Old 06-21-2014, 02:49 AM   #1
rice_classic
rice_classic's Avatar
Drives: Nevermorange FRS
I :heart: double A-Arms. :)
So I was swapping the front springs on the race car and while I had the shock/spring out but the rest still in place I decided to fire up the camera with my camber gauge attached.
Very cool. Ignore the caster setting on the gauge.. I neither adjust nor measure caster on this car. That setting is OEM.
[ame="http://vimeo.com/98792402"]suspension travel on Vimeo[/ame]
SCCA T4 - FRS
The Following 7 Users Say Thank You to rice_classic For This Useful Post:
7thgear (06-21-2014), ayau (06-21-2014), CSG Mike (06-21-2014), Dezoris (06-22-2014), emutcfut (06-25-2014), Racecomp Engineering (06-23-2014), wparsons (06-22-2014)
Old 06-21-2014, 06:41 PM   #2
ayau
Drives: Some rust bucket
IMO, front double wishbone suspension plays an important role for FWD cars because it's what drives the wheels. If your CRX was RWD and had MacPherson front struts, I wonder if it would still set similar lap times.
Old 06-21-2014, 09:41 PM   #3
rice_classic
That sentence right there is TRUTH! It's also why I won't buy a modern Honda.
I don't know on the 2nd part because I tend to think I'll be fast regardless of what you put me in.
SCCA T4 - FRS
The Following User Says Thank You to rice_classic For This Useful Post:
SirBrass (06-23-2014)
Old 06-21-2014, 11:31 PM   #4
ayau
Similarly, I think that's why Porsche and BMW can produce fast cars because they have multi-link RWD (increase in negative camber under compression).
Makes me wonder what the compression camber rate is on my ITR.
Btw, are you using adjustable upper A-arm to set your negative camber? If so, which brand/model?
Old 06-22-2014, 02:31 PM   #5
fooddude
Drives: 04 Toyota Tacoma Prerunner Reg Cab
Going from working on many EGs/EFs to an S13 back in the day boggled my mind when I replaced the S13's springs/shocks for the first time. I thought to myself, "hmmm..interesting. Why does this S13 have such an archaic looking suspension? I thought it was going to be awesome, from all the hype about it. Is this what domestic cars(that are known/rumored to not handle well) have too? I think so. I miss my Honda."
fooddude is offline   Reply With Quote
Old 06-23-2014, 07:01 AM   #6
neurokinetik
neurokinetik's Avatar
Drives: 2013 Scion FR-S Firestorm
Most of the later domestics do, with the exception of the Corvette which has been SLA for a long time. Mustangs have been struts up front since at least the fox body days.
Too bad we got the McSuspension on this car. I miss my Miata.
neurokinetik is offline   Reply With Quote
Old 06-23-2014, 07:59 AM   #7
DarkSunrise
DarkSunrise's Avatar
The Porsche Cayman actually has macpherson struts at the front AND rear.
But I agree with your overall point. BMW and Porsche have proven through racing that you can be fast in a RWD car with macpherson struts at the front (and loads of static negative camber to compensate).
2022 BRZ Build
2013 FR-S Build
Old 06-23-2014, 08:22 AM   #8
DarkSunrise
Haha isn't that just splitting hairs at that point?
Porsche refers to them as macpherson struts btw:
Rear Suspension: Wheels independently guided on transverse control arms with longitudinal control arms, tie rods and suspension struts (McPherson type, optimized to Porsche requirements); cylindrical coil springs with internal dampers; anti-roll bar
http://press.porsche.com/vehicles/20...ifications.pdf
EDIT: That's odd, the post I replied to (saying they were chapman struts at the rear) disappeared.
2022 BRZ Build
2013 FR-S Build
Old 06-23-2014, 01:36 PM   #9
rice_classic
With the right design a Mac setup can have a dynamic curve. Transversely, a double arm suspension (of equal length arms) can have no dynamic curve.
The dynamic camber curve of a double arms isn't inherent to the fact there's 2 arms but to fact that they are of unequal length.
On a Mac setup, if the angle of mounting to the body is very steep then a mac setup will have a dynamic camber curve. Not highly aggressive like that of a CRX but a dynamic curve nonethless. However, on the vast majority of road-going cars, the macs are mounting quite upright as the design restriction of a chassis doesn't allow a steep angle.
Last time I looked at the rear of a Cayman, the angle looked pretty steep... Same with the Alfa 4C but I don't know what kind of curve is represented through the motion with their specific geometries.
In the video I was baselining 4degrees because my car was in the air and on my slightly uneven garage floor. On a flat pavement with my car on he ground I run ~3 degrees up front. I would like about 3.5 or 3.75 but I can't achieve that legally because of ITA rules.
I use OFFSET bushings in my anchor bolts (what my OEM UCA uses to mount to the body)
SCCA T4 - FRS
Old 06-24-2014, 03:12 AM   #10
markw
Drives: 2014 FR-S
Honda screwed it up in 2001 when they went to struts up front. Love my EF.
markw is offline   Reply With Quote
For the not faint of heart.. NX NOS!!! Kit Sportsguy83 Engine, Exhaust, Transmission 84 03-01-2015 02:54 PM
DME Lower Control Arms and DME Toe Arms - Review FT-86 SpeedFactory Suspension | Chassis | Brakes -- Sponsored by 949 Racing 23 02-24-2015 11:53 AM
GTSPEC rear control arms & toe arms review Jesse Suspension | Chassis | Brakes -- Sponsored by 949 Racing 5 08-23-2013 03:20 PM
A change of heart towards Scion Frs? Crzbiohazard Scion FR-S / Toyota 86 GT86 General Forum 44 11-20-2012 04:12 PM
Heart broken.....Subaru brz FT86FRS CANADA 26 09-09-2012 03:45 PM
