 at 11:23 PM. |
03-23-2015, 11:28 AM | #4 |
Confused a bit...
Are you required to use fixed perch non-height adjustable shocks? Or no damper adjustment? Or both... - Andy |
03-23-2015, 11:35 AM | #5 | |
T4 shocks
Andy, below are the rules. I have a note into the SCCA as well. T2-T4 The make of shock absorber may be changed. Their number, perch location(s), system of attachment, and attachment points shall not be altered. Their type (tube vs. lever, etc.) shall not be altered. The interchange of gas and hydraulic shock absorbers is permitted. T4 only: (unless specified on spec line) Any non-adjustable shock absorber is allowed. The shock must be installed in the original mounting locations. Remote shocks are not permitted. Threaded shock bodies or adjusters may be used. a. The mounting hardware utilized shall be of the original type. b. The use of any shock absorber bushing material is permitted. Note: the bushing attaching the end of the strut to the body or frame on a strut-type suspension system is considered a suspension bushing, not a shock absorber bushing. c. T2 only: minimum ride height is 3.75” inches. T3 and T4 only: minimum ride height is 4.5” inches. Ride height to be measured without driver at the lowest point of the rocker panel, but not to include welded seams or fasteners. d. T2-T4 only: Cars with alternate spring allowance in spec line, may use adaptors, and threaded perches to allow fitment of springs. |
03-23-2015, 11:44 AM | #6 |
And then in the FR-S touring car classification, it also allows #15979 (Touring Committee) Place marker only T4: BRZ rear camber control arms
In T4, Subaru BRZ (2013-) and Scion FR-S (2013-), add the notes as follows: Eibach 4.10582.880 and SPC 67660 allowed. Front strut tower brace allowed |
03-24-2015, 08:47 AM | #7 |
I spoke to Jared who has a BRZ T4 yesterday and he has not been able to find any either. So let us know if you know anything out there.
I believe we can't use the Koni Sports because they have an inverted design |
03-24-2015, 11:53 AM | #8 |
Yea, I know it doesn't specifically state orientation, so could get away with Konis.
RaceCar:2013 Scion FR-S #986 NASA PTD || Tow:2011 Dodge Durango R/T Last edited by phastafrican; 03-24-2015 at 11:20 PM. |
03-24-2015, 02:11 PM | #9 |
Hmmm, perch locations may not change but threaded bodies are allowed?
Anyway, Koni Yellows are not inverted and are adjustable for damping. Bilstein B6 and B8 are inverted and non-adjustable. B14 are inverted with height adjustment. I don't think you could use Sportline springs with the B14s without an adapter lower perch, but I haven't really thought that through. Custom valved Bilstein B6 would be my choice. Maybe play with the bumpstops some too. - Andy |
The Following User Says Thank You to Racecomp Engineering For This Useful Post: | phastafrican (03-24-2015) |
03-24-2015, 04:28 PM | #10 |
Drives: '23 BRZ Limited
03-24-2015, 11:28 PM | #11 |
Took a second look at this today and realized I'd been stating the B14 when I meant B12. Email Bilstein and find out if the B12 sportline kit would work on 86. http://eibach.com/global/en/products.../b12-sportline
RaceCar:2013 Scion FR-S #986 NASA PTD || Tow:2011 Dodge Durango R/T Last edited by phastafrican; 03-24-2015 at 11:53 PM. |
03-24-2015, 11:57 PM | #12 |
Typically, yes. But given the importance of the void here, and the significant lack of alternatives, someone has to attempt an application to get a resultant rule enforced.
RaceCar:2013 Scion FR-S #986 NASA PTD || Tow:2011 Dodge Durango R/T |
03-25-2015, 07:01 AM | #13 | |
Thanks, I have an email into them. |
03-25-2015, 09:53 AM | #14 |
Drives: Between Cars
It may also be worth writing a letter to the SCCA for a clarification. Does "any non-adjustable shock absorber" mean non-adjustable now or non-adjustable ever?
Because you could technically have an adjustable shock fixed in one position. I've done that in autocross when a three way shock is not allowed. We would just epoxy the high-speed adjuster, after testing to find the happy place for the adjustment of course. Disabling the adjustment was fine for the other competitors, who are really all you have to worry about anyway. |
Similar Threads | ||||
SCCA Street Touring Legal Arms and Hardware, Now at FR Sport | FRSport.com | Brakes, Suspension, Chassis | 0 | 03-17-2015 09:19 PM |
Brand New Whiteline Sway bars 20mm adjustable front 16mm adjustable rear | deedz | Brakes, Suspension, Chassis | 11 | 03-17-2015 03:29 AM |
ohlins road and track shock absorbers | CyberFormula | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 31 | 11-11-2014 05:00 AM |
Where to find Customized Shock Absorbers | Yoniyama | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 22 | 09-30-2014 10:12 PM |
SCCA Proposes to Ban E-85 in Street Touring Classes | Tirewarmer | Tracking / Autocross / HPDE / Drifting | 31 | 01-04-2013 12:53 AM |
