Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack Specific topics relating to wheels and tires. |
05-07-2013, 10:14 AM | #1 |
Hail Magnet
Tire Rotation Interval Questions
Search Disclaimer: Did a search, couldn't find anything, so my apologies if this is a repost.
So as I get closer to my oil change/tire rotation interval, I looked in the manual and it shows the rotation as merely switching the front and rear tires, and not crossing them (putting them on the other side of the car). So, Noob questions: Are the tires or the car designed so that you are only supposed to swap front and rears, not switch sides? Manual recommends 7500 mi for rotation, same as oil changes. Should the tires be rotated more often than that? I've been used to rotating them every 5k miles. Thanks guys. |
05-07-2013, 10:21 AM | #2 |
Just drive it
Drives: 13' FR-S
I think the tires can be rotated either way; front to back or cross.
I guess only front to back rotation applies if your tires are directional. For frequency... I think 7500 is fine for stock setup. If you run some camber, I'd rotate it every 5000 miles. |
The Following User Says Thank You to frslee For This Useful Post: | HunterGreene (05-07-2013) |
05-08-2013, 06:45 AM | #3 | ||
Drives: 2013 BRZ Ltd. MT
The Michelin Primacy HP tires are not directional; therefore, the typical cross-pattern rotation is best. Directional tires will have the direction marked on the side of each tire, typically with a big ARROW. The arrow points forward in the direction of the car’s travel, the direction the tire will rotate when moving forward. If your FR-S has the Bridgestone all season tires, I cannot say, as I’m unfamiliar with them. But, just examine the tire sidewall to see if there’s a directional arrow on the tire. If “Yes,” then keep the tire on the same side, moving it only front to rear, etc. Otherwise, move the rears straight forward, and cross the fronts over to the back. Repeat as often as you like, but 5000-7500 miles is generally recommended in normal use. Quote:
The Following User Says Thank You to Porsche For This Useful Post: | HunterGreene (05-08-2013) |
05-08-2013, 08:18 AM | #4 | |
Hail Magnet
05-12-2015, 03:18 AM | #5 | |
Drives: 2015 BRZ Ltd 6MT
It's kind of like how the maintenance schedule has that extra line just for BRZ's since there's no center differential. So the Michelin Primacy HP is definitely asymmetrical. The tread pattern is different on both sides, one side has more "curved" fins, while the other is more "straight". Even though it's asymmetrical, can anyone confirm if it's directional or non-directional? |
05-12-2015, 08:06 AM | #6 |
Rotating tires won't help with camber wear, unless you have way worse wear on one end of the car. The only way to even out camber wear is to flip the tires on the wheels.
Definitely not directional. If it's asymmetrical and directional you would see them stamped "left" or "right" as well as with an arrow indicating direction of rotation. There are very few asymmetrical directional tires on the market.
The Following User Says Thank You to wparsons For This Useful Post: | Ultramaroon (11-03-2016) |
11-03-2016, 04:24 PM | #7 |
Drives: Civic Hyb, RS6, BRZ SeriesBlue
Both sides of the treads are clearly not the same.
11-03-2016, 04:38 PM | #8 |
Country Boy 4 Life
The Following 3 Users Say Thank You to Leonardo For This Useful Post: |
11-03-2016, 05:43 PM | #9 |
chicken tonight
Now we have to correct you. [rhetorical]Do you see a rotation arrow on your stock tires?[/rhetorical]
Asymmetry does not imply directionality. These are symmetrical and VERY directional. Mount them backwards and they will hydroplane like, well, a hydroplane.
The Following User Says Thank You to Ultramaroon For This Useful Post: | Leonardo (11-03-2016) |
11-03-2016, 06:22 PM | #10 |
You are right. The Michelin Primacy HP tires do not have arrows on them. They are not directional like your photos shown. So then what's with the Michelin Primacy HP tires? Left tread pattern is different from right.
11-03-2016, 07:04 PM | #11 |
chicken tonight
They have an outside and an inside to address many design goals including modulating lateral grip as a function of camber and load vector.
11-03-2016, 07:28 PM | #12 |
So....... how should these tires be rotated? Front to back or cross?
11-03-2016, 08:04 PM | #13 |
Drives: 15 Series.Blue
Doesn't matter how they are rotated as the outside of the tire is still on the outside of the wheel when it's on the left or right side of the car.
The Primacys, like other tires with different patterns on the left half of the tire than the right, are marked with the words "outside" or "inside" so that when they are mounted, the outside of the tire is placed on the outside of the rim. |
11-03-2016, 08:17 PM | #14 |
Got it. Thanks for the clarification!
Do these look right? Passenger tire on left & Driver side tire on right. (Rotated, not mirrored) Last edited by DCdesign2000; 11-03-2016 at 08:36 PM. Reason: additional questions |
Similar Threads | ||||
A Few Questions for STX | Areddi | Tracking / Autocross / HPDE / Drifting | 10 | 01-04-2013 09:22 PM |
Couple tire/wheel questions | Jayde | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 21 | 11-19-2012 02:18 PM |
Ask more questions ... | Maik L | Scion FR-S / Toyota 86 GT86 General Forum | 9 | 11-17-2012 01:14 AM |
E85 questions | Grishbok | Engine, Exhaust, Transmission | 17 | 08-08-2012 10:49 PM |
FR-S NAV Questions | Dan86 | Electronics | Audio | NAV | Infotainment | 6 | 07-01-2012 02:24 PM |
