Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) Everything related to the mechanical maintenance of the FR-S and BRZ |
Drives: Scion FR-S
oil level too high?
where should it be on the dipstick exactly? is this correct?
Drives: JAWS
Negatory. Should be at that top dot..you're at least a quart overfilled. Make sure you're on a perfectly level surface.
Drives: Scion FR-S
The Fail Boat
Drives: CWP S.B.
should be between the 2 dots
#5 | |
Proud of BOXER
Drives: Subaru Boxer
I've corrected that for you.
Per the owner's manual:
Drives: Firestorm 2013 FR-S
Note it says the LOWER of the levels you see is the actual level I have noticed that on my car one side must rub against the insertion tube because it seems to be completely coated way up high while the other side is where it should be. Make sure you're actually seeing the lower level. New oil is basically colorless so it can be really hard to see where the level is.
1995 BMW M3, 1973 DeTomaso Pantera, 1972 Dino 246GT, 1964 Fiat-Abarth 1000TC vintage racer
chicken tonight
Do NOT run overfilled. Crankshaft whips it up into a nice foamy mess which is then pumped throughout. Circulating bubbles is a quick way to destroy an engine.
The Following 2 Users Say Thank You to Ultramaroon For This Useful Post: | brandonblt2 (03-26-2015), Tcoat (03-23-2015) |
Drives: 2014 BRZ Limited
You really need to look at that dipstick carefully. I'm only looking at it on an old ipad, so I might not be seeing it correctly, but looks like there are breaks in the oil and dry spots on the dipstick. If so, then your oil is NOT at that higher level. When it dips into the oil pan, it's going to be wet from the true level all the down until the end of the dipstick.
The Following User Says Thank You to Itzed For This Useful Post: | Tcoat (03-26-2015) |
Drives: BR86
Struth, that oil level is way over !
The Following User Says Thank You to ZZT86 For This Useful Post: | Tcoat (03-26-2015) |
#10 |
Sweeper
1. Did you drain out everything?
2. How many quarts did you put in? 3. Are you on a level surface? |
The Following User Says Thank You to Koa For This Useful Post: | Tcoat (03-26-2015) |
#11 |
Drives: 2014 BRZ (SOLD)
Did he check it with the engine running?
Supercharged 2014 DGM Limited
The Following User Says Thank You to SpeedWi For This Useful Post: | Tcoat (03-26-2015) |
#12 | |
The Stig's African Cousin
Drives: 2014 wrb brz
The Following User Says Thank You to brandonblt2 For This Useful Post: | Tcoat (03-26-2015) |
#13 |
Drives: '16 WRX, CBR1000RR
if you're on flat ground, and the oil is warm (not hot) then you are quite overfilled.
If you did the change yourself, lesson learned. If a shop did it for you, go make heads roll.
Phantom ESC'd Build Thread (Retired):http://www.ft86club.com/forums/showthread.php?t=75293
LOC vs. High Level Input and Wiring | dcaranci13 | Electronics | Audio | NAV | Infotainment | 4 | 05-30-2014 09:58 AM |
My oil level was low! | FRSjeff | Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) | 22 | 12-15-2012 11:22 PM |
Another Level 86's | SportInjected | Great Lakes | 4 | 07-30-2012 10:13 PM |
