Issues | Warranty | Recalls / TSB Problems, issues, recalls, TSBs |
11-26-2014, 07:55 PM | #1 |
Drives: stock frs
loud knocking constant with engine speed
ok, so 1st post, hit 9k on accident on the intestate. Now the engine has lost power, engine is knocking loudly, and I think I can here a flapping noise too. Its the day b4 thanksgiving so im pretty sure I wont hear from the dealership until next week. No mods. So any thoughts?. Plz im upset and a little panicy. Do not want to drive my wifes veloster for the next however many weeks.
11-26-2014, 08:01 PM | #2 |
As much as I would like to reassure you it looks like you better resign yourself to driving the Veloster for a while.
There are a number of things you could have broke and none of them good. Have to ask (and I don't somebody else will) how did you manage to hit 9K?
11-26-2014, 08:17 PM | #3 |
Drives: 2018 BMW M240i
Did you downshift to a gear you were going to fast for?
Its the only way I can think our car could hit 9k unmodified. If so, uh oh, you may be screwed. |
11-26-2014, 08:28 PM | #4 |
Drives: Slow
Mechanical over rev aka "the money shift". You probably bent some exhaust valves. At that rpm it's possible the valves can float and the piston can give them a good ol smack. I would start thinking about the best way to approach the situation. You don't wanna be a jerk to the service department because they don't have to cover that kind of damage under warranty.
11-26-2014, 08:30 PM | #5 |
chicken tonight
Floated valves and bent at least one. At best valve job on one head.
edit: civdaddy beat me to it. |
11-26-2014, 08:34 PM | #6 |
Drives: Slow
What did you tell the service department so far about what happened?
11-26-2014, 09:11 PM | #7 |
In the event you did bend a valve or 16 you can bet the piston(s) have at least nicks at worst cracks. I know they get tossed out where I work if there is the slightest damage to the piston. Future failure point.
11-26-2014, 09:30 PM | #8 |
chicken tonight
Oh yeah, duh. I'm just going to take a seat over there and shut up now.
11-26-2014, 10:14 PM | #9 |
How did you hit 9K. That is a major Over-Rev. Miss a shift did we....
The Following User Says Thank You to jflogerzi For This Useful Post: | #maverick# (11-27-2014) |
11-26-2014, 10:26 PM | #10 |
in orbe terrum non visi
Drives: violent
I've seen this. I know a guy who did the same thing. Bent 4 valves, cracked a piston and bent a rod. Goodbye engine. At least short blocks are less then 3k from subaru. Labors is going to be much more than that though.
11-27-2014, 12:08 AM | #11 |
Sweeper
bite the bullet and buy Anthony's used engine off here and throw it in yourself .. http://www.ft86club.com/forums/showthread.php?t=77957
.. sorry, these guys covered everything. condolences op, hope you get it sorted |
11-27-2014, 09:50 AM | #12 |
Drives: stock frs
Yeah, it was cold. I had the heat on in traffic. My hands were sweating and slipped off the shifter in the middle of a 4th to 5th. So it went into 3rd instead.
11-27-2014, 09:54 AM | #13 |
Drives: stock frs
Im guessing warranty is non existant after they see data that says it hit 9k. But, my saving grace might be the fact that the warning light never came on. As a matter of fact the noise didnt start until like 10 minutes later. Then I got a low oil pressure light.
11-27-2014, 10:31 AM | #14 |
Drives: 2014 BRZ Limited, Black, Manual
I mis shifted a 2011 Scion tC that I once had. Took it to the dealership, and told them it was making weird noises. They took the top of the engine apart and knew exactly what I did to it. Cost me a little over 7k to have the dealership repair it. Needed a new short block. Floated the valves also. Had to go through the whole break-in process after the repairs.
However, I have heard of dealerships covering over revved engines. Obviously the customer had to lie about what he knew. But most of the time the dealership isn't stupid. For future reference... Palm the left side of the shifter knob when up shifting, Palm the right side of the shifter knob when down shifting. Less likely to hit the wrong gear. Best case scenario, you need new exhaust valves. $1,800 to $3,500 repair out the door. Worst case scenario, you bent/stretched some rods in the bottom end... ~$7,500 repair out the door. You may be required to have the dealership make the repairs to retain the powertrain warranty. Also, they're most likely to do the repairs right as their top mechanics will be handling this. Keep us updated on this whole process! Last edited by Kevinn; 11-27-2014 at 10:42 AM. |
Similar Threads | ||||
perrin catback resonated - loud enough or too loud? | theflathead | Engine, Exhaust, Transmission | 33 | 01-22-2018 05:46 PM |
Engine knocking after flash | Tenchi | Software Tuning | 10 | 09-25-2014 11:50 PM |
FR-S Loud Engine Noise | White0utFrs | Issues | Warranty | Recalls / TSB | 15 | 09-20-2013 08:28 PM |
Engine is making a loud ticking with Redline 0w20 | KevinBRZ | Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) | 2 | 07-29-2013 09:34 AM |
Engine Speed vs Vehicle Speed for 6MT | DetroitJake | Engine, Exhaust, Transmission | 22 | 04-27-2013 06:56 PM |
