Engine, Exhaust, Transmission Discuss the FR-S | 86 | BRZ engine, exhaust and drivetrain. |
06-09-2013, 03:18 AM | #1 |
Drives: Whiteout FRS
Gaskets & Headers question
Did you guys re-use the header to block gaskets and/or header to overpipe gasket or did you guys purchase new ones when installing an aftermarket header? If re-use how many miles did you guys have on the gasket(s)? I know it's best to purchase new ones but I feel that my gaskets are still re-usable (w/ 3k on them). What are your thoughts on this?
06-09-2013, 03:51 AM | #2 |
Drives: 1995 Acura Integra GS-R
Didn't do headers myself yet, but the rest of my exhaust system (Invidia) came with new gaskets. I'd probably pick up new ones, but I've once reused an old one that was falling apart since I could not get a replacement. Just added some RTV and called it a day.
06-09-2013, 10:17 AM | #3 | |
Drives: 2013 Asphalt FR-S
Asphalt FR-S: EcuTek Visconti STG2 tune, MAPerformance turbo kit, MAPerformance 3" exhaust, Hotchkis springs, Mach-V 17x9 Awesomes.
Build thread: http://www.ft86club.com/forums/showthread.php?t=30703 |
06-09-2013, 10:42 AM | #4 |
Generally speaking you don't reuse any metal gasket, that being said many people do without harmful effects.
06-09-2013, 11:17 AM | #5 |
Drives: argento frs; 90 mustang gt
i got new gaskets all around. why risk redoing the work and losing time driving? spend the extra 30 some dollars on this investment..
The Following User Says Thank You to sinigang_guy For This Useful Post: | kodyo (06-29-2015) |
06-09-2013, 11:44 AM | #6 |
Drives: 2013 Scion FR-S Raven
Header gasket Part numbers?
May'12 AT Raven, OFT V2, Perrin IntakeTube, Pulley & Overpipe,HKS Snorkel,FA20 EL Header,Nameless Frontpipe w/ Helmholtz, Crawford AOS, Cusco O2W Cooler, Grimmspeed Strut/MC Brace, Winjets w/D2S 3.0 HID by Illuminating Lighworkx, Fogs w/EU Stalk, LED's, JDM UnderPanels, Diffuser, Rigid Collars, Whiteline, HVT Camber Plates, Koni's, Swift Springs, GTSpec LCA, SPC Toearms, DBA 4K T-Slot Rotors, Ferodo DS2500, Vorshlag BrakeLines, MichelinPSS, 5Axis Wing, Raammat, Ensolite, JPM Coachworks, OEM+Ref400, 20mmspacers, TOMS
06-09-2013, 12:05 PM | #7 |
06-09-2013, 12:32 PM | #8 |
Drives: 2016 STi DGM
Rev Works provides gaskets but I reused my stock gaskets. (They were in great shape). Rev works sells OEM type gaskets. I did. Use their provided gasket from header to perrin over pipe. No issues.
-2014 SSM BRZ MT
06-09-2013, 12:34 PM | #9 |
Thank you
06-09-2013, 04:25 PM | #10 |
Alright. I'll see if I need to replace them first depending on how it looks when I take off the headers. Does the grimspeed gaskets come for both the headers & the overpipe or just the headers?
06-29-2015, 07:47 PM | #11 |
Drives: Scion Frs
What kind of gasket is in-between the catalytic convertor and the rear exhaust section of the OEM exhaust of the frs?
06-29-2015, 07:53 PM | #12 |
Drives: Scion Frs
Is it a donut shape gasket or flat gasket
06-29-2015, 07:54 PM | #13 | |
Drives: Scion Frs
Is it donut gasket or flat gasket? |
06-30-2015, 12:52 PM | #14 |
Senior Misanthrope
Similar Threads | ||||
Headers | Fenris20 | Engine, Exhaust, Transmission | 1 | 06-04-2013 02:06 PM |
Headers | cuddefred | AUSTRALIA | 4 | 05-25-2013 06:16 PM |
question for guys with headers | Xdragonxb0i | Engine, Exhaust, Transmission | 22 | 04-22-2013 12:49 PM |
HKS Stopper Head Gaskets for FRS and BRZ | Hal@Dynosty | Engine, Exhaust, Bolt-Ons | 7 | 07-03-2012 07:48 PM |
Header gaskets | Motordyne | Engine, Exhaust, Transmission | 1 | 06-23-2012 04:31 PM |
