Engine, Exhaust, Transmission Discuss the FR-S | 86 | BRZ engine, exhaust and drivetrain. |
Drives: '03 AS Evo 8, '06 GG Evo 9
FRS/BRZ Bottom End
Just looking into what the motor is setup with it has an 86mm bore x 86mm stoke @ 12.5 compression. Now with that funny thing is an Evo X has an 86x86 setup too for with kits of a 9.0 compression. I need a little bit more time to look up the motor/block design to determine what size the main and rod are on the crank so we can possibly just take some rods and pistons directly from an evo and fit them in.
If anyone has any info please chime in. |
MODERATOR-SAMA
Drives: Swagtron Scooter
oh god....where to start with this...
asymetrical rods + Piston plates designed for DI your going to run into a shit ton of problems attempting to use any parts from other vehicles. as the FA20 is 1. unconventional..and 2. a brand new design.
First 86 Driver Baby!
Drives: FR-S, Flex
I think what he's trying to say is no they won't work, completely different engine designs. I wish it was that easy, though. It will be easier to wait for aftermarket rods/pistons.
I understand what he is saying..just jumped into posting an gettin a little over excited I guess an posting before fully thinking about it...ya know?
Drives: FR-S, Flex
No worries. We're all excited to see what this car is capable of achieving.
#6 | |
Drives: Scion FRS
OP: No worries, Lower compression pistons and high strength rods are in the works. I've already got the ball rolling and will have some in my hot little hands asap. I usually don't like saying things before I've tested them, but darnit,! I'm too excited! Ishii |
Pro Subie Engine Nerd
Drives: empty spot for an FR-S/BRZ
I'm in the same boat with my internals...I'm in a rush to get them done BUT at the same time, there's no real EM solution yet.
So onward with simulation. |
#8 | ||
Drives: Hydra EMS Powered FRS Raven Black
I'm sure if you ditch the direct injection and run the standard injectors only then you could probably get away with it. I know I'm not looking to step back in technology and would much prefer to develop and engine program that takes advantage of new technology. Quote:
Thanks, Phil Grabow |
#9 | |
Drives: 13 FR-S, 00 Spyder&Celica, 08 Tundr
#10 | |
I'm working with a few of my resources/colleagues in the industry to work on a GDI solution. It would be a shame to run a full EMS and be capped on power because of pump/injector size limitations. I'd actually like to work with you guys if you're looking for some input. Actually need to call you anyway because I think I lost my harness for my Hydra...tossing it back into my bugeye -Micah McMahan 'Homemade WRX' |
#11 |
Yeah I pushed them to ensure the direct injection was utilized but it will take a fair amount of programming changes on the current Hydra EMS platform. We will have our work cut out this weekend, thats for sure.
With that said I'm exited knowing we'll have a well developed standalone with CAN fuctions, traction control, and a huge amount of switchable maps for E85, water injection, and the ability to tune for any engine strategy builders choose. |
#12 |
turbo FT-86
Drives: ft-86
guys CP is making rods and piston kits for NA and Turbo setup.
