Issues | Warranty | Recalls / TSB Problems, issues, recalls, TSBs |
11-17-2012, 04:26 PM | #1 |
Drives: 2013 Firestorm FRS, 97 BMW M3
Stalling after full track session
I'm at the auto club speedway with speed ventures and on my way in after the session my frs seems to have stalled itself. I didn't get to do a full cool down since someone had their car catch fire but when i slowed down and put it in neutral, it died. It died again when i put it in neutral while parking. I had the the cel idle problem when i first got the car but the dealership fixed it and i haven't had a cel since. Wondering what might be the cause.
Sent from my DROID BIONIC using Tapatalk 2
Willow Springs |
11-18-2012, 12:59 AM | #2 |
Drives: '97 RSP JZZ30 GT-T
Probably detected overheating and shut itself off
Germans>Japanese>Italians>Americans. Unless its a Corvette. |
11-18-2012, 01:48 PM | #3 |
and outcome?
11-18-2012, 02:29 PM | #4 |
Reverse Burnouts
Drives: 2013 Argento FRS
also interested
2000 Carbon Blue Toyota Celica GTS 152000 miles (wont forget you) 2013 Argento Scion FR-S 2011 Infiniti G37x |
11-18-2012, 02:42 PM | #5 |
Site Moderator
Drives: Stuff
Does it have a CEL and SL now? Did it start idling correctly after awhile?
-Dave
Track cars: 2013 Scion FRS, 1998 Acura Integra Type-R, 1993 Honda Civic Hatchback DD: 2005 Acura TSX Tow: 2022 F-450 Toys: 2001 Chevrolet Corvette Z06, 1993 Toyota MR2 Turbo, 1994 Toyota MR2 Turbo, 1991 Mitsubishi Galant VR-4 Parts: 2015 Subaru BRZ Limited, 2005 Acura TSX Projects: 2013 Subaru BRZ Limited track car build FS: 2004 GMC Sierra 2500 LT CCSB 8.1/Allison with 99k miles |
11-18-2012, 08:58 PM | #6 |
Drives: Sonic Blue 86GT Manual
VAPOUR LOCK.... nah probably not, I just like saying that phrase
11-19-2012, 01:25 AM | #7 |
Drives: Nevermorange FRS
The more you track cars and the more cars you track you'll experience this. It's usually just heat soak. During the track session everything is very hot under the hood and afterwards, during idle the air moving into the engine is moving slow enough that it picks up enough heat and the sensor/computer doesn't compensate fast enough to bring up the revs and it stalls.
My S2000 did this on the first hot day of the summer, and occasionally after a track session. My CRX that I race does this often and most folks that have tracked enough cars have developed a habit of keeping the revs up a bit (800-1k) after coming off track because of this. I wouldn't lose any sleep over it. |
The Following 3 Users Say Thank You to rice_classic For This Useful Post: |
11-19-2012, 12:40 PM | #8 |
Thanks for the info guys. After the next session I had some idle fluctuation but did not stall itself. I think it would be alright with a full cool down lap or drive around the staging area for a bit.
Willow Springs |
11-19-2012, 01:00 PM | #9 |
[||•]=(86)=[•||]
Drives: 2017 Toyota 86
Got the same issue !
11-19-2012, 01:58 PM | #10 | |
Good rule to start with - if you are still picking up rocks with your tires as you come in the pit area, keep driving, its still too hot. and remember, no parking brake!! |
09-07-2013, 09:29 PM | #11 |
Had something similar happen during the middle of my 3rd session today. I was WOT down a straight in 4th when the red flag came out so I slowed and pulled over. We started moving again after 2 min. and I noticed the TRAC OFF light was on. No CEL that I saw. After pitting and restarting the car, it was fine.
I'm hoping this was just a random heat-soak/idle issue. Temps were about 85 degrees and I was running 100 octane to guard against possible DI seal issues. Other than that, the car ran like a champ. Planning to run 100 octane again tomorrow.
2022 BRZ Build 2013 FR-S Build |
09-07-2013, 09:43 PM | #12 |
IMO an oil cooler is almost a requirement if you track your car.
The Following User Says Thank You to jflogerzi For This Useful Post: | RL_BRZ (09-07-2013) |
09-08-2013, 01:17 AM | #13 |
Godzilla Konvert
Drives: DMG BRZ Limited 6MT 2013
Check your vacuum line near the top of the block
Mine blew off You just need to put a hose clamp on it and your good to go Ill post a pick when I get home
2013 Subaru BRZ Limited MT (DMG)
CO>CA Cartel |
09-08-2013, 01:23 AM | #14 |
CASC-OR T.A. Director
Drives: '13 Prius, '22 BRZ
Probably heat soak, your car had a lot of excessive heat and since you came to a stop or much slower speeds, your cooling capability plummeted and your car stopped itself to prevent more heat building.
Word of advice - after running laps BEFORE you lose a lot of speed (eg: rolling into the pits or safety areas) put your HVAC on HIGH HEAT and put the fans on FULL. The car draws air across the hot engine to heat it up going into the cabin and it will help cool off your car faster. It will make you uncomfortable but you can sweat it out with the car. Also, an oil cooler is definitely needed if heavy track use is a possibility. |
Similar Threads | ||||
Full Report: Road & Track tests stickier FR-S/BRZ tires | poormans_LFA | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 74 | 08-15-2013 01:10 AM |
Not stalling? | grgonium | Scion FR-S / Toyota 86 GT86 General Forum | 24 | 11-17-2012 10:26 AM |
Shannonville Motorsports Park Full Track August 11, 2012 | funcheung | CANADA | 5 | 08-13-2012 11:54 AM |
Mine started stalling today | Rob_g | Scion FR-S / Toyota 86 GT86 General Forum | 18 | 07-20-2012 10:27 PM |
GT5 - fastest Suzuka (full track) times | NESW20 | Other Vehicles & General Automotive Discussions | 11 | 04-03-2011 12:20 AM |
