Cosmetic Modification (Interior/Exterior/Lighting) Discussions about cosmetic mods. |
09-18-2013, 01:19 PM | #1 |
Drives: Sc10n Series FR-S
Tapping into badge lighting
I am writing this to see if anyone has yet checked out the badge lighting system on the 10 series?
I looked at the diagrams that came with the car but they don't show much of what I need. I am planning to add accessories/lighting that goes with the badge lighting. Does anyone know, or can give advice, on a good,safe way to tap into the circuit for the badge lights? Essentially I want some accessory lighting to fade on/off with the badges.
I figure as long as you smile while driving the car, you're doing it right.
09-18-2013, 01:44 PM | #2 | |
Drives: tezla
09-18-2013, 02:14 PM | #3 |
Drives: Da-Big Banana
I don't think the wiring for the glowing emblems will support anymore added lighting.
I'm not screwing around with the emblems seeing how they cost $400.00 each to replace.
09-18-2013, 03:01 PM | #4 | |
Might have to use my multimeter to do a power pull test on them to see how much more amperage I can consume
09-18-2013, 04:43 PM | #5 |
Keep Calm And Drift On~
Drives: Scion FR-S WhiteOut 6 Speed Manual
I hope you don't burn your car down because a wire decided to overheat ....
09-18-2013, 04:54 PM | #6 |
Drives: 2013 10 series FRS #944
You can run additional accessories through a relay and use emblem wire as remote to turn them on
09-18-2013, 05:44 PM | #7 |
That's close to what I want. Which of the emblem wires would be used to open/lose the circuit
09-18-2013, 07:11 PM | #8 | |
ProCrastinationConsultant
but for those of you lacking the talent, this guy has put up with plenty of my harassment about his product and still somehow kept it professional.. and his emblems look a heck of alot better then just an 'acrylic sandwich'.. http://shop.ampdemblems.com/ |
The Following User Says Thank You to soundman98 For This Useful Post: | kakarot1657 (10-02-2013) |
09-18-2013, 07:18 PM | #9 | |
OK you go make one and post it up.
09-18-2013, 08:54 PM | #10 |
don't laugh too hard, you might hurt yourself.
http://www.hidplanet.com/forums/show...lipse-led-swap |
The Following User Says Thank You to soundman98 For This Useful Post: | retrosmiths (09-26-2013) |
09-25-2013, 01:10 AM | #11 |
If I upload the wiring diagram could anyone here let me know which of the wires to use as the relay for on and off to some additional lighting?
I'm assuming I could run a serial circuit through the badge ground wires? Or would it be best to find the connectors and tap in there, similar to how the always on LED box upgrade on here has wires directly to the pins? Sent from my SGH-T999 using Tapatalk 2
09-25-2013, 11:05 PM | #12 |
no guarantees, but i can try..
The Following User Says Thank You to soundman98 For This Useful Post: | SillySaxon (09-26-2013) |
09-26-2013, 01:02 AM | #13 |
Drives: Scion FR-S Whiteout
I'd love to see your take on this.
2013 Scion FR-S
09-26-2013, 04:44 PM | #14 |
Cool I'll get it to you this evening
Similar Threads | ||||
FRS Clicking/Tapping sound | DCStorm | Issues | Warranty | Recalls / TSB | 30 | 12-29-2017 09:59 AM |
Tapping sound above 70 mph | Fugazi | BRZ First-Gen (2012+) -- General Topics | 24 | 10-20-2015 04:04 AM |
DIY remove FR-S 86 badge and installing JDM 86 badge | Tylub | DIY (Do-It-Yourself) Guides | 13 | 07-07-2013 10:24 PM |
Strange Tapping noise from under car after use | rhood168 | Issues | Warranty | Recalls / TSB | 10 | 02-12-2013 02:16 AM |
Tapping my oil feed | Silverdub | Forced Induction | 9 | 10-17-2012 04:22 PM |
