Forced Induction Turbo, Supercharger, Methanol, Nitrous |
08-10-2014, 12:39 AM | #1 |
Drives: 2014 Toyota FRS
Another noob question on turbos....
So I was all set to order the greddy turbo kit for the frs until I found out you had to trim the crash beam...upsetting because safety is a concern. Fullblown kit seems like a viable option however I read in a post something about drilling and moving the crash beam. That sounds just as bad to move it from its original position. What would you recommend? I want safety...A daily driver and I want air conditioning lol...havnt looked into gas options but I live in southern California so I use 91.
Avo kit seemed like a viable option but I hear a lot of complaints about leaks... Also... I know there's a crash beam replacement...but it's not tested and I don't trust that option... Thanks!! Last edited by Celigts; 08-10-2014 at 02:01 AM. |
08-10-2014, 12:55 AM | #2 |
Drives: 2013 Subaru BRZ
Ptuning doesn't require cutting anything.
The Following User Says Thank You to mikepaul21 For This Useful Post: | lucid215 (08-10-2014) |
08-10-2014, 01:54 AM | #3 |
Village Idiot
Drives: '13 FR-S Ultramarine Manual
Noon? You posted at 9:30pm... Come on now. Haha.
Aren't the front crash beams for 5mph crashes anyways? |
08-10-2014, 02:01 AM | #4 | |
And no the crash beam helps transfer the crash to the rest of the car. W.o it the front gets smashed in...hurting more than just the engine. At least from what I gather. And I'll look into ptuning kit. |
08-10-2014, 02:50 AM | #5 |
Does the ptuning kit remove the air conditioning??
I'm guessing no but...The boost Guage in the vent throws me. Also I see the kits $5700...yet doesn't come with headers...they say stock header is fine...but for 5700 vs the greddy kit let's say which is MSRP $5200 (can get cheaper around 4300) what is gained?? It's nearly 1.2k more and no headers? Again...I'm noob and learning. There must be a major upside I'm too retarded to comprehend. Thanks in advance Last edited by Celigts; 08-10-2014 at 03:06 AM. |
08-10-2014, 09:36 AM | #6 |
No rice, no life
Drives: 2013 Asphalt FR-S
The P&L kit doesn't require any cutting either.
AFAIK, all turbo kits keep the AC compressor. Some kits require that you remove/modify the windshield wiper fluid reservoir though. |
08-10-2014, 09:49 AM | #7 | |
Seems Legit
Drives: Toyota
Indeed, the PTUNING kit doesn't come with a header and you can use the stock or whatever header you want but it does come with a turbo that is vastly superior than the one Greddy includes. It's low mounted which keeps the heat out of the already toasty engine bay. All of the underneath body panels stay in-tact. Furthermore, the design of the PTUNING kit with the testing they've done and the reviews it has speaks volumes to the quality of the system. Now, PTUNING and Greddy are not your only options in regards to systems that don't modify your crash bar. You can do more searching on them. If you're looking for bang for the buck, the Greddy kit shouldn't even be on your list. PTUNINGs kit removes the washer bottle, which is an issue for some so look at your options there. No the system does not remove the AC. The gauge you see is either an ATI vent pod with an AEM gauge in it, which still allows are to flow around the gauge or the P3Cars OBDII Vent Gauge, which also allows air to flow around it. Also you're in California, don't you have CARB testing? Shouldn't you be looking for a system that's CARB legal? I'm not from Cali but i'm just throwing some concerns out there. Who's going to do your tuning if you decide to go with a system that's not CARB legal in Cali? Have you spoken to him/her yet? What is the tuner's comfort level with the FA20 platform?
No build thread. I don't want to be reminded of how much money I spent.
[insert profound quote here] |
The Following User Says Thank You to ecko04 For This Useful Post: | lucid215 (08-10-2014) |
08-10-2014, 10:45 AM | #8 |
Also just a thought, if you ever want to get more power out of your car it would suck to have to replace your turbo. The Ptuning kit comes with a GT3076R which has great response time with the setup they have made and is large enough to satisfy all reasonable power expectations if you get bored in the future. Just the price of the turbo alone is $1,200. Also you can get whatever header style you want in the future.
08-10-2014, 12:47 PM | #9 | |
As for the gt30 turbo...I believe it's a bit big...was going to go with a gt28 with fullblowns kit however the moving of the crash beam has me too concerned... I'm currently awaiting arrival of my aimgain front/rear/spoiler and greddy v1 sideskirts and fenders next is rims/tires then turbo kit. Sooooo I have about 2-3 months before I make my final decision on the turbo kit. I've been confused on what I'll go with. Greddy I thought was a for sure winner...now I'm leaning in the PTUNING direction...time will tell. |
08-10-2014, 08:15 PM | #10 |
Go-Kart Enthusiast
Drives: Toyota Scion FRS
Why not buy an aftermarket crash beam to replace the one you drill? sBD offers one to folks that don't want a crash beam that has been hacked
FRS
Current mods: K&N air filter, OFT, OFH, berk high flow cat front pipe, Q300 exhaust, lighter wheels |
08-10-2014, 08:27 PM | #11 |
The "moving" of the crash beam is just a 1/4" lift up not a huge relocation. I ended up replacing the crash beam so I could run the piping different but I believe most kits that keep the stock crash bar will require this lifting
The Following User Says Thank You to Dipstik-sportech For This Useful Post: | Celigts (08-10-2014) |
08-10-2014, 08:27 PM | #12 |
Seems Legit
Drives: Toyota
Have any of the companies manufacturing the above referenced crash beams release any data attesting to the fact that they will fare the same, if not better than the OEM beam (or even a "notched" beam), in crash tests? I don't want to derail the thread but I figured I would ask.
The Following User Says Thank You to ecko04 For This Useful Post: | Celigts (08-10-2014) |
08-10-2014, 08:49 PM | #13 | |
Go-Kart Enthusiast
FRS
The Following User Says Thank You to Boofneenee For This Useful Post: | Celigts (08-10-2014) |
08-10-2014, 09:00 PM | #14 | |
Junior
Drives: a car
Similar Threads | ||||
Small Turbos? | SamS | Forced Induction | 30 | 11-18-2013 11:00 AM |
WRX/STI turbos on FA20 | mrk1 | Forced Induction | 9 | 10-04-2013 08:44 AM |
Hodges Subaru has BRZ starting at Noon on Tuesday, March 6 | markitect | Great Lakes | 28 | 03-12-2013 10:51 PM |
Portland Auto Show anyone? - I'll be there at noon | stockysnail | Northwest | 1 | 01-22-2013 10:29 PM |
snails and turbos | carbonBLUE | Off-Topic Lounge [WARNING: NO POLITICS] | 10 | 12-27-2012 04:44 PM |
