Old 04-09-2013, 05:32 PM   #1
GrimmSpeed
GrimmSpeed's Avatar
Drives: '13 BRZ, '12 WRX
Send a message via AIM to GrimmSpeed Send a message via MSN to GrimmSpeed
BRZ/FR-S Strut Tower Brace - Any Interest?
ATTENTION: The Group Buy is officially CLOSED!
Check out our website for more information or to purchase your brace!
[ame="http://www.youtube.com/watch?v=8YrchyZDwiQ"]GrimmSpeed BRZ/FR-S Strut Tower Brace Install Guide - YouTube[/ame]
It's official, ladies and gentleman. Strut bars are back from powdercoat and are looking really sharp! Most of you have been following it's development since day one, but for those that haven't, what you see here is the very best and most cost effective strut tower brace available. In both simulated and on-road testing, we're able to show that the factory triangulation bar actually do their jobs quite well! The only missing piece is a rigid bar tying both strut towers together, completing the triangle, and let me tell you, what a difference it makes. From the moment you pull out of the driveway, you'll feel a stiffer front end. Less creaks, noticeably smoother and more stable over cracks/potholes/etc and much snappier steering response. I wouldn't say it if it weren't true, but you don't have to take my word for it!
Quick Specs:
  • Laser cut, CNC bent brackets ensure a perfect fit
  • Mild steel construction provides maximum stiffness
  • Rigid design prevents unnecessary slop and tolerance stacking
  • Durable duPont powercoat
  • Legal in autocross classes that allow a strut tower bar but no other modification
  • Installation in minutes with only a single tool
(MSRP: $158.99)
Original Post:
We're back at it again folks, and once again we're looking for your input! In our previous ft86club collaboration, the hood struts, the ideas and responses from the community here were very valuable. With your help we were able to release an extremely successful product with ideas and features that YOU want. So please, once again, any and all input is welcome whether you have a question, concern, idea, or just want to hit us with some motivational words!
Most people are aware of what a strut tower brace does, but aren't entirely aware of why they want one. So what does it actually do? Most people would say: "It stiffens up the front of the car." But what does that accomplish, and how does it actually make your car better?
Lets start with some expectations of what it SHOULD be doing: A properly designed strut tower brace should reduce movement between the strut towers, which results in more predictable handling characteristics. What you should notice as a driver (especially if you have sticky tires and complimentary upgrades) is increased response, turn-in, and traction. This is accomplished because you are minimizing a portion of the chassis as an additional deflection in the suspension system, which removes some unwanted changes in camber, castor, etc. An additional side effect of adding a strut tower brace that is often overlooked comes from reducing chassis flex. Reducing movement will reduce fatigue, which is useful for increasing the structural longevity of the car itself.
The first thing that we did before developing any concepts was to determine if these cars actually benefit from a strut tower brace, as we're not interested in providing a part that does nothing. These cars already come stock with triangulation bars to provide additional rigidity, so we wanted to determine how effective these were, and if we wanted to design a brace that included them as well. We will touch on the specifics of our testing in another post, but in the interest of brevity we'll summarize our testing and results here. We made a very simple brace out of metal that fit on the studs on the strut towers that the triangulation bars are bolted to. We then took several data sets with our Faro Arm with and without different combinations of the stock triangulation bars and prototype strut tower brace. We did this to compare how much the strut towers were deflecting when we jacked up one side of the chassis to a calibrated height. This is NOT indicative of the lateral loads the strut towers see in cornering, where the forces are much higher and specifically located. Instead, this test is much more simplified, and results seen here will be more exaggerated when applied to real life cornering.
I took several data sets and then compiled them looking for trends. In my software I held one strut tower in place, and measured the differences in deflection in the other strut tower. I'll post a picture here showing some quick visual results. The blue stud represents the car sitting on the ground, completely unloaded. The yellow stud is the car loaded (jacked up to a calibrated height) with the triangulation bars and our prototype strut tower brace. The green stud is the car loaded with just triangulation bars. Finally, the red stud is the car loaded without the triangulation bars or strut tower bar.
What this initially shows is that the stock triangulation bars do a pretty decent job of minimizing deflection. It also shows us that adding a strut tower brace to those triangulation bars does an even better job at that task. Let the designs begin!!!
