Old 05-19-2014, 11:17 PM   #1
mush
mush's Avatar
OEM Audio Plus settings
what settings are u using? and what head unit do u have?
i installed the reference system last friday and im using what was recommended
tc and natural, i bumped up the bass 2 clicks
scion 2014 touchscreen headunit
wondering if anyone found something better
Old 05-20-2014, 12:48 AM   #2
SC10N
#293 / 2500
SC10N's Avatar
Drives: FR-S MT 10 Series
Mine was installed about two weeks ago. Still haven't found the perfect setting...
When you say you bumped the base up-two, do you mean from the center (middle) or from the very lowest?
I have mine set:
treble -1 to -2 off middle
Bass -1 off full (highest)
Balance (front to rear) a notch or two to the rear.
TC / natural
I think something's wrong with mine because I'm not having the awesome experience that everyone else seems to be having. The front tweeters are distorting about every third song- for example: Rihanna - Stay, is extremely horrific sounding--major distortion anything at 40 or above.
Maybe something I'm doing wrong (or high expectations?), but I miss my old system in some ways, I think it just needed a sub?
I also upgraded to BeSpoke and Nav at the same time so it was a lot to fiddle around with for a while. But after two weeks I have tried almost every setting. 'Some' songs, IMO, seem to sound better on FEEL and others sound HORRIBLE on FEEL so I've just been leaving it on NATURAL...but something is missing? Even my go-to CD when I test a car stereo--Fleetwood Mac, Rumours sounds....empty? My Factory Corolla JBL system BLOWS this set-up out of the water!
I have the 2014 unit and OEM Audio + Reference System 400CF
I was tempted to post this same question, but I was going to call Daniel first.
Would appreciate any pointers too...
SC10N is offline   Reply With Quote
Old 05-20-2014, 02:42 AM   #3
mush
mush's Avatar
Im pretty happy with mine so far
Bass bumped up 2 clicks from the center, Everything else was left alone
Also what bass reproduction did u pick? (Balanced, full, or robust) I picked balanced
Ill try ur settings tomorrow, thanks
Old 05-20-2014, 02:58 AM   #4
SC10N
#293 / 2500
SC10N's Avatar
Robust.
What were the settings at that you left alone?
Thanks.
Rear spoiler - PI fog lights - TRD exhaust - Zeta Center Console Armrest - BeSpoke / Nav upgrade - OEM Audio + Reference System 400CF - Beat Sonic shark fin antenna - Lathe Werks burnt gun metal stainless steel sphere shifter - OEM HID LED Mod Kit - Interior Illumination Kit- Red - Trunk lid Liner Kit
Old 05-20-2014, 08:52 AM   #5
mush
mush's Avatar
Originally Posted by SC10N View Post
Robust.
Thanks.
The only setting that i changed was bass
Old 05-23-2014, 08:50 PM   #6
l0aded
Addicted
l0aded's Avatar
Drives: 2013 Asphalt FR-S 6MT
Reference series.
Full bass profile.
+2 trebble +4 bass.
Natural
Dont know if tC or frs? Why is everyone on tC I thought that was only for the original one.
l0aded is offline   Reply With Quote
Old 05-25-2014, 01:18 PM   #7
alexand3r
Custom User Title
alexand3r's Avatar
Drives: Spaceship
With my reference I use:
tC
Hear
Treble: -2
Bass: +2
Balance: Center
alexand3r is offline   Reply With Quote
Old 05-27-2014, 12:14 AM   #8
mush
mush's Avatar
I have mine set:
TC / natural
i tried this. sounds flat, no bass
Originally Posted by l0aded View Post
Reference series.
Full bass profile.
+2 trebble +4 bass.
Natural
thanks, ill try this. on the instructions it says to set on "natural" and "tC"
tC
Hear
Treble: -2
Bass: +2
Balance: Center
thanks, ill try this too!
Old 05-27-2014, 11:09 AM   #9
alexand3r
Custom User Title
alexand3r's Avatar
Drives: Spaceship
If you want more bass, but not quite as clear highs, go with this:
tC
Feel
Treble +2
Bass +3
Balance +2 Front
FOrgot to mention, my DSP is set to Low. Off kind of zaps the sound a bit.
Old 08-17-2014, 01:18 PM   #10
TemeCal
Drives: 86
Every source is different for me. I've found the following to be the best for my taste (mostly rock and alternative rock)...
All numbers are from center:
Satellite (XM Radio)
tC
SSP Feel
Treble +2
Bass +2
+2 Rear
ASL high
Bluetooth
tC
SSP Feel
Treble +2
Bass +1
+2 Front
ASL high
USB
tC
SSP Feel
Treble -2
Bass +2
+1 Rear
ASL low
TemeCal is offline   Reply With Quote
Old 08-20-2014, 03:09 PM   #11
Pyrefyre
Drives: 2013 Subaru BRZ Black
When I talked to OEM+ they told me to set it to flat. Everything sounds much better than it did stock. But I have the BRZ so it is set to BRZ, since Impreza and Outback are drastically different sound stages. Unfortunately they came out with the good upgrade, the SL system, after I bought mine.
Pyrefyre is offline   Reply With Quote
Old 08-20-2014, 06:41 PM   #12
themajesticone
themajesticone's Avatar
Drives: '13 UM86
I have mine at
Feel
treble +4
bass -2
sounds pretty good!
JRSC C30 91 oct | JDL UEL Header | Tomei Overpipe | Milltek Front Pipe | Milltek Catback | SPL LCA v2 | FA 500 v5 Coilovers 6k/7k | SPC Front Camber Bolts | Enkei RPF1 17x9 +35 | 245/40 Michelin Pilot Super Sport
themajesticone is offline   Reply With Quote
Old 08-21-2014, 08:51 AM   #13
l0aded
Addicted
l0aded's Avatar
I'm surprised so many people are off the natural setting recommended by OEM Audio+.
Old 08-22-2014, 02:42 PM   #14
Jyn
Noob
Jyn's Avatar
Drives: FR-S Mammogram
I used normal OEM+ settings - tC, flat err'thang.
Switched to Feel and -2 Treble, +2 bass. Things sound more interesting, that's for sure
Jyn is offline   Reply With Quote
Incriminator Audio 6.4, Sundown Audio SAX-100.4, US Amps Xterminator XT800.2 slicktop Miscellaneous 1 07-11-2014 08:58 AM
FR-S Audio Build - SQ (Illusion Audio/Mosconi) DekaMori Electronics | Audio | NAV | Infotainment 28 04-17-2013 04:34 AM
BRZ EQ Settings Marcoscrdo Electronics | Audio | NAV | Infotainment 1 01-02-2013 04:35 PM
'Noobish' questions as I look to upgrade my car audio audio. DkY in Vcr Electronics | Audio | NAV | Infotainment 0 09-22-2012 09:45 PM
Settings for TCS and AT atledreier Scion FR-S / Toyota 86 GT86 General Forum 3 08-20-2012 09:36 AM
