Old 11-01-2012, 11:15 AM   #1
jarviz
jarviz's Avatar
Drives: Raven FRS MT
remote starter - thoughts
I want to get a remote starter installed in my car for the coming winter months, but I don't have any knowledge or experience with them.
I want something simple and found this on amazon: [ame="http://www.amazon.com/gp/product/B00170ZUVQ/ref=oh_details_o00_s00_i00"]Amazon.com: Viper 1002 Car Alarm Security System: Car Electronics[/ame]
So I guess being a noob in this matter, how do I know if this is compatible with the FRS (manual)? and if it is, can I just take it to any reputable installer or should I worry because the FRS is so new that most installers probably haven't worked on one yet? Or does this not matter because this would be the same thing on all cars, like getting an oil change?
jarviz is offline   Reply With Quote
Old 11-01-2012, 12:20 PM   #2
Opposed
Drives: 2013 Asphalt FR-S
For starters, Viper is a good company to go with, or anything manufactured by DEI, they (IMO) are on the top quality wise. The only issue you may run into with getting it installed is the fact that you have a manual. Some shops may not install it due to the fact that it can be a risk. Some shops however may be able to install a neutral saftey switch, which will ONLY allow the remote start to work if the car is in neutral. Otherwise, if you parked your car in gear, forgot about it, then went to start it, the vehicle may roll. I wouldn't worry about taking it to a shop for installation, even though the car is new, alot of the wiring is done within the ignition harness, which I would assume is very close to most Toyota products. There will be some extra cost involved due to the fact that your ignition key is chipped. This will have to be bypassed. Otherwise its pretty straight forward.
Asphalt FR-S: EcuTek Visconti STG2 tune, MAPerformance turbo kit, MAPerformance 3" exhaust, Hotchkis springs, Mach-V 17x9 Awesomes.
Build thread: http://www.ft86club.com/forums/showthread.php?t=30703
Opposed is offline   Reply With Quote
Old 11-01-2012, 12:24 PM   #3
whaap
whaap's Avatar
Personally I don't like treading in unfamiliar waters and my knowing little to nothing about electronics I'd be worried about something getting messed up. That's just me though.
whaap is offline   Reply With Quote
Old 11-01-2012, 12:37 PM   #4
xwd
Yeah most shops won't touch a manual unless they have experience with it. Some systems have a manual mode where you can't use the system to start the car unless you shut the car off while outside the vehicle with it still running. It figures if you aren't in the car with it running it is in neutral.
Old 11-01-2012, 01:08 PM   #5
xjohnx
Grip>Slip
xjohnx's Avatar
That used to be the case, not so much anymore. Best Buy will even install remote starters on MT vehicles now.
Old 11-01-2012, 01:09 PM   #6
Opposed
Nothing really to mess up. Its a pretty straight forward install for someone who knows how to do it. 3-4 hrs worth of labor though. And if its installed by a shop, then you will usually have a lifetime warrenty from DEI. So they will cover something they find it was due to an install error, or product error. When I worked for Circuit City many moons ago, we had a brand new MPV burn to the ground from a tach wire grounding out. We ended up buying them a brand new van.
Old 11-01-2012, 01:53 PM   #7
jarviz
jarviz's Avatar
whats the average cost for just the labor?
Old 11-01-2012, 01:58 PM   #8
empower-auto
Kouki-Monster
empower-auto's Avatar
Expect to pay around 500+ with installation depending what system you go with. This car needs 2 bypass modules in a proper installation and usually a shop will charge a 35-50 dollar premium being a manual transmission.
Also, check this out: http://www.compustar.com/remotes/RF-2W940-SS.php
I have the above system in my car. It was a bitch to do. Don't let a rookie touch it.
Rich Anderson
EMPOWER AUTO
empower-auto is offline   Reply With Quote
Old 11-01-2012, 02:56 PM   #9
Yruyur
Yruyur's Avatar
I have one ready to install sitting in my drunk. Posted about it on the AZ local thread and found another member who has a bunch of experience and installed one himself. Hopefully will get working on it in a week or two.
Sent from my flux capacitor using Taptalk
Old 11-21-2012, 03:55 PM   #10
cto424
Do you know what extras are needed if i went the Viper/DEI route?
cto424 is offline   Reply With Quote
Old 11-21-2012, 05:57 PM   #11
empower-auto
Kouki-Monster
2 ADS AL CA bypass modules I believe.
Rich Anderson
EMPOWER AUTO
Old 11-21-2012, 07:27 PM   #12
uspspro
Drives: DGM BRZ, MR-S 3.5L V6 swap (sold)
If you have a MT... don't do it.
[ame="http://www.youtube.com/watch?v=a9zg3A8q_Fs"]acura rsx remote start goes wrong - YouTube[/ame]
uspspro is offline   Reply With Quote
FS: Starter Button - 86 GTS (Australian Spec) Sutty Audio/Visual, Electronics, Infotainment, NAV 8 04-07-2013 01:15 AM
Delete driver01 Electronics | Audio | NAV | Infotainment 20 01-31-2013 02:02 AM
self-starter jarviz Engine, Exhaust, Transmission 16 09-14-2012 11:45 PM
Starter Tool Kit Advice Erroneous Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 12 07-20-2012 03:11 PM
Car Finder feature on Remote eriktherod Scion FR-S / Toyota 86 GT86 General Forum 8 06-13-2012 07:23 AM
