Old 07-19-2014, 07:37 PM   #1
boomslang
Drives: Toyota
Removing reverse lockout pin without a hammer...
Not wanting to bash on my shifter with a hammer, I found a better way to remove the reverse lockout pin.
Just use a 3/32" punch along with a carpenter's bar clamp. Lay a blanket around your console area to protect it and use the clamp to squeeze the punch against the reverse lockout pin. The pin slides out on the first try and there's no drama whatsoever.
You will need to offset the clamp just a tad so you aren't pushing the pin into the opposite side's clamp face.
boomslang is offline   Reply With Quote
The Following 3 Users Say Thank You to boomslang For This Useful Post:
Phaedrus29 (09-03-2014), Pitman (07-20-2014), Sony (07-19-2014)
Old 09-08-2014, 04:54 PM   #2
Phaedrus29
Phaedrus29's Avatar
Drives: 2013 Subaru BRZ
Just installed my Raceseng reverse lockout. I used the "Irwin 6-in Next Gen Bar Clamp" from Lowes. I really couldn't get the pin moving by offsetting the clamp...maybe I wasn't doing it right or maybe the clamp I bought wasn't heavy duty enough. I ended up just holding the clamp straight and pushing the pin out into the rubber clamp face. Once it got started it was easy to tap out the rest of the way with a hammer. Perhaps not as elegant as boomslang described, but it worked fine and made it much easier than using only a hammer.
Oh, the Craftsman punch I purchased also bent really easily...back to Sears it goes.
Phaedrus29 is offline   Reply With Quote
Old 09-08-2014, 05:00 PM   #3
DJCarbine
Thupercharged
DJCarbine's Avatar
I'll have to try this if/when I do my reverse lockout.
You wouldn't happen to be a part of boomslang fabrication would you?
2013 FRS
Vortech V3 11psi
Old 07-21-2016, 01:50 PM   #4
Kronos
Kronos's Avatar
Drives: Asphalt FR-S MT
Have a problem here, I have the red raceseng lockout installed and I'm trying to swap in out to the gubmetal color I just received. However there aren't two holes for the pin like on the stock lockout, so there is no way for me to hammer out the pin to remove the lockout. Does anyone know another way of removing it?
Kronos is offline   Reply With Quote
Old 07-21-2016, 02:19 PM   #5
Pointmutation
Pointmutation's Avatar
Drives: 2016 ZC6
Isn't the Racesend reverse lockouts just screwed in?? Just use a hex key to unscrew the bolt from the one side. Did you install the current raceseng r-lock with a pin instead?
Pointmutation is offline   Reply With Quote
Old 07-21-2016, 02:38 PM   #6
JoeC
Drives: Subaru BRZ Limited
is this just a cosmetic upgrade?
JoeC is offline   Reply With Quote
Old 07-21-2016, 03:39 PM   #7
Kronos
Kronos's Avatar
Oh my shit you're right! It's been installed so long I completely forgot it's not a pin haha
Thank you for reminding me 👍
The Following User Says Thank You to Kronos For This Useful Post:
Norville Rogers (07-21-2016)
Old 07-21-2016, 04:48 PM   #8
JohnJuan
JohnJuan's Avatar
Drives: 2013 FR-S, Hot Lava; 2012 Z1000 CBO
Essentially. It also changes your contact point from plastic to milled aluminum, which feels pretty nice.
JohnJuan is offline   Reply With Quote
The Following User Says Thank You to JohnJuan For This Useful Post:
JoeC (07-21-2016)
Old 07-21-2016, 05:19 PM   #9
Capt Spaulding
Persona Non Grata
Capt Spaulding's Avatar
Drives: '15 BRZ (WRB)
Whew. Good thing you caught it before you started in with the hammer.
Slow is smooth, and smooth is fast
Capt Spaulding is offline   Reply With Quote
Old 07-21-2016, 06:43 PM   #10
JoeC
I thought perhaps it eliminated the actual lockout which I find mildly annoying on the rare occasion I need to move into reverse real quick.
$80 is an impressive amount of coin for a small piece of milled aluminum that provides little to no advantage over the original part. I'm not knocking anyone who appreciates it for what it is. I guess I'm just surprised they can ask that kind of money for it.
Old 07-21-2016, 08:55 PM   #11
Pointmutation
Drives: 2016 ZC6
It's a visual and tactile mod for the interior that I see whenever I'm in my car and interact with every time I shift into reverse. More worth it than an exterior mod for me.
Eliminating the lockout I can imagine myself accidentally reversing instead of going forward, James May style. Haha.
The Following User Says Thank You to Pointmutation For This Useful Post:
JoeC (07-21-2016)
Old 07-22-2016, 10:45 AM   #12
JohnJuan
JohnJuan's Avatar
I have a friend who shoved a Mini Cooper into reverse during an autocross event. Apparently, it resulted in smoke and a nasty sound. I think lockouts are good. I'm keeping mine.
Old 07-22-2016, 01:11 PM   #13
BRZerk
Some guy in a white car
BRZerk's Avatar
Drives: 2013 SWP BRZ Limited
used a hammer. you don't have to crush it. a light tap does the job.
2013 Subaru BRZ Limited 6MT - Satin White Pearl
BRZerk is offline   Reply With Quote
Reverse lockout rattle fix clintavo DIY (Do-It-Yourself) Guides 24 06-17-2020 12:27 PM
FS: Beatrush Reverse Lockout TONY_BRZ Interior Parts (Incl. Lighting) 10 05-15-2015 12:04 PM
Reverse lockout? MrMarinakos Cosmetic Modification (Interior/Exterior/Lighting) 0 04-28-2014 09:47 PM
Beatrush Reverse Lockout - NEW red jack43 Interior Parts (Incl. Lighting) 6 03-22-2014 03:10 AM
Reverse lockout vibration SubaSteve Issues | Warranty | Recalls / TSB 4 03-23-2013 02:26 PM
