Old 03-09-2015, 01:29 PM   #1
scottxnizzle
scottxnizzle's Avatar
Drives: WRB BRZ
Can someone school me on camber bolts lol
Hey guys
so I recently bought some wheels and the coil overs I have:
wheels:
volk te37sl
18x9.5 offset +40 square set up
coil overs:
kwv3 with stock top mounts
I recently installed the wheels and noticed that the front wheels and popping out a little too much past the fender. I am afraid of hitting a really deep pot hole when driving and messing up the fender.
I was told to adjust the camber but I really don't want to buy camber plates and someone mentioned I can just use camber bolts.
Can someone help me decide on what to do?
Thanks!
scottxnizzle is offline   Reply With Quote
Old 03-09-2015, 01:33 PM   #2
adamg
Drives: brz
do some searching, seriously type in "ft86 camber bolts" into google. i can help if needed. I understand the internetz is pretty hard
you can use oem smaller bolts, spc, or whiteline bolts.You only need one set and they give you about up to -2 or so. You can also double up on them i think (use them for top and bottom) and get maybe another degree or two
Heres a thread
http://www.ft86club.com/forums/showthread.php?t=22201
and heres a thread
http://www.ft86club.com/forums/showthread.php?t=38616
and heres another thread
http://www.ft86club.com/forums/showthread.php?t=44660
and another ermahgawd
http://www.ft86club.com/forums/showthread.php?t=12854
adamg is offline   Reply With Quote
The Following 2 Users Say Thank You to adamg For This Useful Post:
Hyper4mance2k (03-09-2015), scottxnizzle (03-09-2015)
Old 03-09-2015, 01:34 PM   #3
8R6
8R6's Avatar
Drives: FRS
i think the kw's are also slotted in the bolt hole, so it can provide a bit extra. not sure though as i dont have kw's myself but i think ive seen pictures of them slotted.
8R6 is offline   Reply With Quote
The Following User Says Thank You to 8R6 For This Useful Post:
Old 03-09-2015, 01:38 PM   #4
finch1750
Undisputed El Presidente
finch1750's Avatar
Drives: Zenki 37J ZN6
If the upper hole is slotted DO NOT use spc or white line lobed bolts as they are more prone to slipping.
Old 03-09-2015, 01:50 PM   #5
scottxnizzle
Drives: WRB BRZ
so... what do you recommend?
Old 03-09-2015, 01:52 PM   #6
8R6
8R6's Avatar
Drives: FRS
if they're slotted, just have the alignment shop adjust using the current stock bolts already there.
if they're not slotted, just get camber bolts and have the alignment shop adjust with that.
Metabrz (03-09-2015)
Old 03-09-2015, 01:54 PM   #7
finch1750
finch1750's Avatar
You can use OEM crash bolts in the upper slot for a little extra. Did you get an alignment already where they maxed out front camber? Depending how much camber you need you may need camber plates even.
Old 03-09-2015, 01:56 PM   #8
scottxnizzle
Drives: WRB BRZ
I see, I am looking to get about -1.75 to -2 on the front. and no I have not gotten an alignment yet.
The Following User Says Thank You to scottxnizzle For This Useful Post:
halujeddo (05-01-2018)
Old 03-09-2015, 02:25 PM   #9
finch1750
finch1750's Avatar
It looks like the kW is slotted from what i read so you may even get what you want as is even. Try loosening the upper strut bolt and pushing in before tightening and see how close you get looks wise. If it isn't close then get crash bolts before taking it in.
Old 03-09-2015, 02:25 PM   #10
8R6
8R6's Avatar
Drives: FRS
you're not going to get that much negative camber with just camber bolts. unless the coilovers have a slotted hole, you're going to need camber plates up front.
Old 03-09-2015, 02:27 PM   #11
scottxnizzle
Drives: WRB BRZ
I'm not sure if Kwv3s have slotted holes
Old 03-09-2015, 03:04 PM   #12
Calum
That Guy
Drives: 2013 asphalt FRS MT
They are. Just raise and safely support the front of the car. Remove a wheel, loosen both lower strut bolts, push in on the top of the rotor and retighten the bolts, put the tire back on, and repeat on the other side. If that's enough you're done. If not, go to your dealership and buy a couple of camber bolt. Repeat the above process but add in adjusting the camber bolts so that you get as much camber as possible.
The Following User Says Thank You to Calum For This Useful Post:
Petah78 (05-15-2020)
Old 03-09-2015, 04:27 PM   #13
Hiros86
Hiros86's Avatar
Drives: whiteout FR-S
@scottxnizzle I got the spc camber bolts installed on mine and I like em. It was a cheap solution for only $25 and gave me an extra -1.75 camber and after alighnment I have -2 all the way around which is perfect.
Hiros86 is offline   Reply With Quote
Old 03-09-2015, 07:33 PM   #14
tracerit
Drives: '13 SSM BRZ Limited 6MT
is additional camber needed for the casual driver? or is it mostly to tuck in the wheel for a more pleasing appearance?
tracerit is offline   Reply With Quote
FS: SPC Camber Bolts bobsacamenoh Brakes, Suspension, Chassis 9 12-02-2014 11:44 PM
Camber bolts: Max camber tricks bfrank1972 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 6 06-03-2014 10:01 AM
*FREE alignment* When you get Front Camber Bolts and Rear Camber Arms Installed! Corner3garage Mechanical Maintenance and Tools 6 10-31-2013 03:40 PM
Question about adjustable LCA's vs Camber Plates vs Camber Bolts djdnz Suspension | Chassis | Brakes -- Sponsored by 949 Racing 13 03-27-2013 11:38 PM
