Tracking / Autocross / HPDE / Drifting What these cars were built for! |
01-08-2013, 01:19 AM | #1 |
Quick Tire Swaps and Rotations | Guide | DIY
Quick Tire Change/Rotation Guide
Problem: I figured I would dump this here as, I HATE swapping tires for events. Always having had 3-4 cars, I am always doing rotations, winter wheel swaps etc. And finally got sick of fighting. So I wanted a new setup that was quick, easy to transport and worked well. Please use the parts and guide as reference, chose your own setup vendors etc. Research: After to talking with a friend who works on a pit team for Spec Miata/SRF most of the guys use cordless impact wrenches, either by Snap-On or Matco. Clearly the cost of those tools is more than a seasons worth of tires, so I talked to a few suspension shops who do some team racing and settled on the following parts. Work Smarter Not Harder 9 minutes per Side Parts List:
[ame="http://www.youtube.com/watch?v=rbToa2nqxKM&"]Tire Swap Test For Rotations and Track Days | Brownline Torque Wrench | Dewalt Impact Wrench - YouTube[/ame]
Photos of Parts
The Following 3 Users Say Thank You to Dezoris For This Useful Post: |
01-08-2013, 08:23 PM | #2 |
Drives: Asphalt FR-S
Those are some cool tools.
I have a cheap Pep Boys, 24v Goodyear branded cordless impact. Surprisingly effective, and the battery lasted at least 5 years before I had new cells put in. Cordless impacts are definitely your friend at the track, Also, when your trailer tires explode on the way home from the track. Between a drive up ramp and the cordless impact, I can change a trailer tire in minutes. ********* Off topic, but I have found that a good percentage of D load range trailer tire failures are due to cheap rubber valve stems failing, They are only rated for maybe 50psi, not 65psi. They leak air, tires get hot, go boom. Use metal valve stems. It will save you from changing as many tires on the side of the road.
Asphalt FR-S
1965 Mustang Vintage Road Racer Ducati Paul Smart 1000LE Ducati 848 |
01-08-2013, 10:16 PM | #3 |
I had an old Milwaukee 24v I just retired. It's a beast and can deliver a lot of torque. I replaced it with an 18v DeWalt which is tiny in comparison. I really only use it to zip the lugs on and off it doesn't quite have enough juice to break the lugs loose at 85lb-ft. I just use the stock tire iron to break them loose.
01-08-2013, 11:16 PM | #4 |
Conedancer
Drives: 2013 Subaru BRZ SWP
I am using a Ryobi 24V Lithium... Works well.. Torques right to 78lbs..
STX #68 Join my BRZ/FRS FB Group Thanks to:Kartboy/Wheeldude/Nameless Performance /Gaurd Transmission LSD |
01-09-2013, 03:35 AM | #5 |
Senior Citizen
Drives: Scion FR-S
Get this or make you own:
http://www.flyinmiata.com/index.php?...umber=35-70000 Being able to jack up a whole side of the car from under the door is a HUGE time saver! |
The Following User Says Thank You to simpleisbest For This Useful Post: | whataboutbob (01-12-2013) |
01-09-2013, 05:40 AM | #6 |
I use one of these
http://www.sears.com/craftsman-c3-19...2&blockType=G2 Two batteries are enough for 10 full changes without straining the battery. |
01-09-2013, 11:24 AM | #7 | |
http://protechproducts.com/index.php...&product_id=57 |
01-09-2013, 12:44 PM | #8 | |
Drives: 2021 Supra / 2022 Tundra
http://www.purems.com/Products/PROTE...-Lift-Jack-Pad 1006 not the 1007. Love them.
TomR
The Following User Says Thank You to ABQautoxer For This Useful Post: | ATL BRZ (01-09-2013) |
01-09-2013, 01:20 PM | #9 |
Are these better than a hockey puck with a groove cut in it?
Serious question... I use a hockey puck. lol |
01-09-2013, 01:30 PM | #10 | |
Conedancer
If it works... stick with it.. BTW...I have to dig mine out (the hockey puck) and Retrofit it for the BRZ...Forgotten I had one for my old STi.. thanks.. Bill
01-09-2013, 01:59 PM | #11 | |
Same principle. I bought the protech one originally because I was lazy. I've also found it to be pretty much indestructible and since its bright yellow easy to find in my messy garage. |
01-09-2013, 02:07 PM | #12 |
Site Moderator
Drives: Stuff
I have a bunch of pucks sitting around, never bothered to use anything besides the jack saddle for lifting the car. Hmm..
Normally I just use the lift instead.
-Dave
Track cars: 2013 Scion FRS, 1998 Acura Integra Type-R, 1993 Honda Civic Hatchback DD: 2005 Acura TSX Tow: 2022 F-450 Toys: 2001 Chevrolet Corvette Z06, 1993 Toyota MR2 Turbo, 1994 Toyota MR2 Turbo, 1991 Mitsubishi Galant VR-4 Parts: 2015 Subaru BRZ Limited, 2005 Acura TSX Projects: 2013 Subaru BRZ Limited track car build FS: 2004 GMC Sierra 2500 LT CCSB 8.1/Allison with 99k miles |
01-09-2013, 02:37 PM | #13 |
We use wood blocks with grooves for the lift and they are showing major signs of wear. I use these devices and they show no wear, they are basically going to be indestructible. So better than a Hockey puck, no I dont think so so unless those are prone to split over time, but they are turn key which is nice.
TomR
01-09-2013, 04:24 PM | #14 | |
Drives: Whiteout FR-S
2013 Ford Focus St
2013 Scion FR-S 2007 Honda Civic Si 2003 Acura RSX Type-S 1998 Ford Escort ZX2 |
Similar Threads | ||||
FS: NRG Quick Releases, Hub, Quick Lock, Steering wheel | Pekingduck | Interior Parts (Incl. Lighting) | 7 | 02-12-2014 05:59 PM |
Motor swaps.. | Brian S | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 2 | 05-19-2012 04:18 PM |
Engine Swaps Available | 88blacktop | Scion FR-S / Toyota 86 GT86 General Forum | 2 | 05-04-2012 06:45 PM |
Engine Swaps and Kit Cars! | merlin2111 | Other Vehicles & General Automotive Discussions | 27 | 01-27-2012 05:18 PM |
The AS1 and engine swaps | Syldrin | Engine, Exhaust, Transmission | 39 | 01-25-2012 10:45 AM |
