Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack Specific topics relating to wheels and tires. |
01-01-2014, 07:57 PM | #1 |
Drives: Asphalt FR-S
better wheels, lowered, with good DD capabilties?
Please correct me if I am wrong. If I get 18" wheels with a coil-over set up that lowers the car 1" the wheel wells would lose a lot of gap but the car would only be lower 0.5" (to maintain clearance). Right? I essentially want the car with no change in clearance but with a better wheel well look because the car is my DD.
01-01-2014, 08:02 PM | #2 |
Drives: 2019 Mazda Miata RF
If you go 1" larger in overall dia, ie diameter of the tire, you're speedo will be off quite a bit. Generally you try to maintain the overall dia, if you go larger with the wheel dia, you go with a lower profile tire, to maintain the overall dia.
01-01-2014, 08:09 PM | #3 |
Drives: TRD Ultramarine '13
^ Basically what he said.
It depends on how big the tires are that you put on 18" wheels. So basically, the height of the sidewall will be a big factor. Keep the overall tire diameter the same as stock, otherwise your speedometer is going to be off. You could be going like 5 mph slower/faster than what the speedometer is actually telling you. And if you do keep the overall diameter the same, then a 1" drop on the coilovers will also mean 1" less clearance. |
Similar Threads | ||||
rce yellow lowered...now wheels any size suggestions? | teamred | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 21 | 04-28-2018 02:16 PM |
TSW Wheels (Good/Bad/Experiences?) | Re~Mix | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 24 | 07-29-2015 08:08 PM |
Seeking lowered 86 with stock wheels | DarrenDriven | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 20 | 10-12-2014 08:12 PM |
is this a good deal for the wheels | Anthony7515 | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 4 | 11-25-2013 11:47 AM |
Does anyone have pics of FR-s Lowered with stock wheels and and fatter tires?> | Mrqb22 | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 19 | 10-09-2012 11:24 AM |
