Old 03-24-2014, 09:47 AM   #1
Khorne
Super 86
Khorne's Avatar
Drives: Red 86 GTS
OEM Big Brake Kit
So this seems pretty cool.
http://www.racingbrake.com/322x25mm-.../2127-k-01.htm
From this thread http://www.ft86club.com/forums/showthread.php?t=59888
Seems like a good alternative from a BBK while keeping OEMness.
Any thoughts?
230rwhp/184ftlb on 98RON/93AKI
Build thread
Red 86 GTS MT | Sprintex Intercooled Twin Screw SC | Invidia N1 | Mocal 10 row | Invidia Front Pipe | Motiv Overpipe| Enkei RPF01 with Bridgestone RE002s | MCA Blue Coilovers | Radium Catch Can
Khorne is offline   Reply With Quote
Old 03-24-2014, 10:01 AM   #2
migueralliart
migueralliart's Avatar
Drives: 2013 Firestorm FRS
That price doesn't look that bad. The only showstopper here is there are no tests or data to compare. I understand that by going to a bigger rotor and more radially positioned caliper there is an increase in stopping power but it would be cool to see the data.
migueralliart is offline   Reply With Quote
Old 03-24-2014, 10:30 AM   #3
gramicci101
Off Topic
And it uses their 322mm rotor. What is the availability for other rotors besides RB?
I've considered making a bracket to allow use of a 326mm rotor from a 2004 STi (5x100). Since it's an OEM size, a lot of companies make replacement parts. The offset of the STi rotor is 4mm lower than the BRZ rotor, so the bracket would have to take that into account. I'd probably do the rear rotor too (316mm), since it's the same offset as ours. I had a long talk with CSG about brake bias and heat absorption and dispersion. I think a genuine BBK would be better for track usage, but this would definitely fill the street usage niche.
Old 03-24-2014, 05:11 PM   #4
wparsons
wparsons's Avatar
These cars don't need more braking power, with better pads you can easily lock up even the stickiest of tires with the stock size rotors and stock calipers.
If you need more thermal capacity, or want easier to change pads (or less cost in the long term if you track a lot), then a BBK can help, but it won't make you stop any faster if you can already engage ABS.
flickr
Old 03-24-2014, 10:06 PM   #5
Turdinator
Señor Member
Turdinator's Avatar
Also wouldn't installing a bigger disk on the front with the same stock caliper bring the brake bias forward?
1974 TA22 Celica
2013 86 GT
Old 03-25-2014, 03:46 AM   #6
troek
troek's Avatar
Drives: 2012 Toyota 86
i would assume so.
Old 03-25-2014, 02:15 PM   #7
Poodles
Drives: 2015 Series.Blue
That's not the point of a BBK. Even the worst cars on the road can do an emergency stop safely...once. BBK is to allow you to do it over and over in a racing setting.
A bit, but the vast majority of your braking is done by the front anyway. If one was to make the rear lock up first, it would be dangerous..
Old 03-25-2014, 03:02 PM   #8
wparsons
wparsons's Avatar
I'm fully aware, my post was in regards to this one:
flickr
Old 03-25-2014, 03:50 PM   #9
OrbitalEllipses
Drives: Attitude
Legacy GT fronts are a bolt on affair - with the dogbone and caliper you can fit 316x30mm OEM rotors. Though you will need to swap them from side to side to get the bleeder valves oriented correctly (IIRC the caliper isn't differentially bored).
Old 03-25-2014, 04:45 PM   #10
Dave-ROR
Site Moderator
Dave-ROR's Avatar
Drives: Stuff
Many of us here understand this. His post was in response to those who think a BBK is needed for "stopping power" and the guy who mentioned that the larger rotors with stock caliper would be enough for the street drivers.
Smaller brakes on this car would be enough for street use.
Too much front bias is just as bad. No rotation so "safer" (if you consider running into something head on safer) but ABS activation earlier than needed reducing overall effectiveness of the braking system. Ideally all four should lock at the same time in a straight line.
-Dave
DD: 2005 Acura TSX
Tow: 2022 F-450
Old 03-25-2014, 04:46 PM   #11
Dave-ROR
Site Moderator
Dave-ROR's Avatar
Drives: Stuff
This is what I was going to initially do until examing the consumables cost (and other) benefits of the direction I went instead.
-Dave
DD: 2005 Acura TSX
Tow: 2022 F-450
Old 03-25-2014, 06:19 PM   #12
gramicci101
Off Topic
What direction did you go instead?
Old 03-25-2014, 06:23 PM   #13
Dave-ROR
Site Moderator
Dave-ROR's Avatar
Drives: Stuff
http://www.essexparts.com/shop/compl...86-bundle.html
-Dave
DD: 2005 Acura TSX
Tow: 2022 F-450
Old 03-25-2014, 06:25 PM   #14
gramicci101
Off Topic
Did you do anything to the rear brakes? If not, do you feel like the brake bias has shifted forward with the much more capable front brakes?
Brake Pads, Rotors and All Your Brake/Suspension Needs! Great Prices!! Check it out!! Mike@CZP Brakes, Suspension, Chassis 348 06-01-2018 12:29 PM
FS: FRS OEM E-Brake (Emergency Brake) Hand Brake Boot CamryDS Interior Parts (Incl. Lighting) 0 06-24-2013 11:26 PM
Redline360: Brake Lines, Brake Rotors, Brake Pads for BRZ/FRS Redline360 Brakes, Suspension, Chassis 12 01-05-2013 10:20 PM
Secondary Rear Brake Caliper for drifting or parking brake?? (pics) Axel Scion FR-S / Toyota 86 GT86 General Forum 20 02-25-2010 10:28 AM
