Forced Induction Turbo, Supercharger, Methanol, Nitrous |
11-05-2014, 08:02 PM | #1 |
Drives: 2013 BRZ limited WRB
Wide Band AFR questions
I am going forced induction next month and have a couple questions regarding a wideband AFR gauge.
1. If I get an AFR gauge I would like to have a failsafe built into my tune based on the readings from the AFR sensor. I assume with a custom tune this is easily added? 2. I plan on installing the kit myself but have no way of welding the bung into the exhaust. Is this a pretty straightforward thing for most shops to do? how much would they charge for this? Thanks for the responses, I have learned a ton form reading through this forum.
92 240sx (sold), 03 350z (sold), 13 BRZ (AVO turbo)
11-05-2014, 08:17 PM | #2 |
Drives: 23 BRZ
1) yes tuner can do that based of the exhaust manifold sensor as well as your wideband - once you feed the signal back into the ECU.
2) AEM offers a 30 dollar or so kit to drill your own bung into the exhaust. Its a slip on device with no welding: http://www.aemelectronics.com/produc...-sensor-mounts I personally would get one welded. |
The Following User Says Thank You to rb6freak For This Useful Post: | kbogarto (11-05-2014) |
11-05-2014, 08:21 PM | #3 |
Drives: 2013 raven black fr-s
That no-weld bung was a good idea. I agree though, just get it welded in. The bung will probably cost around the same price e to have it welded in (I would think no more than 40-50, including the bung).
The Following User Says Thank You to bakerr6 For This Useful Post: | kbogarto (11-05-2014) |
11-06-2014, 01:51 AM | #4 |
Drives: Toyota 86
Just wondering if anyone has done the scaling work on the stock sensor at the rich end.
I was wondering and posted earlier today in mad_sb's thread: http://www.ft86club.com/forums/showthread.php?t=27793 |
11-06-2014, 02:23 AM | #5 | |
Drives: UK GT86
.: Stealth 86 :.
11-06-2014, 02:33 AM | #6 |
Senior Addict
Drives: 86 GT
I'm still confused about how to hook up a aftermarket wideband sensor. Can I just remove the rear O2 sensor and replace with the aftermarket one? How do you connect the wires?
11-06-2014, 11:57 AM | #7 | |
Drives: 23 BRZ
However, I know others that just feed their wideband signal into the secondary o2 sensor blue wire after snipping that wire. |
11-06-2014, 12:45 PM | #8 |
So if i ran an AFR failsafe through a custom tune off the stock O2 sensor I wouldn't need to do any wiring at all correct?
11-06-2014, 01:03 PM | #9 |
Drives: 23 BRZ
More info from this thread - I had forgotten all about it:
http://www.ft86club.com/forums/showthread.php?t=57902 Edit: And these: http://www.ft86club.com/forums/showthread.php?t=42764 http://www.ft86club.com/forums/showthread.php?t=49557 |
11-06-2014, 06:21 PM | #10 |
Senior Addict
Drives: 86 GT
But isn't the whole point of swapping out the stock rear sensor for the wideband sensor is because the aftermarket one gives more accurate reading?
If you are just hooking up the failsafe to the stock sensor then you're still basing your safety cut on inaccurate readings....no? |
11-06-2014, 06:37 PM | #11 |
Drives: Subaru BRZ
man you guys are confusing me even more.... I've been trying to research this. I assumed you can't just replace it with a stock one.
I was planning on getting the berk overpipe that has a bung welded into it. http://counterspacegarage.com/berk-t...-frs-gt86.html off topic: Although doing this with the stock headers would be completely useless because of the cats correct? I wanted to start off with a wideband on the Jackson racing SC w/ the carb tune.
2014 WRB BRZ
11-06-2014, 06:42 PM | #12 |
in orbe terrum non visi
Drives: violent
First off a wideband o2 must be before any cats.
Second you can run the signal from a wide band into the factory ecu (see previous links) but you need a good tuner and ecutek to build in a failsafe. The stock o2 is pretty good, but it's not perfect. I have an aem failsafe wired into my ecu.
The Following 2 Users Say Thank You to Reaper For This Useful Post: | kbogarto (11-06-2014), Xuningshen (11-06-2014) |
11-06-2014, 09:45 PM | #13 | |
Drives: 23 BRZ
If you're going to flash with the off the shelf carb tune then having a wideband would be for your own observation / logging. Adding a failsafe mechanism would require the tuners assistance. |
The Following User Says Thank You to rb6freak For This Useful Post: | Xuningshen (11-06-2014) |
11-06-2014, 10:34 PM | #14 | |
Drives: Subaru BRZ
2014 WRB BRZ
Similar Threads | ||||
PTUNING V Band Exhaust (PRICE DROP) | REVstylez | Mid-Atlantic | 1 | 10-01-2014 10:27 AM |
215 wide tire on 8.25 wide rim question | barabia | Tracking / Autocross / HPDE / Drifting | 15 | 06-30-2014 08:59 PM |
Perrin catback v-band's nut issues | Roarke | Engine, Exhaust, Transmission | 11 | 06-26-2014 01:59 PM |
FS: Ptuning V Band Dual/Single Exhaust | REVstylez | Engine, Exhaust, Bolt-Ons | 2 | 09-20-2013 04:10 AM |
Perrin 2.5" V-Band Clamp | BRZerk | Engine, Exhaust, Transmission | 5 | 08-27-2013 01:10 PM |
