05-19-2014, 12:33 AM | #1 |
fastest frs in sbg
Drives: sick ass ultramarine frs
Oft e85 issues
On cold starts i get popping nosies coming from engine and rpm jumps around, and boggs. Didnt have this issue until switched to e85 with oft tune.
Mods: Light crank pulley Injen intake Headers Over pipe Cat delete Cat back exhaust Third tank of e85 started happening since 2nd tank. Wondering if i should be worried.
2013 ultramarine frs sold
2014 turbo ultramarine frs Sold 2014 firestorm frs |
05-19-2014, 12:51 AM | #2 |
Drives: 2013 BRZ Premium 6MT
i get some popping on cold starts. seems to happen more when its cooler out. i usually just tap the gas pedal after i hear the first pop and they stop.
2013 Subaru BRZ Premium 6MT -STOCK!
The Following User Says Thank You to Lytheum For This Useful Post: | sosick (05-19-2014) |
05-19-2014, 01:55 AM | #3 |
"sick ass ultramarine frs"
Seems it's sick. |
05-19-2014, 02:09 AM | #4 |
If it only happens during initial startup in first 15 sec or so its probably ok on a cold morning like 30f .
If its a warm day and its happening after startup then thats not sounding too good look up di seal failure If your original rom calid was 700 900 or a00 series then the transient knock retart which helps with di seal problems was not implempted it started on a01 and above series roms ie a01c. Oft tines incorporate it. |
05-19-2014, 02:27 AM | #5 |
fastest frs in sbg
Yea usually around 30f start ups
05-19-2014, 02:27 AM | #6 | |
fastest frs in sbg
05-19-2014, 03:33 AM | #7 |
05-19-2014, 11:05 AM | #8 |
fastest frs in sbg
05-21-2014, 07:12 AM | #9 |
Drives: 2013 FR-S Argento
It's fine , misfire when engine is cold causes small burps and backfires in intake manifold, that's the popping sound. Add a gallon of gas to your tank might help.
The Following User Says Thank You to bfrank1972 For This Useful Post: | Luckrider (05-21-2014) |
05-21-2014, 08:57 AM | #10 |
My Other Ride's a Jeep
Drives: 2013 BRZ Limited
This is what the issue is. It is normal and happens in stupid cold weather with e10.
05-21-2014, 10:01 AM | #11 |
I'm on my second tank of E85. Each time I start the car for the first time in the morning, the motor starts reluctantly and then cuts out. It starts on the second try, stays running, and there do not seem to be any performance issues. It's not cold in the mornings or overnight, and the car has been garaged.
Typical, or concerning? I'm running the latest Stage 2 E85 EL bin. |
05-21-2014, 01:38 PM | #12 |
I actually get some mild misfiring and popping on e0 when it's REALLY cold out (like -20*C), both the stock ROM and OFT stage 1.
05-21-2014, 04:31 PM | #13 |
BRZ Jockey
Drives: 2013 BRZ LTD 6MT Sterling Silver
I recently started checking and logging Ethanol percentages too see if there is a correlation between performance and mixture. I recommend everyone on E85 does this. The federal allowable range is 51-83% and I can't believe that even a conservative tune will run as well towards the lower end of Ethanol concentration when compared to 70%+.
05-21-2014, 06:14 PM | #14 | |
http://www.ft86club.com/forums/showthread.php?p=1389932 |
Similar Threads | ||||
Oil issues with my avo brz...help!!!!! | brz2013 | Forced Induction | 22 | 10-19-2016 11:03 AM |
Anybody Have Zero Issues? | Don Ivey | Scion FR-S / Toyota 86 GT86 General Forum | 129 | 03-25-2013 01:14 PM |
91 Octane issues? | tokiokun717 | Northern California | 17 | 02-01-2013 02:21 PM |
more issues after CEL fix.. | DrewZ926 | Issues | Warranty | Recalls / TSB | 2 | 11-07-2012 08:15 PM |
Anybody with no issues? | tdoggy57 | Scion FR-S / Toyota 86 GT86 General Forum | 49 | 08-04-2012 03:41 PM |
