Old 12-01-2014, 07:49 PM   #1
RMP
Drives: 1992 Isuzu PuP, 2014 FR-S
AX Tire Pressures
I upgraded from stock tires to Hankook RS-3 V2's last month and have a ran a few AX events with them in C-Street. Noticing some heavy shoulder wear on my front tires due to, I think, the minimal camber with OEM crash bolts (~1.3deg). I have been running 36psi hot up front and was wondering if that seems a bit low based on other peoples experiences. I would appreciate any advice regarding
setup.
Mods:
Strano Front Bar
OEM Crash Bolts
Alignment:
front:
-1.3 camber
0 toe
rear:
camber (I forget, but it was left at stock settings)
1/16 total toe in
215/45/17 Hankook RS-3 V2
Front: 36psi Hot
Rear: 33psi Hot
Lots of shoulder wear up front. The car feels pretty neutral with a slight tendency to push during corner entry and midcorner at these settings.
RMP is offline   Reply With Quote
Old 12-01-2014, 11:47 PM   #2
knipple
Drives: 2013 Ultramarine Scion FR-S
I have run 37 psi hot in the front, however I haven't autocrossed a C Street legal FR-S on good tires. I have been running 255/40/17 tires (Rivals and ZII*) on 17" X 9" wide (offset +35). When I was on stock suspension, I had -1 degree of camber in the front, now I am over -2 degrees in the front.
I would suggest you use tire chalk to determine how far onto the sidewall you are rolling and add air as required to stop the rolling.
knipple is offline   Reply With Quote
The Following User Says Thank You to knipple For This Useful Post:
RMP (12-02-2014)
Old 12-02-2014, 11:12 AM   #3
renfield90
The Stig's German cousin
Different tire, but I run between 46-49 psi up front on Rivals depending on surface and conditions. I'm an oddball though and run higher than most other people on Rivals.
It's street class, you do what you gotta do to make it work.
Old 12-02-2014, 11:17 AM   #4
raul
Lap time enthusiast
raul's Avatar
Drives: Asphalt '13 FR-S 6MT
at least -3 camber in the front and -2 in the rear, along with 32 psi all around cold. Then bleed them as you run to keep them there. This is the consensus at least in our group of "fast guys" that run at nationals. These settings are for RS3s. If you start to get a bit of understeer, run the front half, to a full pound lower than the rear. However, don't expect tire pressures to completely fix deficiencies in your alignment. It simply won't happen. Also, is your ride height even all around? And where was it it measured from? Pinch weld? Ground to fender? Hub to Fender? The car needs a small amount of rake to make it work as well.
raul is offline   Reply With Quote
The Following User Says Thank You to raul For This Useful Post:
fstlane (12-02-2014)
Old 12-02-2014, 01:14 PM   #5
RMP
I'm currently running in CS so my camber is maxed out at around 1.3 using the crash bolts and I have to be at stock ride height.
I did some research on the SCCA forums and it seems that guys are recommending that the RS3's for 7" rims be run in the high 30's for cars that weigh about the same as ours. This was for the version 1 of the tire so I'm not sure if that is still valid for my version 2.
Old 12-02-2014, 01:21 PM   #6
wparsons
wparsons's Avatar
If you can't adjust camber, your only option is to add some pressure and see if you can stop the tire from rolling over without losing grip.
The ideal solution is a lot more camber, but pressure might help to a point.
flickr
Old 12-02-2014, 01:23 PM   #7
Kido1986
Dodging cones
Kido1986's Avatar
Drives: 2013 BRZ Limited, 93 Z28
V1s and V2s have the same sidewalls so pressures would be close.
I think I ran 38 hot when I was running them. This will always happen with RS3s on a camber limited car, even at ideal pressures. RS3s have soft sidewalls. This made slaloming slower than I'd like but they sweep great. I switched to Dunlops which slalom better but a little less grip in a sweeper. The much stiffer sidewalls on the Z2 make direction changes lightning quick compared to RS3s when you lack camber. Plus, they oversize well unlike Hankook. Downside is they cost a decent bit more.
Originally Posted by trevorovert View Post
Originally Posted by mrbillclintong View Post
If you guys spot any riced frs/brz post them here just for laughs no hating please.
Isn't there already a thread like this? It's called aggressive wheels or summat...
C Street Build/Progress Questions about C Street Autocrossing?
Kido1986 is offline   Reply With Quote
Old 12-02-2014, 01:29 PM   #8
raul
Lap time enthusiast
raul's Avatar
If you're in C Street I would use the Z2, not the RS3 (sorry, failed to read where you mentioned in the OP you were in C Street.)
Old 12-02-2014, 02:21 PM   #9
mla163
Overthinking it
Drives: BRZ in CS
If you don't know at all, start at 40 psi and bleed down at 4 psi intervals to 28 psi. See how the car feels and check times.
The best way is to use a pyrometer.
mla163 is offline   Reply With Quote
Old 12-02-2014, 08:19 PM   #10
Laloosh
Laloosh's Avatar
Drives: 2014 BRZ
I have 4-5 events on mine and they look great. 215/45/17 and I run them at 38f 36r hot.
Laloosh is offline   Reply With Quote
Tire Pressures mike the snake Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 1 04-21-2014 04:03 PM
Tire Pressures - What do YOU run? that_guy Tracking / Autocross / HPDE / Drifting 25 09-10-2013 11:20 PM
Stock tire pressures Ghost 86 Tracking / Autocross / HPDE / Drifting 10 05-16-2013 07:59 AM
Tyre Pressures/Fuel Consumption Vic_RSA AFRICA 11 12-11-2012 01:20 PM
Tyre pressures st162celica AUSTRALIA 6 08-08-2012 05:25 AM
