Old 06-20-2013, 02:24 PM   #1
Imprezzave
Drives: BRZ TS
Send a message via AIM to Imprezzave
Ticking/Rattling coming from steering column/gauge cluster
Have any of you guys noticed a ticking, almost vibrating sound coming from the steering column/gauge cluster area when driving on rough roads? It sounds like someone tapping the edge of a coin on a piece of metal. I'm thinking it might be some clips rattling against the metal underneath the dash.
With that said, any of you guys know how one would start to remove the plastic covering the steering column and possibly the gauge cluster?
Imprezzave is offline   Reply With Quote
The Following User Says Thank You to Imprezzave For This Useful Post:
SloS14 (06-20-2013)
Old 06-23-2013, 06:56 PM   #2
Cadenz
Drives: Subaru BRZ SWP Limited 2013
I just start hearing this at low speeds on bumpy roads. It goes away when I put pressure on the plastic covering located above the pedals / below the gauges. Haven't been able to investigate more since it just started happening.
Cadenz is offline   Reply With Quote
Old 06-23-2013, 09:14 PM   #3
Chele
Drives: WR Blue BRZ
I'm having a few cabin noises that I'm bringing it to the dealership. The car has 1200 miles. I've had a legacy for 4 year with only one minor noise when its left in the sun. This car feels like its going to be a maraca in a year or two. I have one coming from the drivers side door, one near the passenger dash speaker, and the one that you guys are describing.
Chele is offline   Reply With Quote
Old 06-23-2013, 09:24 PM   #4
Burrcold
Drives: Subaru BRZ Limited
I get the odd clunk from the steering column but not ticking. Unless my clunk = your ticking
Old 06-23-2013, 10:47 PM   #5
Sigh-on-Rice
Waited 5 years for this
Sigh-on-Rice's Avatar
Drives: '18 MX-5 Club
I had a clicking noise coming from the steering column. And I noticed it went away when I release the lock. When I locked it, it started to make the noise right away. I found out, if I lock it about 95% of the way, then it doesn't make noise. After I left it there for a few days, I locked it all the way and it doesn't make the noise anymore.
Sigh-on-Rice is offline   Reply With Quote
Old 06-24-2013, 03:44 PM   #6
Imprezzave
Drives: BRZ TS
Thanks for your input guys, I guess this is just normal, but it is really annoying to hear the tick, tick, tick, tick, when going over a rough patch of road.
Old 06-25-2013, 05:37 AM   #7
sdshores08
sdshores08's Avatar
Drives: 2013 Ultramarine FR-S, AT
This noise just started for me. I've had my car for a year and just hit 9,000 miles
sdshores08 is offline   Reply With Quote
Old 06-25-2013, 05:59 AM   #8
sc0urge
sc0urge's Avatar
Drives: 2013 BRZ CBS
My car was making similar sounds in similar situations awhile back. I guessed the sound was coming from the dash or radio/AC cluster but holding down/manipulating the pieces there didn't really seem to change anything when the sound was present. I finally, by coincidence or luck, noticed that some piece of my mirror assembly was loose (I have the Homelink mirror, BRZ btw). It wasn't the mirror itself, rather the assembly that's attached to the windshield. In any case, I kind of shifted/played with the assembly a little and haven't had a problem since. Might not be the issue for you but hopefully this will be helpful to someone else reading. Good luck!:happy0180:
sc0urge is offline   Reply With Quote
Old 06-25-2013, 10:26 AM   #9
Hawaiian
That guy
Hawaiian's Avatar
Drives: Ultramarine mt FR-S
I had a tick coming from the turn signal stalk. I took it in and got it replaced under warranty after recording a video of the noise on my phone.
Ultramarine mt FR-S
P&L stage 1 turbo
Prime Motoring Flex fuel
Jr Tuned 506whp @17psi (e73)
The Following User Says Thank You to Hawaiian For This Useful Post:
Efferalgan (07-04-2014)
Old 06-17-2014, 07:36 AM   #10
omega_factor
Drives: Toyota 86 GTS Black Manual
The dealership where I bought my 86 recently agreed to look into my annoying dash rattle / ticking sound. After 2 days it was given the all clear and I confirmed that they had at least opened up the cluster. Driving out of the dealership I heard the sound literally as I got onto the first road. I guess they weren’t sure what to listen for, as it’s not always prevalent, only certain roads cause the noise. Anyhow, I suggested that I would record it and also find a road near them where they can recreate the sound to verify. Anyhow, here is my first recording, I found it happens quite intensely on tram track type concrete, going uphill. A friend was filming and I was going under 60kms. The iPhone does make it sound more tinny than normal, but regardless, it’s no longer fun driving this car!
[ame]http://youtu.be/eXj11ZZVuz4[/ame]
omega_factor is offline   Reply With Quote
Old 07-04-2014, 10:20 AM   #11
Efferalgan
Drives: 2025 BRZ, ex-2012 GT86
I have the same problem: when the turn signal is engaged and you turn the steering wheel in that direction, it clicks roughly every 1/3 of the wheel rotation. It's clearly related somehow to the turn signal stalk return mechanism. Brought the car to the dealer, they dissasembled the steering wheel column and said that visually there are no issues. Now checking with Toyota guarantee officer. Will post what the outcome of the story is.
Efferalgan is offline   Reply With Quote
Old 07-28-2014, 09:57 AM   #12
Sleeper86
Drives: FT86 GTS white AT
wow I thought I was the only one, we got the exact same noise, I would assume the dealer wouldn't do anything about it as it's difficult to pin point where from, and I don't want to leave my car there with the dealer for a day or two, might be more harm done to it than goods, really hope someone from Toyota can hear this clip and let us know what is the problem. good job with the video mate, I tried recording the noise with my iPhone but the sound quality is worse than yours.
Sleeper86 is offline   Reply With Quote
Old 08-07-2014, 08:44 PM   #13
h8meh8ers
Drives: 2014 FR-S
any update on this? i've had the car for a week and a half and only have 600 miles and i've already got this rattle. i came from a 97 buick that didn't have any rattles at all, so it's surprising that this happened so quickly
h8meh8ers is offline   Reply With Quote
Old 08-09-2014, 06:19 PM   #14
bottle
Also interested on any information about this. Only happens over moderate to large bumps.
bottle is offline   Reply With Quote
Steering Column Creak michaelahess Issues | Warranty | Recalls / TSB 12 06-27-2018 02:14 AM
Gauge Cluster on FRS tonytduc Scion FR-S / Toyota 86 GT86 General Forum 16 07-24-2017 10:56 PM
Custom Gauge Cluster? Ingen Cosmetic Modification (Interior/Exterior/Lighting) 34 07-03-2014 11:41 PM
WTB: Steering Column Cover (top one) Jamifra Interior Parts (Incl. Lighting) 6 11-27-2012 10:20 AM
How to remove steering column trim? Gen Electronics | Audio | NAV | Infotainment 1 10-29-2012 01:36 AM
