Engine, Exhaust, Transmission Discuss the FR-S | 86 | BRZ engine, exhaust and drivetrain. |
Drives: 2013 Hot Lava Scion FRS
Perrin Header Back Review
Quick Words and Review
Hey All, Finally got my header back system installed this weekend. This is my first exhaust system ever, so I wasn't used to the noise. At first, I wondered if i accidentally received the unresonated version, but after a while I grew used to the sound and decided that it wasn't as loud as I thought. But that's a good thing. I didn't want the loudest exhaust on the market. It has this wonderful low thrum to it and then a nice boxer-rumble under throttle. The only word I can use, and am borrowing from everyone else, is: mature. I drive about 200 miles yesterday and noticed an improved throttle response, at least in the lower revs. I didn't go WOT as I was still getting use to the noise. The fit and finish is great. The slash cut tips are nice. I would prefer them to be a little larger to fill the rear diffusor (for example, Greddy's exhaust fills the holes nicely), but I'm not going to complain because they look much better than stock. Installation Installation was not as easy as the videos from brzclub show. Nor were they as simple as the DIY forum posts. There were moments where pipes didn't align until the they were fully tightened and the S-pipe did rattle against the frame. The pipes seemed as though they needed to be just a little more bent in certain areas or straighter in others. The example I use is the front pipe to the over pipe. The fitment wasn't flush and only became so after it was tightened into oblivion. The midpipe is also a finger tip's width from the frame. No rattles on that and hopefully it will stay that way. Because of the fitment we had to wiggle the piping on the hangers and so the tips may not be 100% straight. Now, if we had used a lift we may have had an easier time aligning everything, but we were using a jack and stands. The difficulty we encountered was a small price to pay for such an awesome and well made system. It is not ricer sounding and it fills the cabin with a pleasant grumble. With a jack and stands the job took about 4 hours. With a lift, I can imagine it taking much less time. For all those wondering if they should buy the Perrin Header Back System.... Yes. Go for it. It's a well made, well researched system. The sound is amazing and the tips look good in the diffusor. There is a noticeable response in low down torque from what I've noticed, the "butt dyno" as someone called it. I got my system through Mike with CZP. They had quick shipping and got me a great deal. |
The Following 3 Users Say Thank You to Saab2Frs For This Useful Post: |
Spun
Drives: 17' Focus RS
Nice writeup, any install pictures? Videos?
Ontario's FT86
Drives: 2016 Lexus GS-F
So did you get the hi-flow car version or catless?
Thanks |
I got the catted and resonated version.
No pictures or videos yet. I couldn't take pics of the install since we only had a jack and two stands. There was no room to photo. I'll "try" to get a video of the sound, but all i have is my iphone 4. No GoPro like some people, unfortunately. |
SLO NO MO
Nice! Did one of our forum members end up helping you with the install?
I'm waiting for a break in the weather before I put my Perrin OP/catted FP on to go along with my Perrin non-resonated catback. Hopefully will get a chance to do that tomorrow or Wednesday - temps are supposed to hit back into the 50s again so that should give me some decent weather to work on the car. Once it's on, maybe we can meet up somewhere and compare both systems (non-resonated vs. resonated) and shoot some sound samples for everyone. |
#6 | |
Drives: 2013 Subaru BRZ Ltd GBS 6MT
Has anyone had any issues with bolts popping at the overpipe-frontpipe connection? I've lost 3 now. All torqued to spec. Realigned the whole exhaust system to make sure fitment was spot on. Whenever I get it really hot i poke around under the hood to find one of the bolts missing.
#8 | |
Drives: 2013 FR-S Asphault
http://www.summitracing.com/parts/stg-8911/overview/ |
SLO NO MO
Installed my over pipe and catted front pipe today. I now have that awesome sound I lost with the GReddy Evo3 and no drone to speak of.
I didn't use locking washers on my op/fp connection so we'll see how well it stays together. Sent from my Nexus 4 using Tapatalk 2 |
#10 | |
#11 |
Drives: '11 535i
#12 |
SLO NO MO
It was definitely a tight fit to try and use the lock washers - are they absolutely required? I ended up using the flat ones instead of the split ones. I'll have to check it again later to make sure I used the proper bolts.
#13 |
Drives: '11 535i
No, they are not absolutely required. You should be fine with the set up that you have mentioned.
#14 | |
SLO NO MO
By the way, if I have Jeff's stage 1 tune already, should I send some logs in and have him tweak if necessary or does the addition of the OP/FP not require it? |
FS: AP Header back Exhaust | S1000rr | Engine, Exhaust, Bolt-Ons | 53 | 01-03-2014 04:32 PM |
Header Back vs Catback | Saab2Frs | Engine, Exhaust, Transmission | 16 | 02-08-2013 01:51 PM |
Perrin Header Back Installed!! | tonytduc | Engine, Exhaust, Transmission | 1 | 01-03-2013 10:58 PM |
Complete PERRIN Header Back Exhaust. >>Release Sale - Free Shipping*<< | FT-86 SpeedFactory | Engine, Exhaust, Bolt-Ons | 21 | 10-13-2012 09:17 AM |
Feeler: SRT Header Back with Cat | mike2100 | Engine, Exhaust, Bolt-Ons | 3 | 09-04-2012 04:55 AM |
