Electronics | Audio | NAV | Infotainment Anything related to in-car electronics, navigation, and infotainment. |
07-31-2013, 06:58 PM | #1 |
Addicted
Drives: 2013 Asphalt FR-S 6MT
BeSpoke Backup Camera on Relay
Hey can someone check my diagram for installing a 12V backup camera on a relay? Limited experience in circuits so I want to be safe.
07-31-2013, 07:10 PM | #2 |
Drives: Subaru BRZ Limited
thats good. I would make sure you add in fuse on the 30 side where you tap your power.
07-31-2013, 07:14 PM | #3 | |
Addicted
edit: Which fuse can I safely use an "add-a-fuse" to that is 12V? On the driver's side box I only see ECU ACC
07-31-2013, 10:24 PM | #4 |
Grip>Slip
07-31-2013, 11:02 PM | #5 |
Drives: 2013 FR-S, 2016 Miata Club
08-01-2013, 12:05 AM | #6 |
Addicted
Relay basically is a switch that tells the camera to turn on when the "trigger" tells it too. If you don't use a relay or another method the camera will constantly be powered on (even when the headunit isn't displaying the video) when the car is on instead of just when in reverse.
08-01-2013, 01:18 AM | #7 | |
08-01-2013, 01:27 PM | #8 |
Addicted
Do you know if I tap the cigarette lighter wire that I already tapped for my LED DRL strips would it still supply enough voltage to power the backup camera? Or would it cause any other problems having too many things on this one line?
08-01-2013, 01:28 PM | #9 | |
Addicted
08-01-2013, 01:42 PM | #10 |
Grip>Slip
i can't imagine it would be a problem. the amount of power your backup camera draws is VERY low.
08-01-2013, 02:27 PM | #11 |
Yeah, I was actually wanting to install a front camera as well for parking close to curbs. As low as our fronts are, I'd hate to "tuck" it under one day because of those tire/parking curb things. That and other uses. I'll have to work on a circuit for that.
08-01-2013, 02:58 PM | #12 | |
Drives: 2013 10 series FRS #944
On the 16 pin harness, there is a power out. You should connect your camera to that power out. That power out is only on momentary when your HU is boot up, it trigger the camera and therefore telling HU that there is camera installed. Here is the thread to talk more detail about this; http://www.ft86club.com/forums/showthread.php?t=36323 Last edited by #944_10_Series_FRS; 08-01-2013 at 03:03 PM. Reason: Link to the DIY section on installing backup camera |
The Following User Says Thank You to #944_10_Series_FRS For This Useful Post: | nalc (08-02-2013) |
08-01-2013, 03:31 PM | #13 | |
Addicted
The camera video wire will always have a direct connection to the 16pin. It just won't be powered on until I put it in reverse.
08-01-2013, 03:55 PM | #14 | |
http://ae64.com/Rear-camera-install-16p-BeSpoke.htm http://ae64.com/Rear-camera-16p-operation.htm Good luck! |
Similar Threads | ||||
DIY Backup camera for BeSpoke and 2014 Pioneer | post_break | DIY (Do-It-Yourself) Guides | 48 | 06-01-2017 12:57 PM |
Scion FRS Bespoke Backup Camera, What do I need? | post_break | Electronics | Audio | NAV | Infotainment | 8 | 07-02-2016 09:55 PM |
Help installing backup camera / setting up AV on BeSpoke? | l0aded | Electronics | Audio | NAV | Infotainment | 11 | 07-18-2013 08:05 PM |
Beat-Sonic Backup Camera & Adapter for FR-S (Bespoke) & BRZ Special Price | Beat-Sonic | Audio/Visual, Electronics, Infotainment, NAV | 60 | 07-15-2013 03:58 PM |
Backup Camera Help | husker741 | Electronics | Audio | NAV | Infotainment | 2 | 02-13-2013 01:04 AM |
