BRZ First-Gen (2012+) -- General Topics All discussions about the first-gen Subaru BRZ coupe |
08-28-2013, 05:50 PM | #1 |
I dream of BRZ
Drives: Prospective BRZ owner.
What have been your 0-60 times?
HAHAHAHHAHAHAHAHAHAHHAHAHHAHAHAHAHAHHAHAHHAHAHAHAH AHAH
is my reaction when I see in articles or even our holy Clarkson read off the pamphlet that the twins do 0-60 in an astonishing 7.7 seconds... My dads E60 525i (215hp/185tq) & probably 3500+ ibs does it in 7.6 secs. And that is in Auto without the "sport" mode on. So what are the actual 0-60 times of the twins? I can't imagine a nearly 1000 ibs less car with 200 hp (maybe the torques the issue) does it in 7.7 secs. |
08-28-2013, 05:53 PM | #2 |
Drives: Non-BRZ
Motor Trend says the Limited AT took 7.7, which was 1.3 slower than the 6MT, putting it at about 6.4, which is in line with most other 6MT 0-60 times I've heard. 6.2-6.5 is pretty 'standard'.
2013 SSM BRZ Limited 6MT - 5/28/2012-10/28/2014 |
08-28-2013, 06:02 PM | #3 |
Proud of Boxer
The best time I've seen quoted for a manual was 6.1
I think with good rims/tires and aggressive launches you could see consistent low ~6.x times. |
08-28-2013, 06:12 PM | #4 |
I dream of BRZ
Those times make a lot more sense. What about if we switch out the un-grippy stock tires...Any data on how much the performance summer tires help the brz do it in?
The Motor Trend babe (lady) visiting tire-rack says she shaved more than a second on her best lap around the track with a BRZ and that the tires were the most cost-effective upgrade for the vehicle. LINK: [ame="http://www.youtube.com/watch?v=QQwWdZ00HYQ"]Modifying the 2013 Subaru BRZ! The First Change a Driver Should Make - Wide Open Throttle Episode 39 - YouTube[/ame] |
08-28-2013, 06:12 PM | #5 |
THE CORVETTE KING!
Drives: 2013 FR-S, and 2016 FR-S!
With the FR-S power to weight ratio, 0-60 should be in the low 6's!
08-29-2013, 12:10 AM | #6 |
GBS Mafia Member
Drives: with Snow mode on
Would an automatic on manual mode have the same 0-60 times as a manual (assuming driver in manual does not build RPMs & drop that clutch)?
GBS Mafia |
08-29-2013, 12:20 AM | #7 |
0-60 in 6.5 is what Edmunds clocked it at and they are conservative (6.2 seconds with 1 ft rolloff). I would say 6.2-6.5 with the manual should be consistent.
With some minor mods, you should be able to get the car in the high 5's I would think. |
08-29-2013, 12:24 AM | #8 |
***** Super Senior Member
Drives: 13 FRS
By look alone, the twins should be able to do 0-60 in 4.2 seconds.
08-29-2013, 12:30 AM | #9 | |
Unsprung Weight.
Drives: GBS BRZ, S70 T5, 2002 tii
Well getting away from a stand still with the manual still requires applying some throttle, unless you let the clutch out real slowly without throttle then mash the gas when it catches. If you did that the auto would probably be a car or two ahead of you before you could apply 100% throttle. If you held the revs at say 1500 or so just so the car didn't bog when you dumped the clutch might be pretty close, if the auto just mashed the gas from a dig. I don't think being in manual mode will help the 0-60 time in the auto. It should shift at redline just as fast under full throttle as it does in manual mode. Drive safe. |
08-29-2013, 08:14 AM | #10 |
Drives: MR Spyder/GT86
i think the topgear 0-60 time was actually the 0-62 time because here in belgium they are advertised as 0-100kmph in 7.6sec(0-62mhp) but yeah they should be faster
08-29-2013, 09:04 AM | #11 |
Drives: Subaru BRZ Limited
This may sound dumb, but which traction mode gives the best take off and best 0-60 time?
Full traction ON stops power to the wheels so I'd think either sport mode or Holding the trac button for 5 seconds. I drive a 6MT. |
08-29-2013, 09:13 AM | #12 | |
Dodging cones
Drives: 2013 BRZ Limited, 93 Z28
Full off. Sport mode turns TCS off, supposedly, but the stability cuts in if you have any angle at all, which always happens in a hard launch.
The Following User Says Thank You to Kido1986 For This Useful Post: | ericmpena (08-29-2013) |
08-29-2013, 09:46 AM | #13 |
Drives: 2013 Firestorm
6.7 stock at
08-29-2013, 10:29 AM | #14 |
Drives: '08 328i, '13 Accord Sport, '13 BRZ
What I would really like to know is what are the 0-60 times for Vortech SC BRZs....
nobody seems to post their data outside of whp and dyno sheets. |
Similar Threads | ||||
FI Track Times | wrxgoose | Forced Induction | 0 | 07-24-2013 02:17 PM |
Fun times | John.Hong | FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum | 0 | 07-24-2013 03:46 AM |
0-60mph Times | boredom.is.me | Scion FR-S / Toyota 86 GT86 General Forum | 81 | 03-03-2013 02:43 PM |
How many times have you been pulled over? | IloveBaldEagles | Scion FR-S / Toyota 86 GT86 General Forum | 71 | 11-28-2012 11:28 AM |
Visconti 0-60 times | cuddefred | Engine, Exhaust, Transmission | 0 | 09-26-2012 08:06 PM |
