Issues | Warranty | Recalls / TSB Problems, issues, recalls, TSBs |
11-06-2012, 08:26 AM | #1 |
Drives: 2010 Gen Coupe, 2013 BRZ 6MT S.Tech
Perrin Pulley
I finished installing my pulley. At idle(600-700rpm) the pulley wobbles a little bit but when its above 1000 rpm its good. Im not expecting it to be stationary and simply spin but just wanted to know if other people who installed the pulley get the same result as me.
If someone can do me a favour and let me know if theres wobbles around idle. Thanks |
11-06-2012, 08:34 AM | #2 |
Small penis big dreams
Drives: '13 Scion FR-S
no wobble here
11-06-2012, 08:36 AM | #3 |
^so it should be stationary at all times?
11-06-2012, 08:44 AM | #4 |
SLO NO MO
11-06-2012, 08:45 AM | #5 |
11-06-2012, 09:13 AM | #6 |
Drives: 2013 Scion Frs(Scarlet)
i dunno mine wobble when i had one...it pretty much wobbled the same as the stock pulley did...nothing crazy but it wasnt perfectly still.
The Following User Says Thank You to brichard0625 For This Useful Post: | ArKiTeCkT (11-06-2012) |
11-06-2012, 09:36 AM | #7 |
SLO NO MO
11-06-2012, 09:38 AM | #8 |
when i get a chance ill try and take a vid...its not really wobbling...its more a little bounce
11-06-2012, 09:43 AM | #9 |
Everything is torqued properly, the wobble is the cause of the engine slightly wobbling
11-06-2012, 09:55 AM | #10 |
Boostin'
Drives: FRS-T
did you guys line up the pin in the crank with the hole in the pulley?
11-06-2012, 09:58 AM | #11 |
11-06-2012, 11:45 AM | #12 |
11-06-2012, 11:57 AM | #13 |
yea i put the stock one back on and it moves the same. i've seen other people with perrin pulleys and stock pulleys and none of them were perfectly still..they all have a little bounce to them. its shouldnt be going crazy but its has a little "vibration" to it
Similar Threads | ||||
Perrin Crank Pulley now available | milenko11 | Engine, Exhaust, Transmission | 96 | 12-10-2017 06:45 PM |
perrin pulley vs warranty? | winsometang | Engine, Exhaust, Transmission | 6 | 09-28-2012 12:44 PM |
Perrin Pulley and Exhaust | Simmons | Engine, Exhaust, Transmission | 13 | 09-26-2012 12:39 PM |