We've identified how the strut bar should perform as our initial criteria for design. From there, there are still so many decisions that need to be made. We've weighed many options, and are still on the fence with some. Should it be hinged, or welded solid? What mounting method/location should it use? Is adjusting for preload important? What should it look like? How much should it cost? The list goes on and on! Thus far, the direction we're leaning in is a strut tower bar that is welded solid, non-adjustable, fits over your stock triangulation bars, and utilizes those two mounting studs. We're thinking something that is clean and appears to be OEM...
We've whipped up a few designs in CAD, just to get moving, and we're interested in showing off a couple to give you an idea of the direction we're headed in. These will most likely be made in steel, and powdercoated textured black. Use these quick concepts as a jumping off point for your ideas, and let us know what you like, what you don't, what is important to you, and what isn't, we want to hear it all!
I know what you're thinking: "I dunno, I guess I need to see what it looks like on the car to really be able to tell." Well, me too. So I used my favorite thing in the world to print one of these concepts up:
Re-read this post a couple of times, take a look at the pictures, visualize it on your own car, then come back and let us know your opinions! I'll be updating this thread often as this project progresses, just the same as we did on our thread about the hood struts. We literally can not wait to hear your ideas, so don't be shy!
Chase
Engineering
GrimmSpeed is offline   Reply With Quote
Old 04-09-2013, 05:33 PM   #2
GrimmSpeed
GrimmSpeed's Avatar
This list represents those interested in being contacted when the bars are ready to ship. We'll be offering you guys a killer group buy price (TBD) that's way below MSRP. Being on this list, or adding yourself, in no way commits you to purchasing!
1. Noob4Life Payment Instructions Sent
2. DR 86 Payment Instructions Sent
3. Fenrir Payment Instructions Sent
4. PNW FRS Payment Instructions Sent Payment Received/Shipped
5. qijian Payment Instructions Sent Payment Received/Shipped
6. RazBRZ Payment Instructions Sent Payment Received/Shipped
7. Dustin Payment Instructions Sent
8. Jeffboyarrdee Payment Instructions Sent
9. chanomatik Payment Instructions Sent Payment Received/Shipped
10. mottor Payment Instructions Sent Payment Received/Shipped
11. 2point0 Payment Instructions Sent Payment Received/Shipped
12. FRSGT86 Payment Instructions Sent Payment Received/Shipped
13. peteralfonso Payment Instructions Sent Payment Received/Shipped
14. Vino Payment Instructions Sent
15. Shankenstein Payment Instructions Sent
16. johnb831 Payment Instructions Sent Payment Received/Shipped
17. norsamerican Payment Instructions Sent
18. s2d4 Payment Instructions Sent Payment Received/Shipped
19. Gunman Payment Instructions Sent
20. Ranatsu Payment Instructions Sent Payment Received/Shipped
21. Captain Snooze Payment Instructions Sent Payment Received/Shipped
22. sierra Payment Instructions Sent Payment Received/Shipped
23. dawnst3ar Payment Instructions Sent Payment Received/Shipped
24. SkAsphalt Payment Instructions Sent Payment Received/Shipped
25. tripjammer (x2) Payment Instructions Sent Payment Received/Shipped
26. ATL BRZ Payment Instructions Sent Payment Received/Shipped
27. sbxjap Payment Instructions Sent
28. Anduz Payment Instructions Sent Payment Received/Shipped
29. disgruntld (x2) Payment Instructions Sent Payment Received/Shipped
30. rumors Payment Instructions Sent Payment Received/Shipped
31. Slartibartfast Payment Instructions Sent Payment Received/Shipped
32. wootwoot Payment Instructions Sent
33. ZetaVI Payment Instructions Sent
34. stockysnail Payment Instructions Sent Payment Received/Shipped
35. boredom.is.me Payment Instructions Sent Payment Received/Shipped
36. Jayde Payment Instructions Sent
37. Mr.Jay Payment Instructions Sent
38. onefitz Payment Instructions Sent
39. MrGen Payment Instructions Sent
40. BRZNutt Payment Instructions Sent Payment Received/Shipped
41. RD1428 Payment Instructions Sent Payment Received/Shipped
