Old 02-02-2014, 08:27 PM   #1
dssence
Drives: Toyota FT/MT 86
Best habit to shift gears on MT and fuel economy
Hi well like the post says.. I own a toyota 86 FT manual, and I'd like to know what 's the best way to shift gears and have a nice fuel economy rate about 25mpg like most ppl state.
I don't know if my driving habits are bad or whats up , but I've taken my car from the dealer with the tank filled up have done like 89km and have half a tank left.
So maybe I'm shifting gears badly at bad rpms. A friend of mine told me to keep rpms below 3000rpm not to consume excesive fuel.
but what would be the best manual shifting practice. Start car 1st gear, then 2nd gear those gears are the most fuel demanding ones.. then 3rd .. move to 4th .. Then should I stay driving the car in 5th and 6th gear?
dssence is offline   Reply With Quote
Old 02-02-2014, 08:41 PM   #2
Dusty
Dusty's Avatar
Drives: 2013 Firestorm FR-S (traded).
Slower acceleration. Slower deceleration.
You can look at your instantaneous mpg on the dash menu.
"I'm getting my turtleneck. I'm not defusing a bomb in this!"
Dusty is offline   Reply With Quote
The Following User Says Thank You to Dusty For This Useful Post:
dssence (02-02-2014)
Old 02-02-2014, 08:45 PM   #3
993Fan
993Fan's Avatar
Drives: 2014 DGM BRZ MT
Try not to have any fun.
993Fan is offline   Reply With Quote
The Following 10 Users Say Thank You to 993Fan For This Useful Post:
DrawingWaves (02-03-2014), KelvinBRZ (02-03-2014), Kimsey47 (02-02-2014), Muaddib (02-03-2014), Nasty Sausage (02-05-2014), ntron1 (02-02-2014), Ramster (02-03-2014), Sonolin (02-06-2014), soundman98 (02-02-2014), Squishy86 (02-02-2014)
Old 02-02-2014, 08:48 PM   #4
dssence
I've actually done it checked the instantenous mpg reading , but even if I start slowly in 1st gear gives like 36litres , then it steadies.. then jumps a bit.. then seems to be about 8 litres when I'm in 5th and 6th .. but seems like it's not a matter of being under 2000 rpms . it's weird.
Old 02-02-2014, 08:49 PM   #5
jwlee7ucla
Drives: Ultramarine FRS
I drive 40 minutes to and from work 5 days a week, and drive around weekends to play. I get stuck in ~30 min of traffic each day, and I average 30mpg per tank.
Here are things I do that I've picked up from hypermiling.
1) Don't jackrabbit the gas pedal.
2) try to stay out of neutral- coast in gear.
3) I change gears between 3k-3.5k
4) I keep 2 car distance between me and cars in front of me, because I'm scared of rockchips. If you are not, feel free to draft behind trucks (you get a mpg boost from as far as 100 feet gap if I remember correctly)
5) have a steady foot- accelerating uses more gas than staying constant speed
jwlee7ucla is offline   Reply With Quote
The Following 2 Users Say Thank You to jwlee7ucla For This Useful Post:
dssence (02-02-2014), Nasty Sausage (02-05-2014)
Old 02-02-2014, 08:50 PM   #6
N1rve
N1rve's Avatar
Drives: 2019 BMW ///M4
Under 3000!? I get my car in the 3-4k range...right now I'm averaging 27 MPG LOL
Old 02-02-2014, 08:55 PM   #7
ntron1
Sarcastic Bastard
Drives: '13 DGM BRZ, '13 Mini, 1999 Blazer
1) Pretend there is an egg between your foot and the gas pedal
2) Coast downhill in Neutral not in gear.
3) I change gears between 2k-2.2k
4) I keep 10+ car distance between me and cars in front of me, so I almost never have to brake (wastes alot of gas)
ntron1 is offline   Reply With Quote
The Following User Says Thank You to ntron1 For This Useful Post:
Old 02-02-2014, 09:00 PM   #8
dssence
heh kay so what don't jackrabbit the gas pedal mean, what about coasting in gear? I've been trying now to shift gears in the 2-2.5k range. Honestly don't now what's the best rpm to shift gears.. some ppl are saying 3k-3.5k
Old 02-02-2014, 09:02 PM   #9
ntron1
Sarcastic Bastard
If you activate the eco shift light it will give you the shift arrow @ 2K - 2.2K.
go to the 3:30 point of the video below.
[ame="http://www.youtube.com/watch?v=fB9dcC9dl3w"]Scion FR-S: How to set the Shift Light & Gear Indicator Display Settings (BRZ GT86) - YouTube[/ame]
The Following 2 Users Say Thank You to ntron1 For This Useful Post:
Bonner (02-03-2014), dssence (02-02-2014)
Old 02-02-2014, 09:04 PM   #10
dssence
Well I don't have cruise control, I enabled the G-on feature which tells you with a blinking arrow when you should shift to the next gear. but that goes in a high rpm mostly.. which wouldn't be really fuel conservative.
Old 02-02-2014, 09:06 PM   #11
jwlee7ucla
jackrabbit means quick starts (big acceleration compared to slowly reaching driving speed.
When you cost in neutral, your car uses gas to keep it's idle, but you go a little farther. When you coast in gear, you use no gas, and you supposedly go less distance (I havn't really noticed). Everytime I drive to a red light, I start coasting in gear early and get into neutral when I'm almost at the light to prolong the in-gear coasting.
You should learn how to drive predictably so you can replicate your results, then compare the difference in mpg from you changing gears at 2k vs 3k. Most of getting a high mpg just involves you driving at a constant speed for as long as possible, and reducing your accelerating amount.
I hit 30mpg almost every single gas tank, but I've been practicing for a long time, and I used to have a air fuel gauge/boost gauge to stare at when driving my old car to make sure I kept my foot steady.
I don't use cruise control ever, but you could give that a shot.
The Following 3 Users Say Thank You to jwlee7ucla For This Useful Post:
dssence (02-02-2014), Nasty Sausage (02-05-2014), ntron1 (02-02-2014)
Old 02-02-2014, 09:08 PM   #12
dssence
When you coast you mean when you're letting the car roll without pressing the gas pedal and in neutral ? Sorry
Old 02-02-2014, 09:09 PM   #13
jwlee7ucla
coasting just means moving without stepping on the gas pedal. you want to do that while staying in gear
Old 02-02-2014, 09:09 PM   #14
ntron1
Sarcastic Bastard
My other car gets 9 mpg but it is far more fun than my BRZ but not a good Daily Driver.
Why isn't the fuel economy better? White Shadow Scion FR-S / Toyota 86 GT86 General Forum 495 10-28-2019 08:21 AM
Fuel economy deteriorating?? newbrz Issues | Warranty | Recalls / TSB 33 03-14-2014 02:26 PM
What fuel economy numbers are you getting? Chimpo Scion FR-S / Toyota 86 GT86 General Forum 53 01-05-2014 03:55 PM
Fuel economy ozne99 BRZ First-Gen (2012+) — General Topics 48 12-11-2012 12:55 PM
Fuel Economy Lexicon101 Engine, Exhaust, Transmission 38 02-22-2010 03:50 PM
