| BRZ First-Gen (2012+) — General Topics All discussions about the first-gen Subaru BRZ coupe |
Drives: BRZED!
flapping noise
Has anyone else noticed a flapping noise at higher speeds?
If I'm going 70 or more, it's very noticeable. I drove along side when someone else was driving the car & didn't notice anything obvious... The little mud flap in front of the rear tire was moving a bit, but I'm not sure it was enough to make the noise any thoughts or experience from the collective? |
My mud flap in the back came partially off and was flapping.
Sent from my SCH-I535 using Tapatalk 2 |
Original 2013 Owner
Drives: 13 BRZ, Galaxy Blue Silica
Initially read the thread title as "Fapping Noise"
| The Following 15 Users Say Thank You to Cjymiller For This Useful Post: | Allch Chcar (04-26-2013), awlllwa (04-05-2013), Calin (04-05-2013), ftc~brz (04-04-2013), Giccin (04-05-2013), GMU-BRZ (04-06-2013), jbsali (04-16-2013), M-17 (04-05-2013), Marchy (04-26-2013), marky (04-05-2013), microbionic (04-05-2013), n2oinferno (04-16-2013), njccmd2002 (04-06-2013), sprintertrueno86 (04-05-2013), Turbowned (04-05-2013) |
Lol
Done
Drives: WRB BRZ
thats what I saw.
I hear no flapping or fapping. in mine it sounds like my passenger window is down just a bit, but it's not. And I have a bad habit of hitting the window up button every dang time I hear it. Hope you find the culprit |
dying bird under the hood
Drives: 2013 SWP Limited BRZ
I hear this noise also when I drive near center dividers or walls.
Drives: 2006 Infiniti M45S
I had something similar on my Si, took me almost a year to figure out. Factory body work was loose in a spot, at over 70 enough turbulence to shake it and cause it to "flap". Sounds like that might be a good place to look ;-)
Sent from my SGH-I717D using Tapatalk 2 |
Drives: 2013 Subaru BRZ, 2007 V6 Mustang
I hear the same noise in my BRZ. I cannot find out what it is. It seems to have gone away for now though.
Edit - How new is your BRZ? Mine made the sound in my first 100 miles. |
Drives: BRZ Limited arrived on 9/1/2012
I have the same experience, seems like the mud flap is flapping but only passenger side. I read some say could be the under panel...
#10 |
Drives: 2020 BRZ tS #54
Yup fapping at high speeds sure will make some noise
![]() Yeah check your mud faps studs might of came off could be hanging |
#11 |
Drives: BRZED!
The rear mud flaps are still connected - seem to be as good as ever. Has anyone modified them to have less play? I'm thinking about using 2 part epoxy or something...
#12 |
Drives: WRB BRZ
Check all your tires for rocks stuck in the tread blocks.
#13 |
Drives: 2015 BRZ Limited 6MT
When I got under the car for my first oil change I noticed 3 places where the fiber undercover isn't tight in the rear where they use shoulder bolts to hold it on. The holes in the undercover are larger than the shoulders on the bolts and there is 3-4mm of play where the undercover can bang against the body. Great source for strange rattles. I had a few spare fuel injector o-rings that fit perfectly to snug the undercover up.
2015 BRZ , 1992 SVX LSL, 2019 ASCENT
#14 |
Drives: 2013 FR-S whiteout
I get it at around 85mph. Pretty constant but hard to determine where it's coming from.
| What's this noise? | Nitesh31 | Issues | Warranty | Recalls / TSB | 3 | 12-19-2012 10:35 PM |
| Fixed flapping, clanking sound coming from rear | Cornerman | Issues | Warranty | Recalls / TSB | 2 | 08-16-2012 10:27 PM |
| Fan noise? | djliquidsteele | Scion FR-S / Toyota 86 GT86 General Forum | 3 | 07-30-2012 06:22 PM |
| LSD noise | wheeladdict | CANADA | 2 | 07-09-2012 04:21 PM |
