Old 06-01-2013, 08:50 PM   #1
86_ZN6
86_ZN6's Avatar
Drives: 86 ZN6
Question High Pressure Fuel Pump Difference? Toyota vs. Subaru
Is there a difference on the toyota pump and subaru highr pressure fuel pump?
Each one has their own part number and price.
Subaru costs around $580
But the toyota one is like $1300. Almost double.
What do yoy guys think?
I need to replace mine asap and need to know if there is a difference or not
86_ZN6 is offline   Reply With Quote
Old 06-01-2013, 08:57 PM   #2
johnb831
johnb831's Avatar
Drives: SWP 2013 Subaru BRZ Limited
Doesn't both cars have the same pump? How come u need to replace urs?
johnb831 is offline   Reply With Quote
Old 06-01-2013, 08:58 PM   #3
LavosTRD
Toyota Master Tech
Drives: Whiteout MT
Same pump. All of toyota's parts that they source from subaru start with SUxxx-xxxxx. Hence the subaru # is more a standard part number. Toyota probably has to "buy" them from subaru, hence the mark up on top of mark up. Just my speculation
LavosTRD is offline   Reply With Quote
Old 06-01-2013, 09:01 PM   #4
Sportsguy83
I Love custom Turbo kits
Sportsguy83's Avatar
Drives: Limited BRZ
There are a lot of parts that cost a lot more in the Scion dealer. It's the same. How are you 1000% certain the problem is the HPFP??
Old 06-01-2013, 09:54 PM   #5
86_ZN6
86_ZN6's Avatar
Drives: 86 ZN6
Still getting the p1235 and a new P0625D codes.
Ecu was reflashed to stock, in tank FP was replaced and still the car will not start
Old 06-01-2013, 10:08 PM   #6
Sportsguy83
Drives: Limited BRZ
Tell your tuner to set the car to run 100% on the port injectors, start it. Then the same for HPFP (car shouldn't start), that way you can be 100% sure its the HPFP.
The Following User Says Thank You to Sportsguy83 For This Useful Post:
mad_sb (06-02-2013)
Old 06-02-2013, 08:06 AM   #7
mad_sb
Drives: 2013 Asphalt FR-S
Did you / they test the injector driver? That is where the signal comes from . Per the FSM:
INSPECTION PROCEDURE
HINT:
If the current from the INJ relay is cut because DTC P062D is stored, DTC P1235 will be stored
even if the fuel pump assembly (for high pressure) is normal
Did you ever have any one of P1261,2,3 or 4?
The Following 2 Users Say Thank You to mad_sb For This Useful Post:
charged86 (06-02-2013), Sportsguy83 (06-02-2013)
Old 06-02-2013, 12:29 PM   #8
LavosTRD
Toyota Master Tech
Drives: Whiteout MT
Your ecu needs a dealer reflash.
Old 06-02-2013, 12:56 PM   #9
86_ZN6
86_ZN6's Avatar
Drives: 86 ZN6
Already did that 5 months ago
Im running JA00C
Old 06-02-2013, 12:59 PM   #10
LavosTRD
Toyota Master Tech
Drives: Whiteout MT
Ok, in that case I would be ordering you a new injector driver ecu
The Following User Says Thank You to LavosTRD For This Useful Post:
86_ZN6 (06-02-2013)
Old 06-02-2013, 01:06 PM   #11
86_ZN6
86_ZN6's Avatar
Drives: 86 ZN6
HINT:
I have to check. But no other codes just the 2.
Did you get that procedure on TIS?
I have access to it but cat find it
Old 06-02-2013, 02:30 PM   #12
86_ZN6
86_ZN6's Avatar
Drives: 86 ZN6
HINT:
nvm, i found it on TIS
Old 06-02-2013, 03:16 PM   #13
charged86
charged86's Avatar
link?
INSTAGRAM @Rcf_700 www.youtube.com/boostindub
Old 06-02-2013, 03:21 PM   #14
86_ZN6
86_ZN6's Avatar
Drives: 86 ZN6
Originally Posted by charged86 View Post
link?
it's a subscription service. you need to pay to gain access
Why does the fuel pump not do well with ethanol? boredom.is.me Engine, Exhaust, Transmission 42 02-28-2019 06:21 PM
AEM High Flow In-Tank Fuel Pump JPxM0Dz Engine, Exhaust, Transmission 0 04-13-2013 12:15 PM
FS: Visconti Fuel Pump Sportsguy83 Engine, Exhaust, Bolt-Ons 0 03-31-2013 04:45 PM
Car fuel pump on... Genomaxter Engine, Exhaust, Transmission 5 11-29-2012 10:06 AM
Dynosty FR-S/BRZ Fuel System Upgrades! Deatschwerks DW65C Fuel Pump Dustin@Dynosty Engine, Exhaust, Bolt-Ons 3 08-21-2012 04:53 PM
