Old 01-07-2013, 05:49 PM   #1
Liquidsnake
Drives: "I drives like a Porsche"
Long start up. Not weather related.
Strange, I drove to work parked the car. 4 hours later I went back to the car to leave for lunch, and I had a looooooong start up, I had to try 3 times, and finally it started.
Automatic.
Happened once before like 3 months ago. Anyone else experience this?
What do I do?
Liquidsnake is offline   Reply With Quote
Old 01-07-2013, 05:57 PM   #2
Gixxersixxerman
Gixxersixxerman's Avatar
Drives: Toyota GT86, 66 beetle, 11 GSXR 750
Mines done it a few times.. And at different times to.. Once in the morning.. Once after it sat for a couple hours.. The latest was a couple days ago, when I ran in to pick up a friend and about 10 mins later jump in and tried to start and it didn't want to.. It started the second time..
I've had the same issues
Gixxersixxerman is offline   Reply With Quote
Old 01-07-2013, 06:01 PM   #3
Shagaliscious
Drives: Firestorm FR-S (MT)
This happened to me for the first time last Friday. I was leaving work, but I went to lunch that day. So the car had been sitting for maybe 3 hours. It took me 3 tries to get it started.
Old 01-07-2013, 06:01 PM   #4
Liquidsnake
Should I just mention it to the service guys next time I take it in? Can it wait?
Not due for service for another 4 thousand miles.
Old 01-07-2013, 06:08 PM   #5
marky
marky's Avatar
Drives: 2020 BRZ tS #54
Maybe ignition coil faulty/fuel pump/filter or defect not sure
Could of flooded it for a sec..
Are you waiting for like 2/3 seconds letting the fuel pump to reach the engine before cranking the engine?
I had this similar issues on my DC2 replace the ignition coil and problem went away...
Old 01-07-2013, 06:09 PM   #6
jlu
jlu's Avatar
Drives: Asphalt AT FR-S
It's happened to me before two or three times before (might have been the cold weather), but not in a while.
Someone told me to pump the gas while turning the key, not sure if that's valid advice or not.
jlu is offline   Reply With Quote
Old 01-07-2013, 06:13 PM   #7
Liquidsnake
Just weird man. I don't want to get stuck in Torrance after the sun goes down.
Old 01-07-2013, 06:16 PM   #8
m0nty
m0nty's Avatar
Drives: 86 GT
Funny that a bunch of Australian Clio RS200 owners are reporting the same issue. We all had the issue arise in the last week. Only happens with factory tuned cars and could be heat related. Most of Australia is in heat wave at the moment.
m0nty is offline   Reply With Quote
Old 01-07-2013, 06:22 PM   #9
strat61caster
strat61caster's Avatar
I feel like 95% of these threads can be solved with this advice. The fuel pump needs to pressurize the system before the car will start.
86'd (01-07-2013)
Old 01-07-2013, 06:30 PM   #10
Liquidsnake
So just switch the key to on for a few seconds before starting?
Old 01-07-2013, 06:48 PM   #11
titan_rw
Drives: '09 Matrix XRS
As far an I'm aware, this was valid advice when cars were carbureted. Pumping the gas pedal before starting / while cranking would manually pump gas into the carb(s).
Fuel injected cars don't need this. The ECM handles all the fuel stuff these days.
That being said, waiting a second or 2 after turning key to on, but before cranking might allow the fuel pumps time to create fuel pressure so that the fuel injectors have something to inject. If doing this doesn't help, I'd say there's another problem, and would be talking to the dealer.
titan_rw is offline   Reply With Quote
The Following User Says Thank You to titan_rw For This Useful Post:
Tcoat (03-28-2015)
Old 01-07-2013, 06:50 PM   #12
86'd
86'd's Avatar
Drives: 2012 WRX Sedan
Yeah, in most cars you can hear the fuel pump "prime" in the 2nd key position.
Whenever my car wouldn't start, it would be because of two things:
1. Low Fuel
2. Turning the key too fast
Or a combination of these two things.
If it's not either of these things, then go ahead and take it in.
86'd is offline   Reply With Quote
Old 01-07-2013, 07:12 PM   #13
Carbon420
Drives: 2013 FR-S Raven with carbon fiber
I've got the same thing a couple times. I though it was cause it was cold. We were at like -20 so it wasn't super cold and I didn't think I should be having those problems. But them it did it a couple days ago when it was like plus5 out so I don't think it was cold. I didn't have to try again it just took about 3-5 seconds befor it turned over.
Carbon420 is offline   Reply With Quote
Old 01-07-2013, 07:20 PM   #14
Bristecom
Bristecom's Avatar
Drives: 2017 Subaru BRZ PP
Is it because of newer high pressure fuel pumps? I never had this problem with older cars.
Toyota + Subaru =
Bristecom is offline   Reply With Quote
Push Start Rough Engine Start Up joergasm Engine, Exhaust, Transmission 3 12-12-2012 04:44 AM
PRI 2012 Photos....FRS/BRZ related. jadewbj FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum 3 12-03-2012 02:55 PM
Who got an 86/BRZ related present for Father's Day Sutty AUSTRALIA 4 09-02-2012 03:30 AM
Random dog-related question for those who have their BRZ GMU-BRZ BRZ First-Gen (2012+) — General Topics 11 05-31-2012 08:48 AM