42. Hawk77FT Payment Instructions Sent Payment Received/Shipped
43. whitefrs Payment Instructions Sent
44. Ranatsu Payment Instructions Sent
45. eikond Payment Instructions Sent Payment Received/Shipped
46. wheelhaus Payment Instructions Sent Payment Received/Shipped
47. Vracer111 Payment Instructions Sent Payment Received/Shipped
48. phat 86 Payment Instructions Sent Payment Received/Shipped
49. SonnyBRZ Payment Instructions Sent Payment Received/Shipped
50. Sgt.Beardface Payment Instructions Sent
51. kwood9000 Payment Instructions Sent Payment Received/Shipped
52. LeeMaster Payment Instructions Sent
53. OICU812 Payment Instructions Sent Payment Received/Shipped
54. usptwinsPayment Instructions Sent
55. FrostedFlakes Payment Instructions Sent Payment Received/Shipped
56. Pedalincircles Payment Instructions Sent
57. ducks Payment Instructions Sent Payment Received/Shipped
58. Foobar Payment Instructions Sent
60. dawnst3ar Payment Instructions Sent
61. mit_peid Payment Instructions Sent Payment Received/Shipped
62. Hawaiian Payment Instructions Sent
63. Shim Payment Instructions Sent Payment Received/Shipped
64. elrod Payment Instructions Sent Payment Received/Shipped
65. joel86 Payment Instructions Sent Payment Received/Shipped
66. dem00n Payment Instructions Sent Payment Received/Shipped
67. The Tengu Payment Instructions Sent Payment Received/Shipped
68. cmspooner Payment Instructions Sent Payment Received/Shipped
69. turbos86 Payment Instructions Sent Payment Received/Shipped
70. Noob4Life Payment Instructions Sent
71. Calum Payment Instructions Sent
72. vincent201089 Payment Instructions Sent Payment Received/Shipped
73. EL7 Payment Instructions Sent
74. Sanka86 Payment Instructions Sent
75. Sutty Payment Instructions Sent
76. BlueSTaR Payment Instructions Sent
77. Detailer_GT86 Payment Instructions Sent Payment Received/Shipped
78. RAN94A Payment Instructions Sent
79. jono_l Payment Instructions Sent
80. Pengasus Payment Instructions Sent Payment Received/Shipped
81. Nzjuggalette Payment Instructions Sent
82. fuddbutter Payment Instructions Sent
83. Draco PR23 Payment Instructions Sent Payment Received/Shipped
84. Spartan65 Payment Instructions Sent Payment Received/Shipped
85. CandyFRS Payment Instructions Sent Payment Received/Shipped
86. Lee358 Payment Instructions Sent Payment Received/Shipped
87. BRZSSM13 Payment Instructions Sent Payment Received/Shipped
88. ebielat Payment Instructions Sent
89. sabSquishy Payment Instructions Sent
90. Anthonytpt Payment Instructions Sent Payment Received/Shipped
91. console_cowboy Payment Instructions Sent
92. driver01 Payment Instructions Sent
93. Captain Snooze Payment Instructions Sent
94. dvlnsyde Payment Instructions Sent Payment Received/Shipped
95. Black Tire Payment Instructions Sent
96. siXXtoes Payment Instructions Sent Payment Received/Shipped
97. LetsGo Payment Instructions Sent Payment Received/Shipped
98. Splat Payment Instructions Sent
99. BrentKaty725 Payment Instructions Sent Payment Received/Shipped
100. tg_1981 Payment Instructions Sent Payment Received/Shipped
101. sanmarcosfrs Payment Instructions Sent
102. mrjester Payment Instructions Sent Payment Received/Shipped
103. MikeM5 Payment Instructions Sent Payment Received/Shipped
104. Fascist Fish Payment Instructions Sent
105. rodmoe Payment Instructions Sent
106. sure74 Payment Instructions Sent Payment Received/Shipped
107. Chee-Hu Payment Instructions Sent Payment Received/Shipped
108. chimera118 Payment Instructions Sent Payment Received/Shipped
109. oso_25 Payment Instructions Sent
110. rawr Payment Instructions Sent
111. Markone Payment Instructions Sent
112. jazztennor Payment Instructions Sent
113. tinger00 Payment Instructions Sent
114. Mr.Jay Payment Instructions Sent Payment Received/Shipped
115. rupert Payment Instructions Sent Payment Received/Shipped
116. Ben_G Payment Instructions Sent Payment Received/Shipped
117. Norkoastal Payment Instructions Sent Payment Received/Shipped
118. karlsson Payment Instructions Sent Payment Received/Shipped
119. John.Hong Payment Instructions Sent
120. Biggdogg Payment Instructions Sent
