Old 06-06-2012, 03:22 PM   #1
mvhull
Drives: BRZ Limited SSM
Low MPG
I've got about 150 miles on the car, been driving mostly under 4k RPM since delivery. I've got about half a tank left and my average mpg is 18.6mpg.
What's up with that? I'm thinking that it should be considerably higher though most of the driving has been city driving.
mvhull is offline   Reply With Quote
Old 06-06-2012, 03:30 PM   #2
Grimlock
Grimlock's Avatar
Drives: BRZ and NA
Between
A) City Driving
B) Who knows what kind of gas the dealer put in?
C) Brand new, tight engine
D) Who knows how long the engine had been run and idling after it was filled and before you got it.
E) Have you spent a lot of time with the car idling while playing with the stereo/nav/other features?
I wouldn't worry about it. In mostly highway driving I've gotten between 28 and 30 mpg with the stick. But at least I know my car has 93 octane in it from the dealer.
Just drive it until you need to refill it. It should get better.
Grimlock is offline   Reply With Quote
Old 06-06-2012, 03:31 PM   #3
Longhorn248
Hook 'em
Longhorn248's Avatar
I'm at about 22mpg after a half tank and keeping it under 4k. Change the gauge info screen to the real time mpg setting and watch what happens when you keep your foot on the gas. When I push the pedal to the floor it's around 9 mpg, when I'm coasting on the highway it's around 127 mpg. It's acceleration that uses the most gas, so if you're doing a lot of stop and go city driving and not being conservative with the throttle that's probably what's keeping your mpg down. Conservative driving on the highway looks like it could average high 30's if you're real careful.
Longhorn248 is offline   Reply With Quote
Old 06-06-2012, 03:34 PM   #4
mvhull
Good stuff, thanks for the quick responses.
Car is awesome though, love driving it around. and I upgraded from a '99 Buick!
I've notice the real-time mpg rating jumps all over the place, from what i've read it will get better with more miles.
The Following User Says Thank You to mvhull For This Useful Post:
Zaku (06-07-2012)
Old 06-06-2012, 03:35 PM   #5
serialk11r
Drives: '06 AM V8V Coupe
I'd guess that the dealer was driving it pretty hard or idled it a lot, bringing down your average.
I'd ignore the real time mpg unless you're on the highway holding constant speed, otherwise it's pretty useless.
Old 06-06-2012, 03:43 PM   #6
Hawaiian
That guy
Hawaiian's Avatar
Drives: Ultramarine mt FR-S
If you take the car over 2500 rpm econ falls through the floor.
Resetting your avg will help with understanding how to maximize your mpg. Just press and hold the display button when avg mpg is displayed.
Old 06-06-2012, 03:46 PM   #7
Draco-REX
Corner Junkie
Draco-REX's Avatar
Drives: 13 BRZ, 11 STI, 99 RS
Ignore the first tank. Wait until you've put a tank or two of your own through it before you worry.
Old 06-06-2012, 03:50 PM   #8
BRZ4me
BRZ4me's Avatar
Drives: A4, Isuzu Vehicross
I'm averaging 25+MPG and rising with mostly city driving so far. My typical shift point is around 4000 rpm for city driving.
BRZ4me: Lightning Red Subaru BRZ
ETA: @ Home :happy0180:
BRZ4me is offline   Reply With Quote
Old 06-06-2012, 04:25 PM   #9
thill
I have read Consumer Reports for somtime when it comes to MPG studies and they find that most cars can achieve or beat the highway EPA ratings. City is harder to acheive and beat. Especially if you:
- Have a lot of lights and stop signs
- Take a lot of short trips
- Are driving in cold weather
- Drive aggressive
- Gas quality (high ethanol count) can effect your MPG
- Tire pressure can effect your MPG
Like others have said, your car is not broken in yet so I would not worry. But if you take lots of short trips, or deal with lots of traffic, stop lights, etc you may never hit the EPA city numbers.
Old 06-06-2012, 04:34 PM   #10
serialk11r
No it doesn't. Holding higher rpm than necessary will though.
Old 06-06-2012, 04:39 PM   #11
Lil Abner
Drives: 2013 FR-S, 6MT, Ultramarine
My first tank was terrible, too. On my second tank, average is around 33mpg. This is mostly highway, with some spirited driving under 4K.
Lil Abner is offline   Reply With Quote
Old 06-06-2012, 04:48 PM   #12
Hawaiian
That guy
Hawaiian's Avatar
One of the things I suspect is this car due to it's dual power bands is very thirsty in that first band range so it can hit near peak torque at lower rpm. playing with it and trying hard to lift my lead foot a little I can get about a 4mpg swing pretty easily.
I would imagine a solid ecu econ tune to soften that first torque peak for city drivers will save them at the pump. Add in a track day reflash for your driving days to open it up and everyone wins.
Old 06-06-2012, 04:57 PM   #13
When I got my FR-S, the computer said the avg mileage was 17.6 at 7 miles. I went with the dealer when it was filled up at that. At the end of the first tank I was getting 29.3MPG based on calculations, but the onboard computer still hadn't nearly caught up with that.
You may be just suffering from "early mileage lag". Like others have said, I wouldn't worry about it yet. Heck, even doing a rough calculation on what you say above (150miles at half a tank), you are probably getting closer to 30 than 20. Think about it. Based on my experience, when I fill up between 1/4 tank and empty I'm putting in around 10 gallons of fuel.
At half-tank, even if that means you've used 7 gallons would be doing better than 20.
Old 06-06-2012, 05:20 PM   #14
86'd
86'd's Avatar
Drives: 2012 WRX Sedan
Second tank will show better results. I wouldn't worry about it.
86'd is offline   Reply With Quote
