#1362
Drives: 2014 Ice Silver WRX
HID Question
Gonna be getting a plug and play set, 5000k 35w. Been reading about having to bend squirrel finders and was wondering if the bending is reversible. If not, are there any alternatives to bending them? Tape maybe? I just wonder in case I want to switch back for whatever reason. Thanks.
Sent from HTC Rezound using Tapatalk 2
what is this squirrel fender you're talking about? Heard and read about it too myself but don't know what they look like
Ridge Racerrrrrrrrr
There would be no going back unless you physically remove your headlights from your car and open them up so that you can use tools to bend back the piece of metal (squirrel finder). You may be able to do it without opening them up but I doubt you could get tools in there to bend them back up without taking out the headlight.
The "squirrel finder" is used to reflect and block light in such a way that it produces glare above the targeted beam of light to help illuminate signs, reflectors and other such reflective material that would normally not be in the direct path of your headlights. Think high hanging signs or advisories. The problem with squirrel finders and HIDs is that the bulbs are so bright that the glare is actually distracting if not dangerous to other drivers.
| The Following User Says Thank You to SkAsphalt For This Useful Post: | mezdup (01-02-2013) |
Road Warrior
Drives: Toyota 86 Satin Pearl White
Get yourself 6000k rather they are so much better looking with the blue tint. Not sure why you want to bend anything?
I fitted HID low and high beams from Germany, without any tampering. |
#5 | |
Road Warrior
In the OEM housings without bending the metal there is high unfocused glare as the projectors were designed for halogen bulbs. Its subtle to the driver not to on-comming traffic, namely on elevation change.
And 6000k is very blue, if you don't like any blue tint stick with 5000k. Ryan your housings must have auto level in SA?
Ridge Racerrrrrrrrr
We (US/Canadian FRS drivers) do not have a way to manually adjust the headlight from inside of the car sadly.
| The Following User Says Thank You to SkAsphalt For This Useful Post: | Ryan86 (01-02-2013) |
#8 | |
#1362
edit: and yea, probably gonna stick with 5000k since i just want a pure white. plus, from what i understand, it's the highest you can go without being too blinding.
#9 | |
Drives: 2013 Ultramarine FR-S, 2015 RS 1.0
I found that the squirrel finders aren't really necessary, even with halogen bulbs. I live in the city area so I don't have an issue with seeing signs lit up - it may be a problem if you live somewhere more rural and you need to see signs. For me, at worst I flick my high beams if I really need to. |
| The Following User Says Thank You to cdo221 For This Useful Post: | mezdup (01-02-2013) |
#10 | |
#1362
#11 |
You won't get tickets for HIDs unless you get an obnoxious color.
Get 4300k or 5000k and bend the squirrel finders down. You're welcome. |
#12 |
Drives: WRB BRZ
#13 |
#1362
you, sir, have no business in this thread!
| The Following User Says Thank You to mezdup For This Useful Post: | SkAsphalt (01-02-2013) |
#14 |
Lowered Lifestyle
Drives: Scion Fr-S
Here are my 8k 35w HID's. I haven't bent the squirrel finder or anything either...
Difference between oem and hid |
| BRZ Question | geb2391 | BRZ First-Gen (2012+) — General Topics | 24 | 11-19-2012 11:49 AM |
| Almost there.....but question | VENOM~ | CANADA | 25 | 08-22-2012 06:39 PM |
| Question? | Plxdjake89 | Scion FR-S / Toyota 86 GT86 General Forum | 7 | 07-28-2012 04:31 PM |
| AT question | Rob_g | Scion FR-S / Toyota 86 GT86 General Forum | 2 | 05-25-2012 03:40 AM |
| Question for BRZ and GT-87 hps? | west2k95 | Scion FR-S / Toyota 86 GT86 General Forum | 276 | 03-13-2012 11:45 PM |