121. DriftEightSix Payment Instructions Sent Payment Received/Shipped
122. DGMBRZ Payment Instructions Sent Payment Received/Shipped
123. Harbinger of Darkness (x2) Payment Instructions Sent Payment Received/Shipped
124. Jhon19lopez Payment Instructions Sent
125. overlookedx Payment Instructions Sent
126. infinite012 Payment Instructions Sent
127. Speedie Payment Instructions Sent Payment Received/Shipped
128. j2digit Payment Instructions Sent
129. solidONE Payment Instructions Sent
130. Stay n/a Payment Instructions Sent
131. F1point4 Payment Instructions Sent
132. luv85 Payment Instructions Sent Payment Received/Shipped
133. BRZ68 Payment Instructions Sent Payment Received/Shipped
134. jonbonazza Payment Instructions Sent
135. mjs Payment Instructions Sent Payment Received/Shipped
136. ex-gti Payment Instructions Sent
137. eleu2166 Payment Instructions Sent
138. Ny Brz Payment Instructions Sent Payment Received/Shipped
139. reno Payment Instructions Sent
140. emutcfut Payment Instructions Sent Payment Received/Shipped
141. D18 Payment Instructions Sent Payment Received/Shipped
142. sid325 Payment Instructions Sent Payment Received/Shipped
143. Brzer Payment Instructions Sent
144. RacerDrew Payment Instructions Sent Payment Received/Shipped
145. danthedirt Payment Instructions Sent Payment Received/Shipped
146. chutrain Payment Instructions Sent
147. ArmyJon Payment Instructions Sent Payment Received/Shipped
148. kidgogeta Payment Instructions Sent Payment Received/Shipped
149. xn7485 Payment Instructions Sent Payment Received/Shipped
150. Seraph Payment Instructions Sent Payment Received/Shipped
151. TOZER Payment Instructions Sent Payment Received/Shipped
152. TravBRZ Payment Instructions Sent
153. Subforever Payment Instructions Sent
154. EL_to_TBD Payment Instructions Sent Payment Received/Shipped
155. Jvalich Payment Instructions Sent
157. cslntuee Payment Instructions Sent Payment Received/Shipped
158. tintumz22 Payment Instructions Sent
159. loogs Payment Instructions Sent
160. Chri5 Payment Instructions Sent
161. TeamSweet86 Payment Instructions Sent Payment Received/Shipped
162. forwallblakmail Payment Instructions Sent
163. I<3Twisties Payment Instructions Sent Payment Received/Shipped
164. Chase86 Payment Instructions Sent Payment Received/Shipped
165. Lakers86 Payment Instructions Sent
166. Touge86 Payment Instructions Sent
167. Patio Payment Instructions Sent Payment Received/Shipped
168. jcavner Payment Instructions Sent Payment Received/Shipped
169. 256brz2013 Payment Instructions Sent
170. denkigrve Payment Instructions Sent
171. Skippman Payment Instructions Sent
172. Alusil Payment Instructions Sent
174. finch1750 Payment Instructions Sent
175. Bailey239 Payment Instructions Sent
176. PMok Payment Instructions Sent Payment Received/Shipped
177. gdrider77 Payment Instructions Sent Payment Received/Shipped
178. HSC Payment Instructions Sent
179. TapDat Payment Instructions Sent
180. CharlieChaos Payment Instructions Sent
181. Ovrtme Payment Instructions Sent Payment Received/Shipped
182. Brzzee Payment Instructions Sent Payment Received/Shipped
183. FR-S FI Payment Instructions Sent
184. D-Smith Payment Instructions Sent
185. witness89 Payment Instructions Sent Payment Received/Shipped
186. toysub Payment Instructions Sent Payment Received/Shipped
187. tonystewart Payment Instructions Sent Payment Received/Shipped
188. FastLane1000 Payment Instructions Sent Payment Received/Shipped
189. reyruiz191 Payment Instructions Sentt Payment Received/Shipped
190. Optimus Prime Payment Instructions Sent Payment Received/Shipped
191. SigmaHyperion Payment Instructions Sent Payment Received/Shipped
192. Stu L Tissimus Payment Instructions Sent
193. the.big.kahoona Payment Instructions Sent
194. umpadupa Payment Instructions Sent Payment Received/Shipped
195. arkybrz Payment Instructions Sent
196. greenguy101 Payment Instructions Sent Payment Received/Shipped
197. jbravo373 Payment Instructions Sent Payment Received/Shipped
198. SwisCakeR0ll Payment Instructions Sent Payment Received/Shipped
199. derek1ee Payment Instructions Sent
200. Books Payment Instructions Sent Payment Received/Shipped
