Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) Everything related to the mechanical maintenance of the FR-S and BRZ |
05-01-2014, 02:56 PM | #1 |
Drives: Scion FRS Firestorm
Oil Pressure Range
See bottom of this post for peoples results.
Original Post: Hey all, I've been searching for a few days for an exact answer but I haven't been able to find anything conclusive. What is a normal range for oil pressure for our engines stock? How about with an oil cooler and a turbo? What is a healthy range that the oil pressure should stay between at all times? -------------------------------------------------- Below is the template everyone should follow to report oil pressures.
Optional: Pictures, videos, ect. -------------------------------------------------- Results will be posted here. Last edited by blackfireball5; 06-02-2014 at 01:27 PM. |
05-01-2014, 03:51 PM | #2 | |
Yes, I want this answer too.
The Following User Says Thank You to Dezoris For This Useful Post: | blackfireball5 (05-01-2014) |
05-01-2014, 08:16 PM | #3 |
Drives: WRB BRZ Sport Tech
I would hazard a guess that our cars are spec'd for a viscosity of ~7 cST @ 100C, based on the fact that the stock 0W-20 is rated for that. So in saying that, our cars run hot when being beat on, that raises the temp up to 110-120-130 degrees celsius, so from that I would conclude that the stock 0W-20 at those temps drops to a viscosity rating of ~4-5 cSt which in my mind is not good. but if ya want to keep using the OEM Mobil 0W-20, that I would think having a thermostatically controlled oil cooler would be good investment.
see my post: http://www.ft86club.com/forums/showthread.php?t=63955 EDIT: this doesn't tell you what pressure you will get, but will give you an idea of what oil you should run based off temp to ensure oem designed oil pressure is maintained. Last edited by Gords_zenith; 05-01-2014 at 08:31 PM. |
The Following 2 Users Say Thank You to Gords_zenith For This Useful Post: | blackfireball5 (05-02-2014), flippy (09-21-2021) |
05-02-2014, 01:14 AM | #4 |
Thanks for your post. I personally am using amsoil 5w-30, with an oil cooler and the fbm kit. I'm ordering an oil pressure gauge soon and wanted to know what kind of psi i should be looking for at each end of the spectrum.
05-02-2014, 11:44 AM | #5 | |
humfrz |
The Following User Says Thank You to humfrz For This Useful Post: | blackfireball5 (05-02-2014) |
05-02-2014, 11:53 AM | #6 | |
Still would like to know healthy limits as well though. |
05-02-2014, 12:44 PM | #7 | |
......just from what I've read ..... I've nevered measured it. humfrz |
The Following 2 Users Say Thank You to humfrz For This Useful Post: | blackfireball5 (05-02-2014), Sportsguy83 (01-13-2017) |
05-02-2014, 10:11 PM | #8 |
Drives: 2013 FR-S Blue MT
You need a 150psi gauge. The oil pump goes into full bypass at 125psi. I routinely see 100-125psi on cold start with a low load on the engine.
I typically see about 1 bar per 1k rpm at operating temperature (90-100C) with 0w-20. |
The Following 3 Users Say Thank You to getbent For This Useful Post: |
05-03-2014, 04:45 AM | #9 |
Drives: Toyota 86
Cold start, i get about 8.9 bar (129 psi)
Idling at normal operating temperature, oil pressure would around 1.3-1.5 bar 5w30, Perrin oil cooler, Defi Advance CR oil pressure gauge hooked up to the oil gallery port beside the AC compressor |
The Following 2 Users Say Thank You to HRTROB For This Useful Post: | blackfireball5 (05-03-2014), jcw99 (12-24-2014) |
05-03-2014, 08:46 AM | #10 | |
Drives: Toyota 86 TRD Version AT
Help me out with the install when I get my oil pressure gauge!
05-03-2014, 01:08 PM | #12 |
Thanks guys! Looks like I'll need the 150psi gauge!
Good thing i didn't jump the gun! I already bought my defroster vent pod so I'm gonna pick up a Guage. :-) Sent from my Nexus 5 using Tapatalk
05-03-2014, 04:08 PM | #13 |
Yo can you post up what parts you used for your gauge? That would be very helpful.
05-03-2014, 05:27 PM | #14 | |
Drives: Toyota 86
http://www.rallysportdirect.com/Suba...il-Galley-Plug http://www.rallysportdirect.com/Suba...ey-Plug-Gasket Then I hooked them up to the port beside the compressor Take note that the OEM Subaru oil gallery plug is threaded for 1/8 PT sensors. You can probably use the stock oil pressure sensor location. It's pretty useless anyway. By the time the warning light turns on, the damage has already been done. It's the sensor below the oil filter housing, the one with the disconnected connector in the photo: Been driving around with the stock oil pressure sensor disconnected. No CELs. I believe it's a simple switch that grounds itself to the block when there is no pressure detected, illuminating the warning lamp on the cluster. Hope this helps. Last edited by HRTROB; 05-03-2014 at 05:40 PM. |
The Following 4 Users Say Thank You to HRTROB For This Useful Post: | blackfireball5 (05-05-2014), Bonburner (03-30-2021), BRZ68 (05-03-2014), jcw99 (06-26-2016), rb6freak (06-04-2014) |
Similar Threads | ||||
Stock clutch+flywheel+pressure plate+ ACT lightweight flywheel & pressure plate | PineappleFriedRice | Transmission and Driveline | 0 | 11-08-2013 04:54 PM |
Mid range really lacking | goli5oda | Electronics | Audio | NAV | Infotainment | 4 | 08-19-2013 10:27 AM |
Range on a tank of Gas! | crank | Southern California | 28 | 02-10-2013 04:04 PM |
Cruising Range? | skoodge | Scion FR-S / Toyota 86 GT86 General Forum | 4 | 05-25-2012 02:31 AM |
UK Price range £25-£32k!? | ZeeSpeed | Scion FR-S / Toyota 86 GT86 General Forum | 56 | 11-27-2011 02:11 PM |
