Tracking / Autocross / HPDE / Drifting What these cars were built for! |
08-09-2013, 04:24 PM | #1 |
Drives: 2013 Firestorm FR-S
Can the stock rotors and pads hold up to light auto-x duty?
going to start doing a bit of auto-x for fun and I haven't made any break system modifications to this point. Can the stock rotors and pads hold up to 5-6 spaced out runs? I'm a novice at this point so I'm not going to be 10/10ths around the course.
2013 Firestorm FR-S, MTX, build date 1/13.
08-09-2013, 04:28 PM | #2 |
Driving Enthusiast
Drives: 2013 BRZ Limited
stock brake system has held up well for spirited canyon driving for me. Never done any autoX yet. Also need to consider your track layout. Are there long straights where the brakes can cool or is it all corners?
“This isn’t a supercar, it’s a sports car. It sacrifices rear seats yes but it just feels alive. Pure, direct, immediate. The other two are going to get all the admiring looks yes, that’s my point. I’m not driving around in this for other people’s benefit. I’m driving around in this BECAUSE I LOVE DRIVING IT. END!”
-Richard Hammond, Top Gear, USA Supercar Road Trip, 2011 Porsche GT3 RS.My BRZ |
08-09-2013, 04:33 PM | #3 |
AutoX Nut
Drives: 2022 BRZ
I've had my BRZ on the stock rotors, pads, and fluid for 14 months and have about 20 Autocrosses and 11,000 miles under my belt. I've never experienced brake fade and my pads and rotors are holding up fine.
You won't be going fast enough or running long enough on a typical AutoX course to worry the brakes too much, so just go out there and have fun! |
08-09-2013, 04:33 PM | #4 |
head of infinite swagger
Drives: 2013 FR-S 6MT
100% yes, I've done 4-5 events with my car with zero issues.
The biggest issue with the stock system is that the pads fade, you wont get them hot enough at auto-x to make them fade.
2019 Golf R 6MT - current daily...I need another coupe
2008 Civic Si - winter beater 2000 Silverstone M5 6MT - SOLD 2013 Ultramarine FR-S 6MT - Car Journal - SOLD 2004 AlpineWhite M3 6MT - SOLD |
08-09-2013, 04:53 PM | #5 |
thanks, I appreciate the feedback.
08-09-2013, 06:36 PM | #6 |
Drives: 13 BRZ - 90 Miata - 07 FXT -05 Mini
Yeah, normal autocrosses won't tax the stock brakes at all. I ran mine several events last season, and have done 5 or 6 this season, most with a co-driver, sometimes with a 3rd driver in another class, and the brakes have held up very well. Only time at an autocross type event where they might start to give you problems is at a test and tune or driver's school where you might be going back out for repeated back to back runs (and I'm talking dozens of runs over the course of the day).
17x7 Kosei K1-TS w/ 215/45-17 Dunlop Star Specs
Nameless Track Pipe - Strano front sway bar |
08-09-2013, 08:00 PM | #7 |
Drives: 2013 WRB Subaru BRZ 6MT
Yes, you should have no problems with the stock pads and rotors for autocross. For HPDE events I would recommend at least a brake fluid change and brake pad change.
08-10-2013, 08:59 AM | #8 |
What if any downsides exist to switching to higher performance brake fluid? The only thing my research has shown is dot 5 is less able to absorb water. Does it have any other negative daily driving effects?
08-10-2013, 09:58 AM | #9 | |
You'd need to change the fluid more regularly, but what this really means, is that unless you boil it, you need to religiously change it once a year. |
08-10-2013, 10:23 AM | #10 |
Detroit Region, MI
Drives: 13 BRZ, 13 Volt, 02 WRX
I've had a little bit of fade one time when my car had 3 drivers at one event, otherwise no issues. I think a mild pad upgrade (like a stoptech street pad) will be beneficial if you are running a higher grip road tire, but it's certainly not a necessary upgrade.
Detroit / NWOR SCCA Member
2005-06: #192 ES 91 MR2 N/A Hardtop 2007-08: #54 STX 05 WRX Sedan 2009-12: #92 BSP/ASP 07 Solstice GXP 2013-14 : #192 CS 13 Subaru BRZ |
08-10-2013, 11:25 AM | #11 |
Drives: 2013 FRS Asphalt
I have 327 Autocross runs on my car between the two seasons. Still on stock pads and fluid and run a co-driver all the time. 15kmiles. Pads are still strong. No issues.
2013 Scion FR-S AT Picked up 5/30/2012
08-10-2013, 01:17 PM | #12 |
With Dot 4 do you need to change it every year or just Dot 5?
Similar Threads | ||||
DBA Rotors & StopTech Brake Pads IN STOCK, FREE SHIPPING | Import Dynamics | Brakes, Suspension, Chassis | 26 | 04-30-2013 08:05 PM |
Selling stock FRS Springs/Struts + Stock Pads + Rotors 6k on all! | NickFRS | Brakes, Suspension, Chassis | 6 | 03-14-2013 01:38 AM |
GTS OEM rotors and pads | yomchi1989 | AUSTRALIA | 1 | 12-30-2012 04:47 PM |
Stock pads + rotors + springs/struts for sale in Gladstone Oregon 6k miles | NickFRS | Northwest | 2 | 12-23-2012 01:03 AM |
DBA rotors w/ stock pads | yomchi1989 | AUSTRALIA | 16 | 12-12-2012 07:46 AM |