201. randel_07 Payment Instructions Sent Payment Received/Shipped
202. ScionKid Payment Instructions Sent Payment Received/Shipped
203. JACK 8URT0N Payment Instructions Sent
204. Opposed Payment Instructions Sent Payment Received/Shipped
205. fang_gt86 Payment Instructions Sent
206. FRS1010 Payment Instructions Sent
207. J MaM 86 Payment Instructions Sent Payment Received/Shipped
208. exequtor1987 Payment Instructions Sent Payment Received/Shipped
209. ziptiedae86 Payment Instructions Sent Payment Received/Shipped
210. BagOfArms Payment Instructions Sent Payment Received/Shipped
211. dhenson405 Payment Instructions Sent Payment Received/Shipped
212. Brzzee Payment Instructions Sent
213. zex Payment Instructions Sent Payment Received/Shipped
214. doggieboy09 Payment Instructions Sent Payment Received/Shipped
215. stratodyne Payment Instructions Sent
216. dwx Payment Instructions Sent Payment Received/Shipped
217. Nardi330 Payment Instructions Sent Payment Received/Shipped
218. Iamthebatman Payment Instructions Sent Payment Received/Shipped
219. Symmetrical Payment Instructions Sent
220. Felix Payment Instructions Sent Payment Received/Shipped
221. Evil Payment Instructions Sent
222. DAFRS88 Payment Instructions Sent Payment Received/Shipped
223. SliverBrz Payment Instructions Sent Payment Received/Shipped
224. 2SeeKU Payment Instructions Sent
225. j8 Payment Instructions Sent Payment Received/Shipped
226. vteclol Payment Instructions Sent Payment Received/Shipped
227. Clipdat Payment Instructions Sent Payment Received/Shipped
228. jimmillion Payment Instructions Sent
229. CJB Payment Instructions Sent Payment Received/Shipped
230. thorlius Payment Instructions Sent Payment Received/Shipped
231. Demandred7 Payment Instructions Sent Payment Received/Shipped
232. ub78 Payment Instructions Sent Payment Received/Shipped
233. mRdeMs83 Payment Instructions Sent Payment Received/Shipped
Old 04-09-2013, 05:47 PM   #3
Noob4Life
86 Noob
Drives: Firestorm FR-S
I like this bar because 1. it's simple and 2. retains use of the OEM triangular bars which leads to a lower cost. Any chance you guys are thinking about offering different colors? (Red/blue/polished, the normal strut bar colors)
This truly does look like a function over form bar. Subed for updates
Noob4Life is offline   Reply With Quote
Old 04-09-2013, 05:48 PM   #4
stockysnail
Just the tip
stockysnail's Avatar
Drives: 2013 Lightning Red Subaru BRZ Mt Lt
I agree it should be welded, not hinged. It should also be solid, not hollow and very strong as to not bend under extreme forces. I like the example in the pictures and where it is mounting as long as there isn't any unwanted flex on those points in the chassis compared to the strut bolt points. If you're able to keep the price around $100 (ideally exactly $100) then I'd buy it. I'd also like an option for different colors like textured red, black, and blue.
stockysnail is offline   Reply With Quote
Old 04-09-2013, 06:23 PM   #5
Fenrir
Drives: Mazdaspeed 3
I'm curious to see how much this will actually benefit the chassis, as it already seems pretty stiff to begin with. Most testing I've seen shows that it takes QUITE a bit of stress to make these things worth it (Outside cosmetics, obviously. The ricer in me thinks they look badass.). If anyone can produce some reliable data it'll be you guys. Subbed for interest!
Fenrir is offline   Reply With Quote
Old 04-09-2013, 06:43 PM   #6
whitefrs
Love Boost!!!!!!!!
whitefrs's Avatar
Drives: Whiteout Scion FR-S
looks nice but needs different colors
Old 04-09-2013, 06:47 PM   #7
PNW FRS
PNW FRS's Avatar
Function = Benefit notwithstanding... from a purely aesthetic standpoint... I like the simple clean look and wonder if you are considering having replacements for OEM braces so that there is a consistent "look and feel" (i.e., texture, etc.).
If so.. .then +1 on offering in different colors.
2013 Asphalt / MT
Olympia, Washington
PNW FRS is offline   Reply With Quote
Old 04-09-2013, 06:54 PM   #8
civicdrivr
civicdrivr's Avatar
Drives: 2018 Golf R
Welded solid, I wouldn't mind preload adjustment, powdercoated semi gloss black (to match the stock bars better). Where do I send payment?
