Old 05-20-2012, 09:12 PM   #1
Scooby South
Conedancer
Scooby South's Avatar
Drives: 2013 Subaru BRZ SWP
BRZ NAV/DVD bypass
Not sure if this will work with the BRZ nav system...but it works with all other Subarus with Navi..... When I get some spare coin..I will purchase this to see if it works..
Bill
http://www.beatsonicusa.com/nav-dvd-...ic-tvk-54.html
Scooby South is offline   Reply With Quote
The Following User Says Thank You to Scooby South For This Useful Post:
ESBjiujitsu (05-21-2012)
Old 05-20-2012, 09:21 PM   #2
Spaceywilly
ZC6A2B82KC7J
Spaceywilly's Avatar
Drives: 2002 WRX
No reason to spend that much on it, all it's doing is grounding one signal.
Straights are for fast cars. Turns are for fast drivers.
Spaceywilly is offline   Reply With Quote
Old 05-20-2012, 09:25 PM   #3
Scooby South
Conedancer
soooo cut the signal??? Diode it???? bypass it??? and do we know exactly 'what' signal..
Bill
Old 05-20-2012, 09:31 PM   #4
Spaceywilly
ZC6A2B82KC7J
Drives: 2002 WRX
I'll have to figure that out once I get mine
Then once you know the signal it's just a matter of cutting that wire and grounding it somewhere. Sometimes it is as simple as taking a pin out of the harness.
The Following 2 Users Say Thank You to Spaceywilly For This Useful Post:
ESBjiujitsu (05-21-2012), Guff (05-20-2012)
Old 05-21-2012, 09:14 AM   #5
ESBjiujitsu
MUST HAVE MORE 86 ! ! !
ESBjiujitsu's Avatar
Drives: Mazdaspeed 6 2.3 AWD Turbo
i see good things in the works here
WISH LIST: Whiteout FRS- Bronze 18' race rims, Cooper Zeon RS3-S tires,
Cusco Coilovers, Cusco 6 point cage, CF Lip spoiler, CF F1 Mirrors, HKS GT-86 SC
92 carmy -> 86 corolla-> Honda S2000 -> Audi TT -> Mazdaspeed6 -> NEXT UP TOYOTA FT-86!!!!
ESBjiujitsu is offline   Reply With Quote
Old 06-06-2012, 04:06 AM   #6
bryan
bryan's Avatar
Drives: Lots of Toyotas
Has nobody figured this out yet? The car must be that good that current owners could care less about using the nav screen while driving!
bryan is offline   Reply With Quote
Old 06-06-2012, 03:49 PM   #7
Oriental Life
Oriental Life's Avatar
Drives: Forester 2007, BRZ Limited '13
To figure this out, does anyone have an access to this doc: http://techinfo.subaru.com/proxy/676...aviHQFinal.pdf?
Also, review this post from NASIOC:
http://forums.nasioc.com/forums/show...28&postcount=9
It could be that BRZ is fitted with Pioneer unit, then to identify it use this code diagram:
P - Panasonic
PE - Pioneer
CX - Clarion
GX - Kenwood
FT - Fujitsu Ten (Eclipse)
I am busy. Do not disturb. http://youtu.be/I58ZSqwFlWw?hd=1
Oriental Life is offline   Reply With Quote
Old 06-06-2012, 04:31 PM   #8
2pt5RS
Berz
US BRZ has the Fujitsu Ten unit in it.
2pt5RS is offline   Reply With Quote
Old 06-06-2012, 10:47 PM   #9
Indestruct
Drives: 2013 SWP Limited BRZ, MT
Has anyone figured this out yet? I was just watching an Xvid.AVI file... and the second i put down my ebrake the screen turned blue!!! so sad. I wanna watch inital D while drifting and smoking a cig!
but for 125 I rather put that towards a Nav/dvd that actually works well! This head unit is sooo crappy it makes me sad.
Indestruct is offline   Reply With Quote
The Following User Says Thank You to Indestruct For This Useful Post:
StarsGarrador (07-02-2012)
Old 06-06-2012, 10:54 PM   #10
Dave-ROR
Site Moderator
Dave-ROR's Avatar
Drives: Stuff
The ebrake one is simply, you literally just ground the wire going to the HU for that.
The NAV I don't think is the ground signal as you don't need to engage the ground to set an address. One of the issues I noticed during my recent trip was I could only find stuff in motion with voice rec or nearby items, and voice rec doesn't let me (in an obvious way anyways) change from "nearby" to "in this city/state". Instead the car has to be stopped and I believe the HU is figuring that out simply from the GPS signal, not the ebrake.
-Dave
DD: 2005 Acura TSX
Tow: 2022 F-450
Old 06-10-2012, 12:44 AM   #11
xcelir8brz
Drives: 2013 BRZ Limited
Easy Peasy. Pull the head unit out. Look for the gray plug. One wire is sticking out of it. Cut the wire in the middle. Take the wire that still connects to the connector that plugs in the radio and ground it. Problem solved. Oh, BTW, I grounded it to the ground wire on another connector (the one that has front speakers). Works well.
xcelir8brz is offline   Reply With Quote
Old 06-10-2012, 08:28 PM   #12
BRZranger
Any way you or someone else can post a how-to with pics? This would be an awesome mod.
BRZranger is offline   Reply With Quote
Old 06-17-2012, 09:27 PM   #13
Sportsguy83
I Love custom Turbo kits
Sportsguy83's Avatar
Drives: Limited BRZ
I will pull out the Nav assembly on Tuesday to try and find the ground cable.
Old 06-17-2012, 11:40 PM   #14
Sportsguy83
Drives: Limited BRZ
Does grounding the ebrake wire allow for phone functions to be used, for example using the dialpad and phonebook?
While Driving I mean...
