Old 03-14-2014, 01:29 PM   #1
FRSure
Drives: Toyota
Shifting Problem (Automatic)
As some of you guys know, my car was rear ended 2 months ago..
Today the car has been finished being repaired, however, there is still one problem they can't fix.
The car won't shift in to reverse neutral or drive, but it will mechanically if we over ride it. Once over rided in drive, it only shifts to neutral, drive, and M. The car drives fine.
tl;dr, car won't shift
Anyone know what could be the problem?
FRSure is offline   Reply With Quote
Old 03-14-2014, 01:30 PM   #2
subiestyle
subiestyle's Avatar
Drives: 2014 Monogram FR-S White MT
i would have them change the transmission and not spend another minute diagnosing something that somebody else caused.
subiestyle is offline   Reply With Quote
Old 03-14-2014, 01:32 PM   #3
Blood
Drives: 2018 STI
The shop repairing your car probably did not reconnect the sensor that detects that the brake pedal has been pressed in.
Blood is offline   Reply With Quote
Old 03-14-2014, 01:33 PM   #4
FRSure
Drives: Toyota
What they told me is..
Cars goes in to reverse with a over ride just fine. When it's in reverse, the car has no problem backing up.
When car goes in to Drive or M with over ride, the car goes forward fine.. But once you put it in gear, it's stuck there until you have to manually over ride it again.
They told me they're suspecting something electronic..
Originally Posted by Blood View Post
The shop repairing your car probably did not reconnect the sensor that detects that the brake has been pressed in.
I noticed that right after I got rear ended, it won't shift, but still drives.
Any clue whats happening?
Old 03-14-2014, 01:52 PM   #5
FRSure
Drives: Toyota
DP: My low beam and high beam light also doesn't work when it's turned to "on".
Turn signal works
Old 03-14-2014, 02:01 PM   #6
2pt5RS
Berz
man...what second rate shop did you take this to?
I'd take the car to toyota about the transmission problem. ESPECIALLY if it did it right after the accident.
Also, how are they manually overriding the shifting? I don't have an auto, so I don't know what to do there.
Also, tell the body shop that did the work about the lights. They most likely forgot to plug up the headlights when putting the front back on.
2pt5RS is offline   Reply With Quote
Old 03-14-2014, 02:03 PM   #7
FRSure
Drives: Toyota
Its a Toyota dealership body shop..
Not sure how they are doing it. But all my headlight are gone after I got rear ended...
They are scratching their head on wtf is going on
Old 03-14-2014, 02:31 PM   #8
AznBRZer
Drives: 16 CBS WRX Limited
And this is EXACTLY why I will not go to a dealership's body shop.
I'm guessing that the "override" that the OP is talking about is a little button on the gear indicator next to the shifter that unlocks the solenoid that keeps the shifter in place until you step on the brake, which is what is supposed to release it.
It's underneath the tab above the "P." You have to pop the tab off first.
AznBRZer is offline   Reply With Quote
The Following 2 Users Say Thank You to AznBRZer For This Useful Post:
2pt5RS (03-14-2014), FRSure (03-14-2014)
Old 03-14-2014, 02:33 PM   #9
Chattanooga FR-S
Chattanooga FR-S's Avatar
Drives: Monogram Firestorm
Shoulda totaled it...
Chattanooga FR-S is offline   Reply With Quote
Old 03-14-2014, 02:39 PM   #10
thill
Not that it sounds like you are going to accept this workaround, but just don't
Tell them if they can't fix the current transmission then you would expect a new one that functions properly.
Old 03-14-2014, 02:45 PM   #11
FRSure
Drives: Toyota
Not my choice to total it or not.
They pinpoint it on "electrical issue"
Old 03-14-2014, 02:46 PM   #12
2pt5RS
Berz
something they're responsible for fixing. I wouldn't take possession of the car until they fix everything
Old 03-14-2014, 02:48 PM   #13
thill
Sounds like my VW GTI.. That car came with some German speaking electrical gremlins..
Old 03-14-2014, 02:49 PM   #14
AznBRZer
Electrical issue or not, the car is not safe to be on the road PERIOD. Any half decent shop wouldn't come close to letting you take that car off their property.
shifting from 1st to 2nd jarviz Scion FR-S / Toyota 86 GT86 General Forum 35 05-26-2016 07:15 PM
Automatic Transmission Kick/Choke when shifting gears Tech Gremlin Engine, Exhaust, Transmission 13 06-16-2015 01:54 AM
MT Shifting n8dog11914 Engine, Exhaust, Transmission 4 08-28-2012 03:28 PM
Paddle shifting automatic downshift FR-YES Scion FR-S / Toyota 86 GT86 General Forum 15 08-06-2012 09:18 AM
shifting and down shifting feel Lowellrenzo Scion FR-S / Toyota 86 GT86 General Forum 23 07-08-2012 05:09 PM
