Engine, Exhaust, Transmission Discuss the FR-S | 86 | BRZ engine, exhaust and drivetrain. |
03-20-2012, 11:58 PM | #1 |
the way of engine and gearbox system work?
I will explain my friend how the car engine works and it moves the car.
So, could you please tell me the chronological order in a very simple way? From "turning the ignition on" to "exhausting the gas" can you please set the order in simple sentences? A technical video or such links are also highly welcome. Thanks in advance & cheers! |
03-21-2012, 01:25 AM | #2 |
Re-member
Drives: Toyota camry
Entire books are written about this so a forum is not the best starting point, perhaps if you had specific questions we could better help. Your best bet is to go to youtube and find some computer animated videos. If you really are interested go buy a 1/4 scale clear plastic model (1/4 Visible V-8 Engine by Revell-Monogram) for about 50 bucks. These scale models are usually older outdated engines but are a great foundation to learn from. Also assembling the parts yourself really helps you to understand everything. I assembled mine in a day. First things first, google the terms ''4 stroke engine''.
Basically air is sucked into the engine through the air box and air intake, it then mixes with fuel, this mixture is sucked into the combustion chamber where it then get compressed, then a spark ignites it, it explodes and expands. This expansion causes a complex mechanical movement of parts which ultimately turn the wheels. After the explosion there is left over gas which is basically unusable and it get forced out through the exhaust manifold and muffler. I would really check out a book or that scale model . FYI the scale models uses a hand crank to turn and you can see all the parts move. Its pretty good and only overlooks a few minor things, its about as good a starting point as you will find.
Nothing decays like progress, and nothing preserves like neglect.
03-21-2012, 08:23 AM | #3 |
That Guy
Drives: 2013 asphalt FRS MT
03-21-2012, 11:27 PM | #4 |
Drives: car
howstuffworks.com
[/thread] |
03-21-2012, 11:36 PM | #5 |
Hot Dog
Drives: quicker than arghx7
Too funny, I was just going to say that. It's a good site for the very basics in a reasonably illustrated format.
"Wisdom is a not a function of age, but a function of experience."
Just Say No to unqualified aftermarket products. |
03-21-2012, 11:50 PM | #6 |
How does an automatic transmission system in automobiles work?
03-21-2012, 11:52 PM | #7 |
Delights in pure handling
Drives: Zoom Zoom
03-22-2012, 12:27 AM | #8 |
Not.. sure if serious..
I am the Ice Queen.
Logic > Emotion ┬──┬◡ノ(° -°ノ) Yashio Factory Pink adds +10HP to anything. TOYOTA FT-86 |
Similar Threads | ||||
UK work | Giccin | EUROPE | 5 | 02-09-2012 01:21 PM |
6-speed mannual gearbox info | Lottta | BRZ First-Gen (2012+) -- General Topics | 17 | 02-01-2012 10:33 PM |
Got a little bit of work done on my S14 today | MrVito | Other Vehicles & General Automotive Discussions | 23 | 01-15-2012 10:00 PM |
Off to Work! | Exage | Off-Topic Lounge [WARNING: NO POLITICS] | 2 | 09-16-2011 11:04 PM |
Does anyone work for Toyota? | MTD | Scion FR-S / Toyota 86 GT86 General Forum | 7 | 10-25-2009 07:40 PM |
