Engine, Exhaust, Transmission Discuss the FR-S | 86 | BRZ engine, exhaust and drivetrain. |
05-25-2014, 10:36 AM | #1 |
Drives: gt86
toyota 1gr 76mm throttlr body
Hi,
I just got a throttle body from a toyota 2gr engine, the plug is the same as 4U, BUT got no response when plug into my 86. Are they different? |
05-25-2014, 11:32 AM | #2 |
Drives: Asphalt FR-S
05-25-2014, 11:36 AM | #3 |
Drives: gt86
05-25-2014, 09:23 PM | #4 |
Seņor Member
Does it bolt to the FA20 manifold?
1974 TA22 Celica
2013 86 GT |
05-25-2014, 09:28 PM | #6 |
Drives: FRS
Pics or it didn't happen...
05-25-2014, 09:34 PM | #7 |
What all is done to your engine that you can actually make use of a TB that big?
05-25-2014, 09:35 PM | #8 |
Drives: FRS
05-25-2014, 09:47 PM | #9 |
Drives: 04 Toyota Tacoma Prerunner Reg Cab
Very curious about this, if it's legit.
A humongo TB is probably the closet thing to an ITB setup for NA (which hasn't been done/reported yet); regardless if the engine is small/low-hp. A tune and/or cams is most likely needed to squeeze the power out of it and/or to even make it work. |
05-25-2014, 09:51 PM | #10 |
Drives: 2015 WRX
Isn't the stock throttle body 76mm?
05-25-2014, 09:55 PM | #11 |
05-25-2014, 09:58 PM | #12 |
Drives: 2015 WRX
You sure about that?
This post seems to disagree with you. http://www.ft86club.com/forums/showt...973#post508973 EDIT: How ironic... This one disagrees with you too... Oh wait.. recognize the username?! |
05-25-2014, 10:54 PM | #13 | |
Less than pleased...
Drives: '13 BRZ Ltd SSM 6MT
05-25-2014, 10:59 PM | #14 | |
Drives: 2013 BRZ Limited WRB
sound clips ?
Similar Threads | ||||
Toyota Service Bulletin: Body Panel Fitting Issues | ahausheer | Issues | Warranty | Recalls / TSB | 99 | 03-07-2017 12:21 PM |
Recommendations for Toyota MR2 Spyder (2002) Body Kit Vendor? | flameSniper | Other Vehicles & General Automotive Discussions | 8 | 09-19-2013 02:11 PM |
Body Shop or Scion/Toyota paint specialists in Long Island NY | mikeg7827 | NY / NJ / CT / PA | 7 | 02-27-2013 12:15 PM |
Scion FR-S / Toyota FT-86 / Subaru with Aggressive Body & High Wing! + VIDEO! | Hachiroku | Scion FR-S / Toyota 86 GT86 General Forum | 538 | 06-15-2011 02:20 AM |
