Tracking / Autocross / HPDE / Drifting What these cars were built for! |
09-09-2014, 01:03 PM | #1 |
Drives: 2015 FR-S
NASA TT - Lets talk about spending points!
This thread is for discussion of NASA Time Trial builds and how to spend the points for the best track times. There are countless ways to spend your points (please refer to http://www.nasaproracing.com/rules/t...sification.pdf for a list of the mods and points assigned them, and http://www.nasaproracing.com/rules/time_trial_rules.pdf for full TT rules) so lets bounce some ideas off each other and share experiences of what does and doesn't work.
I plan to build a car that will stay within the base TTD class. Please note I am no expert on the points system and if I am adding all of this up incorrectly please point out any discrepancies. I feel that power mods, fairly stock weight, and sticky tires will yield the best times personally so my currently planned build is as follows: A - Tires Toyo RR or lower for a max +9 points Running a 235 vs the class max 245 is -1 point C - Engine Adding a CAI +1 Aftermarket header +2 Aftermarket exhaust +2 Upgraded cats +1 Reflash to clean up that torque curve +0 E - Suspension Coilovers, aftermarket dampers and springs +3 & +2 Camber plates +0 I know there is a forum member in AZ with this basic setup doing very well, and it was pretty much the exact setup I was planning to try before we met. So anyway chime in with your NASA TT setup, or discussion on if spending points on A is better than B, etc.
The Following User Says Thank You to JustDoItMikey For This Useful Post: | ja1217 (09-09-2014) |
09-09-2014, 01:39 PM | #2 |
Drives: 2013 Raven Scion FR-S
Hal in AZ is running a different set up now He has an E85 tune and dyno'd 194hp.
225 A6 +9, Muffler delete +2 RCE TII +5 3pts for weight.
Emmanuel Baako: NASA-Southeast Race Control & NASA Florida Race Director
RaceCar:2013 Scion FR-S #986 NASA PTD || Tow:2011 Dodge Durango R/T |
09-09-2014, 01:41 PM | #3 |
Drives: 2004 Toyota RAV-4 5M
So here's my current set up. I'm usually pretty competitive, but it always depends on who shows up. My last event I came in 2nd (Summit Point Main) but was 2 seconds off the pace (dang E36's, guy set the track record), but the previous event I won at VIR.
Current Total: 16 points Tires (6 Total): Hoosier R6: +10 225/45R17: -4 Suspension (8 Total): Ohlins Road&Track: +8 (Shaft > 40mm = +5, inverted front struts = +1, aftermarket springs = +2) Brakes (2 Total): Essex AP Racing Sprint BBK: +2 Free Mods (0 points): DSS CF Drive shaft ACT Prolite clutch/flywheel Perrin Engine Mounts Shorai 5lbs. battery Competition Weight: 2885 (need to have at least 1/3 tank of gas and I am carrying 70lbs. of ballast in the spare tire well) WHP (Dynojet): 185 Next year I plan on adding more power by getting a header and high flow cat downpipe (or where ever that 2nd cat is) and I'll probably move to Maxxis RC-1's for there very generous contingency plans. It's probably still not a completely optimal setup, but I did a fair amount of stuff before even considering doing TT. Theoretical Fastest Build (19 points total): Tires (9 points): 225/40R17 Hoosier A6: 9 points (although with the A6 being replaced with the A7, which will be a higher point cost, currently its at 22!!!) Suspension (5 points): Aftermarket shocks/dampers: +3 Aftermarket springs: +2 Engine (5 points): Header: +2 Exhaust: +2 Cats: +1 Then you throw in as many free mods (bushings, etc) as you can and run right at the power/weight limit for the class. Also, as a side note, all aftermarket headers for the FR-S/BRZ will cost 5 points. The definition of a header, according to the rules, is just the primaries. Since all aftermarket headers I've seen for our car include primaries, remove/upgrade the cat, and will modify piping going to/from that cat they are seen as 5 point modifications. See http://nasaforums.com/viewtopic.php?...119352#p467349 |
09-09-2014, 01:44 PM | #4 |
Drives: 2015 FR-S
Ya we spent lots of time with Hal at nationals and asked him alllllll sorts of questions. Great guy, so far all the 86 guys we have met have been great... I think that basic combo is the way for us to go though, get power and torque up to max, sticky tires, and suspension stuff. But if we get hit with a 7 point penalty for 2015 its really going to change things and we are more looking at tires and suspension and thats all....
