Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack Specific topics relating to wheels and tires. |
01-15-2013, 01:35 AM | #1 |
Drives: 13 WRB BRZ
why are aftermarket wheels so wide?
I can't seem to search this.. but why do aftermarket rims come in such wide widths for this car? 9.5 wide wheels with 245 tires?? wouldn't the tires over-stretch? i remember having 19x9.5 wheels with 275 tires and they seemed too narrow.. Am I missing something?
01-15-2013, 01:51 AM | #2 |
Drives: 2003 Subaru Outback
You just have to search for more narrow wheels. People who put such narrow tires on wide wheels are just....silly(being nice about it) A 265 belongs on a 9.5, not a 245. I dont understand why people feel the need to add more weight by buying an unnecessarily wide wheel.
For this car and what most people want out of it, a 245 or even a 255 tire out back will be all you need for sufficient grip, while people doing higher hp builds will find more use out of a wider tire. We share the same bolt pattern as wrx's and early sti's and given that they are AWD do not need wide tires. There are several narrow wheels for narrow tires out there in this bolt pattern if thats what you are looking for. It all comes down to that, what you want. |
The Following User Says Thank You to Tansey86 For This Useful Post: | number1Tango (01-15-2013) |
01-15-2013, 04:28 AM | #3 |
We generally use 8" wheels on our shop car, with 225 tires
The Following User Says Thank You to CSG Mike For This Useful Post: | schtebie (01-15-2013) |
01-15-2013, 05:13 AM | #4 |
Drives: 2013 86 GTS - Pegasus White
Always been curious about the pros and cons of using either or (narrow vs. wide, in relation to wheel width).
01-15-2013, 08:33 AM | #5 |
Drives: 2013 Whiteout Scion FRS
I have 18×8.5 +33 with 225/40 and 18×9.5 +40 with 255/35. I would not say that the tires are stretched at all and even dropped I have no rubbing issues.
01-15-2013, 08:48 AM | #6 |
Drives: Skoda Yeti DSG diesel 4x4
Here's a good site for comparing tyres and wheels.
http://www.rimsntires.com/specs.jsp If you put the 215/45-17 with the 7" P38? offset on the left hand side you can play with the right hand side and see the comparisons below. For a 245/45-17 tyre an 8" rim is ideal but 7" and 9" are within acceptable limits. That tyre is 4.2% larger diameter but that should correct the speedo error that is usually 5% over. It will also take 5% off your odometer which is usually accurate. Good for resale and servicing but don't forget to take 5% off the fuel consumtion if you work it out. So you could fit up to 245/45-17 on the OEM rims which would be a better look for me than the stretched crap that is trendy. |
01-15-2013, 09:25 AM | #7 |
Drives: '13 BRZ in WRB--let's mod!!!
Maybe because the stock wheels are too narrow for performance applications?
The Following User Says Thank You to GTB/ZR-1 For This Useful Post: | jadewbj (01-15-2013) |
01-15-2013, 09:54 AM | #8 |
Drives: Attitude
01-15-2013, 11:40 AM | #9 |
01-15-2013, 11:49 AM | #10 |
Drives: Monkey-butt red FR-S
01-15-2013, 12:37 PM | #11 |
head of infinite swagger
Drives: 2013 FR-S 6MT
Wide wheels is all about the look, the wider the rims the more concave it can be.
There is also the flushness, which could be achieved with offsets on a more narrow rim, but then you lose some of the concavity. The mild stretch on the tires is to avoid rubbing issues mostly.
2019 Golf R 6MT - current daily...I need another coupe
2008 Civic Si - winter beater 2000 Silverstone M5 6MT - SOLD 2013 Ultramarine FR-S 6MT - Car Journal - SOLD 2004 AlpineWhite M3 6MT - SOLD |
01-15-2013, 01:16 PM | #12 |
Drives: Some rust bucket
Stock 7" isn't too narrow considering the stock power/weight ratio. Look at the similarly powered DC2 and DC5 Type R. The DC2 had 16x7 and the DC5 had 17x7. Look at the first generation s2000; it only had 16x6.5 at the front.
01-15-2013, 01:17 PM | #13 | |
Drives: 2013 Ultramarine FR-S
01-15-2013, 02:06 PM | #14 |
Drives: 2013 FR-S Ultramarine
I like 8" wheels best for a 225. They look a little cramped on anything smaller than that.
The Following User Says Thank You to SubieNate For This Useful Post: | CSG Mike (01-15-2013) |
Similar Threads | ||||
Aftermarket wheels in Calgary | Davetherave | CANADA | 4 | 12-03-2012 10:30 PM |
For those guys with wide wheels | jkonquer | Off-Topic Lounge [WARNING: NO POLITICS] | 1 | 11-02-2012 02:18 PM |
Light, wide wheels with good fitment | coyote | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 15 | 02-10-2012 04:27 PM |
Aftermarket wheels? | Levi | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 21 | 12-06-2011 07:19 AM |
