Electronics | Audio | NAV | Infotainment Anything related to in-car electronics, navigation, and infotainment. |
06-03-2013, 07:28 PM | #1 |
JDM Vaping Stance Nation
Drives: 2013 White
BeSpoke Back Up Camera Help
I'm following post_break's guide here:
http://www.ft86club.com/forums/showthread.php?p=952117 But I can't seem to get the wiring right. Seems like I'm doing it right but nothing shows up. Tapping into the 12v from the acc plug in the glovebox. |
06-03-2013, 09:46 PM | #2 |
Drives: 2013 frs white out
try to tap a signal from a different place, i used the green wire on the amp ... as long as you have 12v in postions on acc and run you are on the money!
" Knowledge is nothing with out execution"
06-03-2013, 09:51 PM | #3 | |
Drives: 2013 White
The 12v Power works no matter what, so I tried (with test light) to connect that wire to the "trigger wire". Test light didn't light up. Connected it to the Reverse light and it still did nothing. So the problem has to either be the Trigger Wire (Since the BeSpoke isn't going into that mode). Or the Video RCA since it isn't popping up (haven't tested the wire/power to the Video RCA). |
06-09-2013, 12:13 PM | #4 |
Drives: 2013 White
Figured out what it was. The video RCA wires had to be reversed. The Ground is on Botton Left while the Positive is on the Top Left.
Similar Threads | ||||
DIY Backup camera for BeSpoke and 2014 Pioneer | post_break | DIY (Do-It-Yourself) Guides | 48 | 06-01-2017 12:57 PM |
Scion FRS Bespoke Backup Camera, What do I need? | post_break | Electronics | Audio | NAV | Infotainment | 8 | 07-02-2016 09:55 PM |
Bespoke camera menu? | toddj55 | Electronics | Audio | NAV | Infotainment | 2 | 04-22-2013 08:17 PM |
OEM Back up Camera | Perihelion | Electronics | Audio | NAV | Infotainment | 11 | 03-25-2013 04:49 PM |
anyone interested in a bespoke unit w reverse camera? | xpicer | NY / NJ / CT / PA | 3 | 11-03-2012 06:57 AM |
