Suspension | Chassis | Brakes -- Sponsored by 949 Racing Relating to suspension, chassis, and brakes. Sponsored by 949 Racing. |
09-10-2014, 11:37 AM | #1 |
Drives: '14 FRS
Alignment and Camber questions for Dummys(me)
I recently bought some Enkei RPF1s 17x9 +45 and Nitto NT05 235/40/17
Im getting them installed today and they are giving me an alignment They are also putting in my whiteline camber bolts for free during alignment Im just wondering what is an optimal Camber for my car? I DD it but also take it to the occational AutoX I was reading that -1.5 is a good start? please help lol
'14 Raven FRS - Toyota Badges - Helix Smoked Side Markers - K&N Drop-in - 3" Nameless Axleback 4" Mufflers - Tinted Back Windows - RCE Yellow Springs - Openflash Tablet - OLM HID Kit - Cusco strut bar - TRD Quickshifter - 17x9 Enkei RPF1's with Nitto NT05's
09-10-2014, 12:00 PM | #2 |
Zero your toe front and rear.
Go for -1.75 degrees front camber if they can get it. Rear isn't adjustable without extra parts but should be OKAY. Enjoy. - Andy |
The Following 2 Users Say Thank You to Racecomp Engineering For This Useful Post: | KonTheory (09-10-2014), omegared19 (09-11-2014) |
09-10-2014, 12:02 PM | #3 |
Drives: '14 FRS
Thanks, yeah im on RCE yellows as well, feels great..
and is it worth buying somerthing to adjust the rear?
09-10-2014, 12:05 PM | #4 | |
- Andy |
09-10-2014, 01:27 PM | #5 | ||
Serial Cone Killer
Drives: '14 BRZ - WRB Premium 6MT
The Following 3 Users Say Thank You to Turkish For This Useful Post: |
09-10-2014, 02:40 PM | #6 |
Normally I would say max out the camber you can get from the bolts, but with 17x9 +45 I doubt you'll have clearance between the wheel and lower spring seat (strut) for that without a spacer.
09-10-2014, 06:40 PM | #7 |
Drives: 2013 Ultramarine Scion FR-S
You definitely will not be able to run anymore camber with a 17X9 +45 (other than that gained by the drop springs) without spacers. I used to run 17X9 +35 on stock suspension and with -1 deg camber, the inner sidewall of my tires was millimeters from the spring perch.
09-10-2014, 09:35 PM | #8 | |
09-11-2014, 12:18 PM | #9 |
Drives: '14 FRS
I did go with 3mm spacers.. dunno how much that will help but from what Ive read its enough to stop any sort of rubbing
Also I have the cusco strut bar, is it necessary to preload the strut bar?
09-11-2014, 12:55 PM | #10 | |
Drives: White 2013 BRZ Limited 6MT
However I've also invested in all the adjustable parts I need for the rear. So remember it also depends on what you want to spend on your set up. |
09-11-2014, 01:05 PM | #11 | |
Drives: '14 FRS
Problem is I commute 80kms a day(50ish miles) so i dont want to go crazy, but I do like to autox.. so Im pretty much looking for the limit of camber that I can go to without wearing the tires out too much..
09-11-2014, 05:53 PM | #12 |
Toe kills tires, not camber. The combination of toe and camber is what gives camber a bad rep.
-2* with zero toe up front will be fine for commuting.
09-14-2014, 04:38 PM | #13 |
Drives: '14 FRS
So I took it in for the alignment, and the guy there told me they had no problem getting one side to -1.5 but the other side wouldnt go passed -1.2.. so he put them both to -1.2
does that seem right? also the rears are sitting at -2.2 and all I have done suspension wise is RCE Yellows
09-14-2014, 05:29 PM | #14 | |
i'm sorry, what?
Drives: Canada
it's possible. Usually people equalize at 1.3. 1.5 on one side and 1.2 on the other could mean a very slightly mis-aligned cross member, but well within the specs. remember that realistically 0.1 degrees is very very very small, it just seems large since everyone talk's so feverishly about it on suspension forums.
Similar Threads | ||||
*FREE alignment* with Purchase and install of Front Camber / SPL Rear Camber Arms! | Corner3garage | Southern California | 188 | 04-24-2015 01:10 PM |
*FREE alignment* When you get Front Camber Bolts and Rear Camber Arms Installed! | Corner3garage | Mechanical Maintenance and Tools | 6 | 10-31-2013 03:40 PM |
Rear Camber/Alignment Question | anewprelusion | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 1 | 09-25-2013 11:39 PM |
Alignment questions | Thongpocket | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 6 | 09-12-2013 01:50 PM |
Alignment/coilover questions | yomny | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 9 | 08-04-2012 04:48 PM |
