Old 05-15-2013, 02:57 PM   #1
subiesteve
subiesteve's Avatar
Drives: 2013 Subaru BRZ Premium Galaxy Blue
Exclamation transmission or diferential peoblem? CLICK/TICK
I get a click/tick every time I shift it happens when I release the clutch and use the gas. It will also do it at 3000 RPM coasting then when I return to accelerating again I hear this CLICK. It even does it in reverse. feels like it happens when the gear is engaged. ANYONE HAVE THIS?
subiesteve is offline   Reply With Quote
Old 05-15-2013, 03:12 PM   #2
frslee
Just drive it
Drives: 13' FR-S
I hear slight click when I push the clutch. Just curious.
frslee is offline   Reply With Quote
Old 05-15-2013, 06:00 PM   #3
EZWood
BAMF
EZWood's Avatar
i hear something that may be similar. to me it sounds like the e brake being angaged or possibly disengaged while moving.
Old 05-15-2013, 06:06 PM   #4
Wo6M
Keep Calm And Drift On~
Wo6M's Avatar
Drives: Scion FR-S WhiteOut 6 Speed Manual
This sounds a lot like a differential action , the hypoid pinion gear is in contsnt mesh with the ring gear of the torsion style diff. The ring gear has two sides, the cost side and drive side aka faces . Now of the tolerance is not correct and too far apart I e not preloaded enough you will get a click from th e rear end when
Getting into gear I e moving
Let off the gass and cost
Uneven shiffting.
I'm pretty sure warranty would cover this but I would get it checked out. .
2013 Scion FR-S White Out Six Speed Manual
Mods:
Wo6M is offline   Reply With Quote
The Following User Says Thank You to Wo6M For This Useful Post:
gonzo (05-29-2014)
Old 05-23-2013, 11:04 PM   #5
Sookainian
Sookainian's Avatar
Drives: Toyota GT86
Same too, I get a click/tick every time I shift it happens when I release the clutch and use the gas
Sookainian is offline   Reply With Quote
Old 05-24-2013, 07:58 AM   #6
chenshuo
chenshuo's Avatar
Drives: WRB BRZ
Check your pedals. My gas pedal makes a click noise when i lightly step on it. I took it to the dealer, they acknowledged the clicking noise but said thats normal nothing wrong.
chenshuo is offline   Reply With Quote
Old 05-27-2013, 07:01 PM   #7
SMOKETREES
Lowered Lifestyle
SMOKETREES's Avatar
Drives: Scion Fr-S
I get this too. Thought at first was an exhaust situation but nope def sounds like its coming from clutch/tranny or diff..
SMOKETREES is offline   Reply With Quote
Old 05-27-2013, 07:23 PM   #8
charged86
charged86's Avatar
Haven't heard this click yet. Had it on another vehicle it crunched as I shifted like a the master cylinder was fucked up
INSTAGRAM @Rcf_700 www.youtube.com/boostindub
Old 05-30-2013, 10:35 PM   #9
vtmike
vtmike's Avatar
Drives: Scion FR-S
My car does this too. Just started to notice it around 8500 miles. It happens when there is an abrupt acceleration. Wasn't sure if it was drivetrain or what. Some cars with exhaust have had issues where it will shift and contact something when accelerating (I have an aftermarket exhaust.) Some other kinds of cars (Mazdaspeed 3, focus st) have motor mounts that allow the engine to move enough to contact the firewall. Was wondering if that's a possibility.
One thing in my particular case that might rule out drivetrain is I can induce the sound by punching the throttle for a rev match or just abruptly applying throttle while not in gear.
vtmike is offline   Reply With Quote
Old 06-04-2013, 10:18 PM   #10
vtmike
vtmike's Avatar
Drives: Scion FR-S
Anyone have any updates on this? I checked out the exhaust bolts and everything seems snug.
Mine is a particularly loud clank noise when doing a fast redline shift from 1st to 2nd when releasing clutch and applying throttle going into second.
Apparently the stock transmission mount has some play in it from the factory. Wondering if this is it.
Old 06-05-2013, 10:30 AM   #11
Carwhisperer
Drives: A lot of supercars.
Mine does it going 5 mph in 1st gear all the time. Little throttle, let off *tick* high pitch ticking noise. No idea.. Glad im not the only one experiencing this.
Carwhisperer is offline   Reply With Quote
Old 06-05-2013, 11:01 AM   #12
vtmike
vtmike's Avatar
Drives: Scion FR-S
I'm wondering if it's a motor/transmission mount working it's way loose, or if it's the tob. A coworker with a wrx said to look at the pitch stop mount. Looks like the exact same part as the wrx.
After a little research, it looks like the stock pitch stop mount is really cheap and a lot of wrxs with the stock one make the same noise when shifting. Think I might pick up a pitch stop in the near future.
Never mind, the car doesn't have a pitch stop mount. So maybe the transmission mount.
Sent from my SCH-I535 using Tapatalk 4 Beta
Old 06-11-2013, 03:31 PM   #13
EZWood
BAMF
EZWood's Avatar
Any news on this?
Old 06-11-2013, 03:39 PM   #14
Carwhisperer
Mines still doing it especially when I let out the clutch, sometimes i'll hear it come from the right side of the car, sometimes the left side of my car. Usually its just 1 tick, but sometimes its 3 ticks back to back really fast.
lifter tick? DarkCard Issues | Warranty | Recalls / TSB 11 02-07-2016 01:51 PM
Tick tick tick from the dash FRiSson Issues | Warranty | Recalls / TSB 23 06-12-2013 05:11 PM
Tick Click Tick (injector orgy) empower-auto Issues | Warranty | Recalls / TSB 4 08-27-2012 02:28 PM
Tick Tick injuryexpert Engine, Exhaust, Transmission 3 08-21-2012 08:31 AM
topspeed difference between manual transmission and automatic transmission torquemada BRZ First-Gen (2012+) — General Topics 51 05-04-2012 07:54 PM
