Old 02-25-2013, 12:23 PM   #1
BRZerk
Some guy in a white car
BRZerk's Avatar
Drives: 2013 SWP BRZ Limited
Smoothing out 1st and 2nd gears
hello all,
I was wondering what modifications were out there that would remove some of the notchiness from the transmission, especially when shifting from 1st to 2nd gears. It is definitely worse when cold or on a cold day. I was thinking about Motul 300 and the cusco transmission mount collar, or the Perrin transmission support. Will these mods help correct what I am looking for here?
thanks for the help guys.
PS I did do a search so please hold off on the
2013 Subaru BRZ Limited 6MT - Satin White Pearl
BRZerk is offline   Reply With Quote
Old 02-25-2013, 12:29 PM   #2
OrbitalEllipses
Drives: Attitude
http://www.ft86club.com/forums/showthread.php?t=16604
Old 02-25-2013, 12:30 PM   #3
FreshFRS
KCCO From Canada
Drives: Asphalt FRS
better fluid (pentosin 75w-80 is way thinner than stock and helps alot with cold shifting) maybe a rear stay bushing(TWM)? and whiteline's positive shift bushing may or may not help. (i would pick it over cusco's IMHO)
FreshFRS is offline   Reply With Quote
Old 02-25-2013, 12:31 PM   #4
A5D5TRYR
A5D5TRYR's Avatar
Drives: FR-S 6MT Ultramarine (BeeDrill)
I haven't tried the Pentosin yet but the Motul Gear 300 didn't do much to remove the problems I have with shifting when the transmission is cold. Once warm it works great though. Much smoother than the stock fluid.
2013 Scion FR-S - Ultramarine 6MT
A5D5TRYR is offline   Reply With Quote
Old 02-25-2013, 12:57 PM   #5
FRSFirestorm
Red is Fastest
FRSFirestorm's Avatar
Drives: 13 FRS 6MT Firestorm
Miles have helped mine more than fluids and bushings. When warm.
FRSFirestorm is offline   Reply With Quote
Old 02-25-2013, 12:58 PM   #6
stockysnail
Just the tip
stockysnail's Avatar
Drives: 2013 Lightning Red Subaru BRZ Mt Lt
I did the pentosin 75w-80 fluid, whiteline trans mount bushing, perrin rear shifter, and a heavier (flossy heavyweight) shift knob and the notchy-ness has all but disappeared. See my build thread in my sig for more info.
stockysnail is offline   Reply With Quote
The Following User Says Thank You to stockysnail For This Useful Post:
tech4pdx (02-25-2013)
Old 02-25-2013, 05:05 PM   #7
tech4pdx
Make love
tech4pdx's Avatar
Drives: H8R.. Not really
I have done everything that @stockysnail has done, except I have the Perrin trans mount and a different (also heavier.. 526 grams I think) shift knob and my cold shift problems and notchiness are all but gone! I believe Pentosin was mostly the key to better shifting (especially COLD).
tech4pdx is offline   Reply With Quote
Old 02-25-2013, 05:34 PM   #8
reeves
It's affecting so many cars.. maybe there should be a sticky on this subject.
I'm going to try the trans mount & bushing too.. 8K miles and 3 tranny fluid changes later, I'm still having the 2nd/3rd gear grind occasionally. 2nd gear is by far the worst tho.. Notchiness/stubborness occasionally too, at random times.
reeves is offline   Reply With Quote
Old 02-25-2013, 05:39 PM   #9
Rayme
The Answer
Rayme's Avatar
Drives: Mazda 2
I will attend to fix this using GM/penzoil synchromesh fluid. I had very good results in the past with my old toyota and civic SI. I'd use pentosin but it seems to be hard to get that product here.
Rayme is offline   Reply With Quote
Old 02-25-2013, 05:53 PM   #10
BigFatFlip
sleep, drive, eat, repeat
BigFatFlip's Avatar
Drives: '13 BRZ, '12 Outback
^This. The big question is: How many miles are on your cars? We have to remember that, like the engine, the transmission (specifically the gears) need to break-in aswell. The "notchiness" you feel is the rough fitting between the gears brand new "sharp" teeth. I too have had the same issues and was slightly worried in the beginning, even feeling some notchiness going from 2nd to 3rd. Now that I'm at almost 8k miles, gear teeth are better matching and 1st to 2nd and 2nd to 3rd are buttery smooth.
Old 02-25-2013, 06:11 PM   #11
reeves
I just past 12K miles.. still grinds/notchiness occasionally & randomly in 2nd & 3rd.. It might not be the tranny gears/teeth at all.. for me, it could be the bushings, so I'll try that first & see if it helps.
Old 02-25-2013, 09:11 PM   #12
BigFatFlip
BigFatFlip's Avatar
Agreed, in that case, you might be looking at something else. I guess the point I was trying to make is to allow the car to break-in first, then try other avenues such as a fluid change or bushings.
Old 02-25-2013, 09:18 PM   #13
mad_sb
Drives: 2013 Asphalt FR-S
double clutching with rev matching goes a VERY long way at eliminating the cold 1 - 2 shift notchiness FWIW. FLuid will help, i don't see how trans bushing will do anything for cold shift notch as that has more to do with fluid operating temperature than trans flex / location etc.
Old 02-25-2013, 09:40 PM   #14
GerryL
Drives: White BRZ
I've had very good results with Redline's gear oil. Removed about 80 to 90% of the issue and many days its perfect from the first cold shift. Its not cheap but definately worth the effort. When my son first drove it after I changed the gear oil, his first words on getting out of the car were "that stuff is magic in a bottle"....
GerryL is offline   Reply With Quote
Speeds at each gears. mickey177 Engine, Exhaust, Transmission 10 08-25-2016 06:40 PM
What really grinds my gears! CircuitJerk Off-Topic Lounge [WARNING: NO POLITICS] 128 04-01-2013 08:45 PM
2nd gears a b*tch Carbon420 Scion FR-S / Toyota 86 GT86 General Forum 32 01-29-2013 05:09 PM
Changing Gears Naughty AFRICA 10 01-09-2013 12:30 PM
Top Gears - Worst Car in the World KlafKoon FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum 13 12-02-2012 09:20 AM