Parting out HERE
civicdrivr is offline   Reply With Quote
Old 04-09-2013, 06:59 PM   #9
RazBRZ
Cones are bad
RazBRZ's Avatar
Drives: 2013 BRZ Premium
I think the prototype looks perfect and I definitely want it to match the MCB and Hood Struts. I like the solid idea. Maybe do what you did with the struts and add and option logo that you can put on. Of course the cheaper the better without sacrificing the rigidity. Replacements for the stock triangle bars as an option or next project would be nice too. I have a Crawford AOS so the would have to mount close to stock
RazBRZ is offline   Reply With Quote
Old 04-09-2013, 07:02 PM   #10
Jayde
Jayde's Avatar
Hmmm.....
Jayde is offline   Reply With Quote
Old 04-09-2013, 07:11 PM   #11
Dustin
Twin Screw You
Dustin's Avatar
Drives: 2013 Supercharged Whiteout FR-S
Forgive the crappy MSPaint rendering but could you not have it mount something like this? Something about mounting it solely to that piece of metal that is tack welded onto the strut tower seems flimsy to me. Other than that, love the solid, no hinge design.
Dustin is offline   Reply With Quote
Old 04-09-2013, 07:17 PM   #12
Jeffboyarrdee
Jeffboyarrdee's Avatar
Drives: 2013 Subaru brz limited wr blue
1. Would be cool to have grimmspeed versions of the stock triangular bars as well (optional) which is nice since they are separate pieces and don't need to be purchased if not wanted.
2. Solid bars,not hollow
3. Nice colors would be a plus over functionality of course
4. If the main bar shares the same bolts as the stock bars, maybe having hardware that has longer threads, I know it would be nice to just use the stock hardware, but if calls for it, it might be worth it. That's something I've found with the password jdm struts, they are short in my opinion.
I like how they are straight and don't have unnecessary bends, weld points, or hinged. This should be a straightforward rigid design
I like how they don't surround the entire circle around the struts, I think they just need to hit those two points you have or the 3 on the inside.
I like the design, it's not too big and it's simple. If its affordable I may ditch what I have haha. It's nice to have something we all collectively have input toward.
So if there's a group buy I'm in haha
Jeffboyarrdee is offline   Reply With Quote
Old 04-09-2013, 07:18 PM   #13
chanomatik
Snow Don't Hurt!
chanomatik's Avatar
I like the idea of a solid bar. OEM-looking paint like the hood struts would be awesome. Optional paint colors would be welcomed, like red or blue at least, or maybe a color that better compliments your logo. It gets kinda messy when you offer colors, though, since it's nearly impossible to color-match and compliment aftermarket parts.
The angle of my reasoning: I plan on getting the blue engine cover, so a blue bar has a high chance of looking tacky stretched across the engine bay, not matching the engine cover's blue color.
Are the stock mounting studs designed to withstand the extra pressure from the strut bar? Are they long enough to withhold their length and integrity with having another part bolted to the chassis?
Overall, I'm for this. I know your price will be reasonable. I expect it to cost more than $100, but not a whole lot more.
Old 04-09-2013, 07:19 PM   #14
mottor
mottor's Avatar
Do you find any benefit in using the strut mounting bolts to mount the strut tower bar? Does this increase rigidity? I know that many are looking to save cost by using the OEM triangulation bars, but would there be any benefit in incorporating these in one solid triangulation bar? If so, how much?
2013 Asphalt FR-S 6MT - Perrin 2.5" Catback Exhaust - Grimmspeed Strut Tower Bar - Grimmspeed Master Cylinder Brace
Grimmspeed Hood Struts - Grimmspeed 86 Oil Cap - Grimmspeed Boxer Battery Tie Down - HID - Pioneer AVH-X5500BHS - Infinity Basslink 10" Sub
mottor is offline   Reply With Quote
Anyone using the STi Flexible Strut Tower Brace? ngabdala Suspension | Chassis | Brakes -- Sponsored by 949 Racing 45 08-15-2019 01:59 AM
F/S Beatrush Strut Tower Brace Type-2 $175 Dan-in-Japan Brakes, Suspension, Chassis 2 02-24-2013 01:38 PM
FT-86 SpeedFactory Strut Tower Brace Review F1point4 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 35 01-07-2013 04:31 AM
DIY - Strut Tower Brace - FT-86 SpeedFactory F1point4 DIY (Do-It-Yourself) Guides 4 10-28-2012 04:30 PM
