Cosmetic Modification (Interior/Exterior/Lighting) Discussions about cosmetic mods. |
08-07-2014, 12:42 PM | #1 |
More Overpriced Junk | Tom's Tails
The deal is I had OEM tails leak twice. Had them replaced and most recent TSB done and they did not leak after.
So, you know I had to screw around and replace them with the USDM Toms. Followed TSB and made sure they were tightened properly (basically not tightened.) Well just look at them. Junk @FT-86 SpeedFactory
The Following User Says Thank You to Dezoris For This Useful Post: | aakash (08-07-2014) |
08-07-2014, 01:16 PM | #2 | |
Drives: FRS
Fix the flaw for 99 cents and all is well. CERBERUS |
08-07-2014, 01:39 PM | #3 |
Come fix my car then, whats the problem?
08-07-2014, 02:09 PM | #4 |
Regional Moderator
Drives: 13' ZN6 / 00' AP1 / 20' A90/ 15 EVO
08-07-2014, 02:32 PM | #5 |
Tom's came with new gaskets, is there some secret to installing foam gaskets and tail lights for this car that don't apply to every other car on earth?
08-07-2014, 02:47 PM | #6 |
Drives: LS Swapped BRZ
get some of that sticky spray from the infomercials and wahla, fixed! If it can make a screen door as the bottom of the boat work, I'm sure it can keep some condensation out of some tail lights
The Following 3 Users Say Thank You to JesseE For This Useful Post: |
08-07-2014, 02:48 PM | #7 |
Hmmm I've actually not seen very many leaky taillights lately, but California is also in a drought, so I'm useless here
The Following User Says Thank You to CSG Mike For This Useful Post: | continuecrushing (08-07-2014) |
08-07-2014, 02:54 PM | #8 |
The answer then is to move to California or should I bottle the water and send it to you?
The Following 3 Users Say Thank You to Dezoris For This Useful Post: |
08-07-2014, 03:08 PM | #9 |
Drives: BRZ limited GBS
i think all tail gaskets for this car need to be glued to the tails with 3m weather adhesive or whatever you can find
08-07-2014, 03:15 PM | #10 |
Amateur Drifter
Drives: '13 FRS
I would gladly take buy them off of you if you are fed up
i like 2 drift
https://www.youtube.com/channel/UCvo...pU-TkCZZcTh61g |
08-07-2014, 03:17 PM | #11 |
Living the dream
Drives: Fensport AVO Turbo GT86
Well, for what it is worth, I have had the EU spec TOMs on my car for about six months now, and there is absolutely no condensation / leak issue. This is despite the lovely weather we have here in the UK, and the fact I wash my car at least once a week, very often with a pressure washer.
Having said that, I had absolutely no problems with my OEM lights either. |
The Following User Says Thank You to Pitman For This Useful Post: | Sideways? (08-07-2014) |
08-07-2014, 03:24 PM | #12 | |
08-07-2014, 04:05 PM | #13 |
Drives: SWP Subaru BRZ
no issues on my TOM's and I have had them on the car for a year in Nebraska. I knew the OEM gaskets sucked and the TOM's ones looked better than the OEM, proved correct. I have the USDM wired JDM ones though with the amber turn signals.
2013 SWP BRZ full STi Lip kit installed. Tons of other mods from interior to exterior. One of the cleanest BRZ's around in the midwest! Enjoy the build thread below. Full of pictures, exhaust clips, garage shots, and walk around video encasing its beauty. |
08-07-2014, 04:11 PM | #14 |
Thupercharged
When I took my OEM tails off I remember doing some metal bending, very minor... I think it was around the bolt holes, the tightening done during the build at the factory deformed the metal slightly and it needed some tweaking
I'm going to check mine right now actually, there was a pretty bad rain storm a few days ago
2013 FRS
Vortech V3 11psi Revworks UEL - PLM Overpipe - MOTIV catted frontpipe - Invidia Q300 2019 Series.Grey STI - Stage1+ SF |
Tags |
jdm condensation, op has downs |
Similar Threads | ||||
Junk in the Trunk | Dadhawk | Scion FR-S / Toyota 86 GT86 General Forum | 347 | 04-29-2022 05:25 PM |
Does the Audi S3 make the WRX STI look overpriced? | WolfpackS2k | Other Vehicles & General Automotive Discussions | 90 | 09-09-2014 09:37 AM |
Trade: Black Spyder V1 Tails for Tom's Tails | Cross | Exterior Parts (Aero, Lighting, Etc.) | 3 | 07-05-2014 04:19 PM |
Junk in the Trunk: | nataku | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 8 | 01-04-2013 06:17 PM |
How much junk in that trunk? | Tobz | Scion FR-S / Toyota 86 GT86 General Forum | 8 | 07-21-2012 10:13 PM |
