Cosmetic Modification (Interior/Exterior/Lighting) Discussions about cosmetic mods. |
05-31-2014, 12:49 AM | #1 |
Drives: Asphalt FRS
OEM Mudflaps to Rally Armor?
Hello,
I was wondering, has anyone swapped out the OEM MudFlaps for the Rally Armor Flaps? Iv had the OEM on now for about 6 months, do not mind the look however I cringe every time I detail my car, because I can see the shotty fitment of the flap onto the fender panel, leaving to my imagination that a bunch of stuck debris in-between the flap and the panel, which could harm the paint and possibly cause a mismatch. Also, I kinda look the look of the rally armor flaps. I had them installed at the dealership, they did it for free, does the install require drilling that may have been done? that id need to worry about. or would it be as simple as un-attaching the OEM and and fitting on the rally armor per instructions? Aakash |
05-31-2014, 01:09 AM | #2 |
Maximum puntential
Drives: 2013 DGM BRZ 6MT LTD
I went from no flaps to the Rally Armor ones. Fitment was spot on, no drilling required, didn't even have to remove the rear tires because my friend and I used a ratchet with a Phillips head that was low profile enough to screw in the mounting screws. That said, I could see that removing the rear tires would have made it quite a bit easier.
My only real complaint about the flaps, and this is nitpicking, is that the included screws are silver while the flaps themselves are black. I don't mind it that much but it would have been nice to have the screws painted to match the flaps just from an aesthetic standpoint. And I like the way the flaps look too. |
The Following User Says Thank You to YMAA For This Useful Post: | aakash (05-31-2014) |
Similar Threads | ||||
*GROUP BUY: JUST IN RALLY ARMOR MUDFLAPS!* | genometuning | Groupbuys | 585 | 01-15-2015 06:08 PM |
oem mudflaps or rally armor? | SuperDave | Cosmetic Modification (Interior/Exterior/Lighting) | 20 | 05-28-2014 11:28 AM |
Fs: Rally Armor mudflaps | RWD_FR-S | Exterior Parts (Aero, Lighting, Etc.) | 4 | 03-09-2014 01:38 AM |
Rally Armor mudflaps - FREE | nzer | AUSTRALIA | 23 | 01-22-2013 12:58 AM |
Rally Armor Mudflaps | jammz | Cosmetic Modification (Interior/Exterior/Lighting) | 5 | 12-27-2012 10:29 AM |