09-09-2014, 01:50 PM | #5 | |
Drives: 2015 FR-S
I assume you are tuned? Are you just tuned on pump 93 or 91? I guess I need to do more research on tuning the stock car as I thought we couldn't make much more power and eliminate the torque dip without headers and exhaust. If we can thats awesome, will be doing that asap. And it looks like we both came up with the same solution for what should be the fastest car given the points. I guess only hard track time will tell now. But gotta do that tuning research, maybe I can get tuned before Road Atl in December.
09-09-2014, 01:55 PM | #6 |
The torque dip won't be eliminated... But you can tune to max hp allowed in class on E85. To get to max hp on 93, you'll need the 5pts for headers/cats/exhaust.
Keep in mind, any tune needs to have a margin of variance. So even though 199 is what gets max, you probably don't want to give some room up top, or have the option to add weight in some way, either ballast or fuel. A DQ for cheating is worse than a 2nd place for being a few hp under.
09-09-2014, 02:00 PM | #7 |
Has that been discussed at all? If so, I haven't seen it. I was actually going to see if I couldn't argue getting our base competition weight back to 2775 since the only FR-S at Nationals East was 3 seconds (I think) off the pace of 2 E36's, both of whom I will be battling at VIR in October.
09-09-2014, 02:01 PM | #8 | |
The Following User Says Thank You to ja1217 For This Useful Post: | JustDoItMikey (09-09-2014) |
09-09-2014, 02:04 PM | #9 | |
Drives: 2015 FR-S
Oh ya I saw too many DQ's at Nationals, do not want. But I dont think E85 is a realistic option for me at this point as much as I want it to be. So I am looking to stay within the confines of 93, at least until I can figure out a way to make E85 possible. So that means all I am going to do that are points related, at least until I know the 2015 points system, is tires, coilovers and a tune. Hey thats less money I have to scrounge up!
09-09-2014, 02:04 PM | #10 | |
09-09-2014, 02:05 PM | #11 |
Drives: 2015 FR-S
Did that help out the torque dip a good bit?
09-09-2014, 02:08 PM | #12 |
09-09-2014, 02:15 PM | #13 |
Drives: 2015 FR-S
Well it looks like it at least made it climb back out faster, better than not tuning either way I suppose. We just need more E85 available at the track so we dont have to byoE85
09-09-2014, 02:28 PM | #14 | |
There's no way to win that battle. The FR-S is 2 secs faster at Roebling so it's a trade off. These 2 tracks are heavily biased to one side or the other. VIR next year will suck... long straights will favor the high HP. Might need to build for TTC if you want to win - Hal and I are both considering it. I have more PTD racers than PTC racers so right now, I'm not motivated to do it, plus would rather spend the money on sticker R7s and modifications to my trailer to transport 2 additional sets of tires and 4 fuel jugs.
Similar Threads | ||||
Lets talk lug nuts | Ibanezboy21 | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 22 | 06-23-2014 03:42 PM |
Lets talk tires... | frs10 | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 34 | 10-04-2013 05:21 AM |
Lets talk about clutches | charged86 | Engine, Exhaust, Transmission | 26 | 08-30-2013 04:13 PM |
Lets talk exclusivity | whitejdm | BRZ First-Gen (2012+) -- General Topics | 33 | 02-15-2012 01:17 PM |
Lets talk weight | KaliKev | Scion FR-S / Toyota 86 GT86 General Forum | 63 | 09-12-2011 12:05 AM |
