Old 03-02-2014, 08:19 PM   #1
tzhu07
I just cannot remove the oil filter...
- I tried by hand
- I bought a wrench, but found out that there isn't enough room to work the handle
- my local auto shop has oil filter caps, but none of them fit
Maybe I have to look online for something? My first oil change is coming up at the 7.5 month mark in April.
tzhu07 is offline   Reply With Quote
Old 03-02-2014, 08:24 PM   #2
Malt
Drives: 2015 WRX
Malt is offline   Reply With Quote
Old 03-02-2014, 08:24 PM   #3
Takumi788
JHerbert Racing
Takumi788's Avatar
Drives: 2013 Scion FRS
http://www.ebay.com/itm/Adjustable-M...15f2db&vxp=mtr
Buy one of these from an auto parts store and use a ratchet extension for clearance.
- #813 2013 Scion FRS Build Thread
- JHerbert Racing Website
Takumi788 is offline   Reply With Quote
Old 03-02-2014, 08:25 PM   #4
Deadspool
Much title. Wow.
Deadspool's Avatar
Drives: 2013 BRZ Sport-Tech
http://www.autozone.com/autozone/acc...er=114009_0_0_
༼ つ ◕_◕ ༽つI PUT A SPELL ON YOU ༼ つ ◕_◕ ༽つ
Deadspool is offline   Reply With Quote
Old 03-02-2014, 08:30 PM   #5
ProTekk
ProTekk's Avatar
Drives: Whiteout FR-S
This works 100% of the time.
http://www.walmart.com/ip/33906627?w...097301&veh=sem
Sent from my hlte using Tapatalk
ProTekk is offline   Reply With Quote
Old 03-02-2014, 08:31 PM   #6
ProTekk
ProTekk's Avatar
And no I'm not trolling. I've had to use water pump pliers to remove the filter every damn time Toyota has done the oil change.
Old 03-02-2014, 09:15 PM   #7
supramkivtt2jz
PROUD OF BOXER
Drives: Raven FR-S
ugh.
take screwdriver and hammer. hammer screwdriver through filter. use the handle to loosen filter
supramkivtt2jz is offline   Reply With Quote
Old 03-02-2014, 10:01 PM   #8
cycleboy
Drives: 2013 Scion FR-S - Argento
Originally Posted by supramkivtt2jz View Post
ugh.
I had to do this on my 1973 BMW 2002 the first time around. Someone had put the filter on retarded-tight and it was the usual narrow/hard to get angle. Tried everything and finally just pounded a screwdriver through it. Messy as fuck, but it worked.
EDIT: there is no way that's needed on this car w/ the filter right there on top.
cycleboy is offline   Reply With Quote
Old 03-02-2014, 10:06 PM   #9
Sportsguy83
I Love custom Turbo kits
Sportsguy83's Avatar
Drives: Limited BRZ
ugh.
Cant get any simpler than that...
Old 03-02-2014, 10:08 PM   #10
sdemo
sdemo's Avatar
Drives: '13 SWP ZC6 R
Turn counter-clockwise.
EDIT: First oil change at 7.5 months???
sdemo is offline   Reply With Quote
Old 03-02-2014, 10:14 PM   #11
tzhu07
Originally Posted by Malt View Post
I bought and then returned that item. There wasn't enough clearance for the handle.
Old 03-02-2014, 10:16 PM   #12
Luis_GT
ugh.
I preffer the non messy way...
I just wrapped a belt around it and pulled like I mofo... worked like a charm.
Old 03-02-2014, 10:16 PM   #13
tzhu07
Yes, I'm following the car's manual.
7.5K miles, or 7.5 months, whichever comes first.
Old 03-03-2014, 12:19 AM   #14
CoupedUpSubie
Drives: 2013 BRZ Limited
From what I have heard most dealers recommend an oil change at 3750 miles. The old convention was 1000 miles on break in.
As for the filter a set of filter pliers or channel locks should do the trick. I like the filters with grit in the paint as I have never had to use tools to remove one. Dealerships also seem to like over tightening filters.
2013 BRZ Limited 6MT
2014 Ram 1500 Quad Cab Black Ram - 8 speed with 3.21 gears
1994 Honda VFR750 - Two brothers 4-1 left side exit exhaust
1993 Honda CB750 Nighthawk
CoupedUpSubie is offline   Reply With Quote
OEM Subaru engine air filter + cabin air filter autobrz Mechanical Maintenance and Tools 6 03-09-2014 09:28 PM
Does anybody know exactly what filter the injen Sri uses? I want to get a new filter Frsexxxy Engine, Exhaust, Transmission 13 02-19-2013 10:04 AM
PLS REMOVE Nezz Australia Classifieds 0 01-31-2013 05:59 AM
will polishing your car to remove swirls remove opti-coat? bacon_cheese_beer Cosmetic Maintenance (Wash, Wax, Detailing, Body Repairs) 11 10-25-2012 10:41 PM
Drop In filter test! Stock, Apexi, No filter RallySport Direct Engine, Exhaust, Transmission 14 06-25-2012 02:40 PM
