Drives: 14 FRS
FRS rally car
Hi guy I am new to the 86 community and forums for that matter. I would like to get someone to guide me in the right direction. I want to turn my 2014 FRS into a rally car. Nothing too crazy because it is my DD. It is mainly because I like the look and I like to go out into the desert to shoot. I am tired for asking people for rides out there and paying range fees. I have done research about what I need to do this but haven't found much. I have found rally FRS/BRS's but they don't say what parts they used or what to consider when building a car like that. So can anyone tell me what I need, venders, or maybe some sites that could help.
Good rally suspension is expensive. How bad are the roads we're talking about here?
- Andy |
Drives: 14 FRS
How expensive are we talking about? The roads aren't too bad but I think I will barely make it with a stock set up.
Drives: 2013 BRZ Limited
Setting some specific goals will help in guiding you to a solution that will work for you.
Do you need more clearance? Will an aggressive all-season work or is a off-road capable tire needed? Is there any need of underbody protection? From my time dealing with rallycross I can tell you that unless you are flying along roads at 80-90 mph, going off jumps, and in general putting the car through its paces then a decent set of struts and springs will work just fine. Biggest concern is if any lift is needed. I can see 1-2 inches as being the max for this car. You will then need new rear lower control arms and different camber bolts. As far as underbody protection goes, nobody makes a skid plate like those made for the Impreza. I would pick up a couple decent sized sheets of LDPE and figure out a way to fasten it to the bottom. Next obstacle is tires. You said desert so I'm guessing rocky/sandy terrain. Normal tires might not work. You are also going to want some flex. I am not sure if the Team Dynamics 15" wheels fit our car but I do know they fit the xv crosstek. All in all for a basic slight lift, protection, proper tires you will probably be spending upwards of $2-2.5k just to take the car off the road a bit.
2013 BRZ Limited 6MT
2014 Ram 1500 Quad Cab Black Ram - 8 speed with 3.21 gears 1994 Honda VFR750 - Two brothers 4-1 left side exit exhaust 1993 Honda CB750 Nighthawk |
Drives: 14 FRS
I think an aggressive all-season will work best for me since it's a DD. I do need a bit more clearance, I think an inch should be good. I would prefer underbody protection just to be safe.
I will not be going 90 down dirt roads. I haven't paid it off yet. Any suggestions on where I can get lca and camber bolts? Brands? I have searched for struts and springs but haven't found anything. I currently have 18" XXRs (531 I think) I also still have the stock rims. I figured I would need 15 or 16 inch rims. Thank you for your feedback. |
#8 | |
Drives: 14 FRS
Master Tuner
Drives: GT86 + Celica ST205 GT-4 WRC + MR2
http://www.toyota-motorsport.com/mot...ars/gt86-cs-r3
[ame]http://youtu.be/EDQlJnEWYwo[/ame] |
#10 | |
Drives: 14 FRS
#11 |
LOL those parts are $$$$. That car is meant as a turn-key professional rally car. It comes with a Reiger 3-way setup that is way more than what you want to spend.
I'd contact Nameless to see what they used. I think that car originally came from Australia and I'm not sure they had much to do with the suspension but they should know. I would just use the stock suspension and see how it goes. |
#12 |
Drives: 14 FRS
I'm not going to build the exact same car lol but something that will work for me. I have been searching for shocks, springs and something to give me more clearance but I haven't found any. I guess not too many people are doing it. I emailed nameless but haven't heard from them.
#13 |
You can also contact Ground Control, they could probably build you a coilover sleeve+spring setup with longer springs.
#14 |
Master Tuner
for suspension you can look at öhlins or bc racing
| Rally GT86 - The Little Car That Could - Lots of rally video and photos! | Circuit Motorsports | Tracking / Autocross / HPDE / Drifting | 48 | 10-12-2020 04:32 PM |
| Who is up for a Rally? | Thongpocket | Southeast | 12 | 11-04-2013 09:27 AM |
| Rally Armor on FRS? | JohnAyySays | Cosmetic Modification (Interior/Exterior/Lighting) | 23 | 03-18-2013 04:44 PM |
| Bullrun Rally? | trackmagic | Scion FR-S / Toyota 86 GT86 General Forum | 1 | 06-28-2012 01:51 PM |
| Cusco FRS/BRZ Rally Car | vividracing | FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum | 36 | 06-04-2012 11:42 PM |
